BHPian Viju recently shared this with other enthusiasts:
Quadlock
As a smart phone mounting system, Quadlock has become quite popular over the past few years. When I ordered my Bullet, I decided to go for a suitable smart phone mount that I can fix onto the handlebar near to the USB charging port near the clutch lever.
Quadlock does have numerous mounting options though, and it is unlikely that you will not find one that suits your needs. I picked and chose the items and ordered them from Quadlock Japan. But they do have a Quadlock Asia store as well from where they ship to anywhere in Asia.
Dislikes:
Components:
Suitable case for your make and model of smartphone
Necessary components as per your mounting needs
Handlebar mount
Vibration dampener
Wireless charging head with varying lengths of USB cables
Fitment:
Each component fits onto the other with allen key bolts and splines. Adjusting and fixing the orientation is easy and precise. The CNC machined components feel solid and built-to-last. The fitment itself is really easy. I believe the pictures self explanatory. More than happy to answer any questions.
Disassemble the handlebar mount
Fix the mount onto the handlebar with the right spacer
Fixing the vibration dampener to the mounting 'arm'
It is easier to adjust if you fix it directly on to the motorcycle, piece-by-piece
Wireless charging head goes on last
To fix or remove your smartphone, gently press the tab on the left side. The little LED shows the ON / OFF charging state.
Fix a USB cable of suitable length from your motorcycle's charging port to the charging head.
Insert your phone into the Quadlock case.
Fix your phone to the mount, and it should start charging once the engine is running.
