How you treat your new car engine will directly affect its long-term performance, efficiency and longevity. Failing to properly run-in your engine will have serious negative effects down the road.
Although this is a controversial topic, we stand by the opinions of the manufacturers – after all, who knows your engine better than the company that made it? There are good reasons most manufacturers ask you to take it easy during the initial running period. Call us conservative, but we recommend the tried and tested method. The moving parts of your new engine need an adjustment period before reaching normal operating conditions, and these conditions are determined by how the engine has been run-in. The run-in involves settling the piston rings and ensuring that the bearings and cylinders wear evenly, but it’s not only the engine that needs a running-in. The transmission, tyres and brakes all benefit from it too.
By following these simple steps you can help ensure that your engine reaches its maximum performance and endurance condition. This will maximize you car’s power, fuel economy and engine life. Many new cars are designed to minimize damage from a poor running-in, but even these engines benefit from the advantages of a proper run-in regime.
