Advice: My Maruti SX4 airbag light switches ON without reason
The error has been cleared thrice but keeps coming back.
BHPian Piyush Kanthak recently shared this with other enthusiasts.
Greetings dear BHPians,
I own a 2007 Maruti Suzuki SX4, 2 months ago the airbag light switched on just before the 20,000 major services, I took it for service and the service advisor has told me that there is no problem with the wiring, airbags and the pre-tensioner, he said that there is an issue with the sensor (not the one which detects the crash) which costs Rs 18,000.
He tried clearing the error 3 times, but it comes back.
Please advise dear BHPians, my car has to run a lot for the next 4-5 months and I will be busy. Moreover, RC is expiring on 22nd August as she will complete 15 years, I want to extend it for the next 5 years, during re-registration if the officer from RTO spots this light, he might declare the vehicle unfit and I have to let her go.
This is urgent, please advise, should I change the sensors, if yes then please tell me where to find it.
Thanks.
Here's what BHPian gkveda had to say on the matter:
Suggest checking the wiring through a local auto electrician. Some small cable chewed by rats can also light up the panel. If he is not able to find out the issue, probably you can think of a sensor replacement.
Sometime back, the engine light turned up in my i10 and the dealer asked for 10k. It got resolved with 600 Rs with the local auto electrician. A small cable issue due to rats was the cause.
Here's what BHPian sole_rider had to say on the matter:
Hello Piyush,
First of all, I am not an expert in this matter. But from the several DIY videos I have seen on YouTube, it could just be that your clockspring assembly might have gone bad. If it's indeed your clockspring, then it should only cost you around Rs 2000 - 3000. Attached is a similar video from ChrisFix on YouTube.
Here's what BHPian asit.kulkarni93 had to say on the matter:
Looks the airbag clock spring has gone bad. Check with an FNG.
