BHPian airguitar recently shared this with other enthusiasts.
A nut on the spare wheel of my Mahindra Thar was tightened by a local tyre shop in reverse (my bad that I took it there for a tyre puncture fix). Now, it seems to be stuck and I cannot remove the nut to rotate the tyres (or worse if there is a puncture, I will be stuck).
During a recent periodic service, the A.S.S. said that they tried but couldn't remove it and asked me to get it removed at any local garage. After the A.S.S. gave up, I tried on my own to remove the nut (it's not grooved in tight, it rotates a little bit like 10% of a turn but that's it)
What are my options now to have it removed without any damage to the alloy or the mount? Any garage that can help out or is there anything DIY that I can try?
Here's what BHPian SS-Traveller had to say on the matter:
Go back to the same shop and ask them to remove it. They probably put it in with a pneumatic impact wrench, they can take it out the same way.
Here's what BHPian kosjam had to say on the matter:
Take it to a mechanic who has a welder. Ask him to weld a T rod onto the nut and then begins the painstaking task of slowly rotating it open and close and jiggling it, in an effort to break the remaining threads of the lug. With luck (and good welding skill) there will be minimal damage to the alloy but be prepared for some discolouration at the very least. You will obviously have to renew the lug.
Here's how BHPian airguitar managed to fix the problem:
Took it to a lathe and a 3-4 blows with the chisel brought the nut out undamaged. Bolt, nut, mount and alloy are all safe. No damage to the bolt thread either as it was hand-tightened.
