Mahindra Bolero Neo Plus variants & engine specs leaked
The Bolero Neo Plus could be offered in at least 7 variants in 7-seater and 9-seater configurations.
Mahindra has been working on the Bolero Neo Plus for quite some time. While you may have already seen spy images of the SUV, we could only speculate on what lay under the bonnet. Thanks to a leaked Type Approval Certificate, we can now share some technical details of the upcoming Bolero Neo Plus.
As per the document, the Bolero Neo Plus measures 4,400 mm in length, 1,795 mm in width, 1,812 mm in height and its wheelbase is 2,680 mm. The gross weight of the vehicle is 2,390 kg.
The SUV is likely to be powered by a 2.2-litre diesel engine with 118 BHP @ 4,000 rpm. In 'Economy Mode', the engine's output is reduced to 94 BHP.
The document also reveals the different variants of the Bolero Neo Plus that could be on offer. There are seven variants in total: P4, P4 7-seater, P10, P10 (R), P10 7-seater, P10 7-seater (R) and an Ambulance version based on the P4 5-seater. Mahindra could also offer a 9-seater version.
Source: Zigwheels
