BHPian SN88 recently shared this with other enthusiasts.
Hi fellow Jetta owners,
I got an issue with the coolant in my Jetta. On a random inspection, I found the coolant to have become frothy/foamy. I showed it to VW and they said the gear oil and coolant are mixing in the gear oil cooler! They advised replacing the gear oil, coolant flush and the gear oil cooler cover which is estimated to cost approx 40k.
I checked with my trusted FNG and he has said the gear oil does not need replacing in this case as the gear oil has mixed with the coolant and not the other way round.
Can any of you suggest what is the right way? Attaching the photos of the coolant's condition.
Here's what BHPian vishy76 had to say about the matter:
Your FNG's hypothesis isn't completely flawed, but would you really want to risk the GB for it? The oil serves as the hydraulic fluid for the mechatronics and lubricates and cools the clutch packs. Any sort of anomaly in the oil can cause a failure of the mechatronics and set you back big bucks.
Changing the oil and filter at an FNG is not more than 10-12K. My advice is to just change the oil while you are doing the oil cooler and coolant too. It's a very small price to pay for peace of mind IMO.
Here's what BHPian graaja had to say about the matter:
If the gear oil mixed into the coolant, the coolant could have mixed with the gear oil. Only if you can inspect the gear oil, you can be sure that the coolant has not mixed with the gear oil. I guess this has not been done. So it is better to replace both the coolant and gearbox oil and replace the seals that have caused this.
Here's what BHPian ajmat had to say about the matter:
This was common with the mid-90s Mercs since the intercooler and transmission cooler were colocated and corrosion sets in allowing fluids to disperse into other channels.
