Clocked 50000 kms on my Thar D AT: Maintenance, running costs & more
My driving style has changed quite a bit after I got the Thar. No more pedal to metal, a lot more relaxed.
BHPian ph03n!x recently shared this with other enthusiasts.
So Planet Earth's spun around 864 times from this...
...to this on April 3rd 2023:
And I have procrastinated for another 213 rotations to update this thread So here goes, let me give a 10k KM update first, and then get on to more interesting stuff:
Running costs & maintenance:
Kitna deti hai?
Fuel is only a part of the story - the other is in maintenance:
I paid ₹9.20 per KM for Fuel + Maintenance in the last 10,000 KM. But the joy the Thar brings through every one of those - priceless!
While on the topic of running costs, I used to post about how DEF cost have been sky-rocketing. But hey, there has been a price correction, and this time it has- surprise, surprise - reduced!And by 14%, at that.
Wonder what the reason is, but am not complaining - Thanks you, M&M. And whoever else is responsible for that!
Like always, I had ZERO issues with my exhaust system. In the last 10K KM, about 55% of my usage has been highways, 40% in city traffic and 5% in ghats/ offroad.
My driving style has changed quite a bit after I got the Thar. No more pedal to metal, a lot more relaxed - and what better way to prove this, than with an almost unworn pair of brake pads/ shoes?
Do these looks like 50K KM young to you?!!
Niggles:
By and large, this jeep has been niggle-free for after the first ~2000 KM (when I faced the water-in-fuel niggle). But the telltale lamps for ESP Warning, HDC Malfunction and HHC Malfunction came up twice within: 2,000 KM of run:
I have no idea what they meant - the fluid levels were all fine, and the warnings go off after a turning off the Thar, and turning it back on. It never came back after the 48k KM mark (ODO is close to 52k KM now). I did not get a chance to get to MASS to check the error codes soon enough. And the driving experience was unaffected - I didn't get to see if HHC is working, I have never used HDC. And ESP, well - I am not nuts enough to check if ESP is working or not when the warning is calling out a malfunction
So yeah, one of those mysteries...
Addition to the list of Accessories:
When have BHPians ever stopped with fill it - shut it - forget it?! I ended up spending ₹41,330 bucks more. Where?
Horns - I had Hella Red Grill from April '21, but wanted something Thar-y. So out went the Hellas, replaced by Bosch Europa Black Grill:
Rear view Mirror mounted Dual-channel Dashcam:
If you've been following this thread from before, you'd have known that I had a 70mai Dual Channel Rearview Dashcam for more than 2 years now. So why this? While the full story is a post for another day, I wanted a dashcam that also has a GPS module to record vehicle speeds - and found this to be good going by the specs and reviews. Will make a separate post reviewing it once I have it installed and used it for a few months.
And then I got this -because of this.
Image from Amazon listing:
Closing Shots:
What is better than a convertible top Thar? A convertible top with the CT removed completely!
I do this once in a while on farm tracks/ estate roads...
 ...but topless or not, a Convertible Top means your clean-car OCD will get triggered more often than usual. Whenever you take off the top, you will find nooks and crevices to clean/ vacuum!
This was after a closed top run in dusty conditions for a few hours:
Closing off with a couple of clicks from Nelliampathy, with multiple generations of jeeps - I should maybe calls this as "Treat For Thy Eyes" section:
Redlining the Indian Scene
