From Kota you can drive either to Jhalawar (in case you need a top up), or you can go directly to Jaora (Delhi-Mumbai expressway).
BHPian piyush.bhandari recently shared this with other enthusiasts.
I recently travelled on this route with a Tiago EV. Since I was travelling from Kota to Indore, I can only provide you with suggestions for that route. Check if it works for you.
- In Kota, you have a couple of options for fast charging if required
- From Kota you can drive either to Jhalawar (in case you need a top-up), or you can go directly to Jaora (Delhi-Mumbai expressway). There's a charger at a petrol pump and you have the option of a couple of shops nearb
- I charged at Jhalawar because of the smaller battery obviously. The expressway does not have anything (rest stops, fuel stations, or ev chargers). The speed limit is 120kmph but I had to drive at 65 without the AC because the distance between the Jhalawar and Jaora chargers was close to 190 kms. But the road is amazing
- A small patch between Kota and Jhalawar is a bit problematic. Other than that it's smooth sailing
- From Jaora, you can go to Ujjain. There are a couple of options. There's one JioBp at Hotel Meghadoot. I had a very unpleasant experience there, however. In case you face any issues, there's one opposite to Hotel Meghdoot (which I added on Plugshare as well)
One thing which is generally helpful while planning trips on Plugshare is to uncheck "show along the route only". This gives you a better picture in case an alternate route is more practical for you.
