Installed Auxbeam 8 universal circuit control relay system on my Thar
There was no space in firewall to take switch wires inside cabin in case of any new items.
BHPian MithunSathianat recently shared this with other enthusiasts.
As I have around 5 auxiliary lamps (2 shoulder, 2 rear, one light bar) and projector fog lamps of which all have separate relays, it was getting difficult with too much of wires inside bonnet. Also there was no space in firewall to take switch wires inside cabin in case of any new items.
To solve this, I purchased Auxbeam 8 Gang Switch Panel BA80, Universal Circuit Control Relay System. This was hand carried by one of my friend who came from US.
I installed this as a DIY over the weekend. The advantage is that now I can control more than 8 devices without pulling wires inside cabin. This supports video inputs from a camera as well.
Total power will go to 600w at 12V, 1200W at 24V and the maximum current is 60A.
The kit comes with 8 panel switch which needs to be mounted in cabin, relay panel which needs to be mounted inside bonnet, connecting wires, mounting brackets, stickers, installation manual, ignition fuse connector.
The thin red cable connects the master switch power cable to the ACC fuse.
I have installed the relay panel on top of stock fuse box as there is only limited space inside bonnet for Thar.
Switch panel has automatic dimmable blue back light.
Got BHP?
