Renault Duster AWD: Maintenance, repairs & ownership cost after 60k km
General annual service costs between Rs 10k - 12k, however, the bill for the last service at 60k km came to about Rs 21,000.
BHPian Samba recently shared this with other enthusiasts.
Got the 60,000 km service done at the 59,000 km mark. Just before the service, the Duster was taken for another 1200 km road trip to Odisha.
The details of the trip have been shared here.
Now coming to the car
Got the service done from Renault Budgebudge. They again did a fantastic job. I am more than happy with the way they have provided me with all the backups since the purchase of this vehicle. If my next car is again a Renault, Renault Budgebudge will be a significant reason behind that decision.
The 60,000 km service.
The service cost came to Rs 21,376.
Parts replaced:
  • Engine oil (Mineral)
  • Engine oil filter
  • Diesel filter
  • Air filter
  • AC filter
  • Brake oil
  • Differential oil
  • Timing belt
  • Accessory belt
A thorough checkup was done for the vehicle too. Post-service the car is feeling much more silent and smooth and the pickup has improved.
Let me share all the service expenses of this car since purchase:
List of parts changed under warranty:
  • 5 injectors: Each costs Rs 29,000 = Rs 145,000. Finally, Renault changed the engine wiring harness to solve the repeated injector failures in my car: Rs 17,000
  • EGR: Renault suspected this of the coolant consumption issue, but it was not the culprit. Still replaced. Approximately Rs 13,000
  • Head Gasket: Renault suspected this of the coolant consumption issue, but it was not the culprit. Still replaced. Approximately Rs 7,000
  • Radiator & hose: The culprit was a minor crack in the radiator joint. The actual reason for the coolant consumption issue. Approximately Rs 7,000
  • Steering angle sensor: Due to a faint nose while rotating the steering wheel. Approximately Rs 8,500
  • Wheel cylinders: Rs 7,000
  • Fuel Float due to erratic behaviour of the fuel meter: Rs 3,000
  • Dashboard wiring harness due to the erratic behaviour of the fuel meter: Rs 25,000
  • Cluster meter due to erratic behaviour of the fuel meter: Rs 8,000
  • Fuel tank: Due to the erratic behaviour of the fuel meter. Approximately Rs 35,000
Approx: Rs 2.75 Lac! (FOC)
Parts replaced due to wear & tear:
  • Front brake pads (twice) Approximately Rs 4,400 X 2 = Rs 8,800
  • Rear brake shoes: Rs 6,200
  • Turbo hose O-Ring. Approximately Rs 600
  • Diesel filter while changing injectors on a trip. Approximately Rs 3,000
  • Tappet cover (twice): Rs 3,200 X 2 = 6,400
  • Rear shock absorbers on both sides: Rs 14,600
  • Battery: Rs 6,200
  • Four tyres: Rs 29,000
  • Underbelly protection clamp (both sides): Rs 1,600
Approx Rs 75,000. (Paid by me).
General service:
10,000 km, 20,000 km, 30,000 km, 40,000 km & 50,000 km service cost approximately Rs 10,000 - 12,000 per service.
The 60,000 km service cost Rs 21,000. So roughly it will add up to Rs 75,000.
Body shop:
I carelessly reversed the car and got a minor dent on the rear bumper. Got it repaired for Rs 4,000 at Renault.
Total money spent by me: approximately Rs 1,55,000.
Cost per kilometre: Rs 2.58
For the trip to Odisha, I used Xtra green Diesel from IOCL. Honestly, I could not figure out any difference in performance, NVH or fuel economy. It felt all the same. Plus Xtra green diesel has lesser sulfur content, which can be even worse for the already sensitive injectors, so I shifted back to normal fuel.
Here are a couple of pics from the trip.
Redlining the Indian Scene
