Need advice: Upgrading the shock absorbers of my 1.07 L km run VW Ameo
I have a rather odd requirement where in instead of stiffening the ride for better handling, I want to soften the ride for better comfort.
BHPian aadiaksh recently shared this with other enthusiasts.
My VW Ameo has done 107000 kms in the last 6 years. The shocks are done for their life and need replacing.
I've seen and read about Bliestein B6 and B12 on the VW Polo. Also KWs on the Polo as well.
I have a rather odd requirement where in instead of stiffening the ride for better handling, I want to soften the ride for better comfort. The stock suspension is rather stiff for the kind of roads I frequent on. It is confirmed by the fact that no one who has sat in the car have had any good thing to say about the ride quality.
So, I want advice on what to "upgrade" to if that is the right term.
Thanks in advance.
Here's what BHPian KKapadia had to say on the matter:
Bilstein B6 and B12 are more performance oriented. You should go for B4. Those will iron out the bumps better than stock, but they will be very slightly firmer than stock OEM. A softer than OEM won’t be possible to get usually. Unless you try and get a similar size shock absorber of another vehicle. But the ride will become bouncy with a weak shock absorbers. Generally not recommended.
Driven by india
