Enabled the seat belt alarm in my Indica using a Tiago seat belt buckle
While removing the carpeting, I noticed a wire and connector poking out from under the driver seat.
BHPian greenhorn recently shared this with other enthusiasts.
One of the things I've been doing slowly over the years is adding DLX features on my Indica DLG. While removing the carpeting, I noticed a wire and connector poking out from under the driver seat. Curious about what it did, i tried shorting the pins together (Do not try this at home kids, you may blow up a fuse or worse, burn down your car. This DIY was done under controlled conditions under the supervision of an equally curious mechanic).
And guess what? The seat belt warning light lit up! After all these years it was just waiting there for someone to enable it.
Boodmo didn't have the correct part (from the Indica/Indigo DLX) but there was a Tiago part that looked suspiciously similar. I got the help of another BHPian who had a Tiago to check the dimensions of the Tiago buckle, and they looked close enough.
My mechanic did the actual fitting part, and he said he had to do a little bit of cutting/shutting so I'm not going to claim any diy here, but it's working.
I'm probably the only one going to so much trouble enabling the seat belt alarm in a car, when so many people are trying to disable it with fake latches.
Got BHP?
