Severe loss of power on my Ford EcoSport: Identifying cause & its fix
Earlier, this used to happen once in 3 months or so, but nowadays, it happens every single day.
BHPian sporteco1.5drgn recently shared this with other enthusiasts.
Hi, I am currently experiencing a severe problem with my Ford Ecosport petrol, which is the popping up of SEE MANUAL warning along with a WRENCH SYMBOL and in addition to that, loss of power.
When I press the accelerator in this situation, the car will vigorously vibrate and the rpm won't exceed 1500. But when I stop the car and restart it, the warning and loss of power will go off. Earlier, this used to happen once in 3 months or so, but nowadays, it happens every single day, causing me more trouble on the road.
Does anyone know what this might be or any possible (affordable) solutions?
Here's what BHPian codeseo had to say on the matter:
I had the same exact issue, which was pointed to the fuel filter. As per the service centre, the O-ring went kaput and the diesel was leaking. After getting the oil filter changed the vehicle was running for a month but again the error popped up.
Were you able to point out the solution?
Here's what BHPian Bhupesh_2628 had to say on the matter:
Hi sporteco1.5drgn,
I faced a similar problem in my EcoSport which I have documented below. After the replacement of the damaged part, I haven't faced any problems yet.
You should visit Ford Service Center and they will help you out in finding the root cause and the fixes.
Here's how I solved it:
I went to Ford Service Center & they said that the O2 Sensor wires have been chewed by the rats.
So, it had to be replaced. However, the part was not in stock & it took 3 days to arrive but a wrong part was ordered. So, had to wait 3 more days for the correct part to arrive.
Today, I went to Service Center & they replaced the part which costs Rs. 1600 & they also updated the PCM to the latest version. The total bill came to Rs. 1900.
Now, the issue is solved with the replacement of this part & car is running smoothly.
I asked a technician how to prevent rats from entering the engine bay. He suggested putting 'Kuber' in dry cloth & hang it on the bonnet joints or at the windshield washer bottle container. This will prevent them from entering. Has anyone done this technique?
Live To Drive
