BHPian RavenAvi recently shared this with other enthusiasts.
Took Icarus to the Balaji ASC in the afternoon today to get the front suspension lower arms replaced. In addition, they had procured 2 TPMS sensors and the two tail lamp plastic watershed parts had also arrived. Estimated time was given as 2 and half hours and work started at 4 PM.
Icarus went up on the ramp and the front wheels were off. The only difference I could make out was that the newer lower arms had bigger bushings than the old ones. The rest looked the same, even though the sizes were a match.
The lower arm placement.
State of the disk brakes and the wheel mounts. I was told rusting here was normal and wasn't a cause for worry.
Then they took the wheels and checked the older tyre pressure sensors. Surprise, surprise - the front tyre pressure sensors were completely different from the ones which had been procured by Balaji ASC. A part number search showed that the older ones, fitted by Paramount's ASC at Jeypore, Odisha, belonged to the Bolero! The rear tyre pressure sensors were thankfully of the XUV700. The sensor in the spare (5th) tyre belongs to the Bolero.
The older one on the left belongs to the Bolero! The correct, newer one is on the right.
3 tyre pressure sensors of the Bolero were fitted to my XUV7OO. Only 2 were originals. No wonder the TPMS system never worked.
Previously.
They swapped the front ones with the two new sensors they had procured, changed the TPMS system from a 5-wheel reading to a 4-wheel reading, and then the learning of the TPMS was finally completed and the values started showing in both the tyre pressure and the temperature readouts. The spare (5th) tyre pressure sensor was left as is for now, as they placed an order for 1 more sensor for my XUV.
Paramount's service staff must be smoking some very strong stuff back on 31st December 2022 to make such a glaring, obvious and disappointing mistake. Called up the Service Manager at Paramount and informed him of the same, and told him I would be returning the 3 Bolero tyre pressure sensors back to him and to refund me the amount for them accordingly.
In between, they changed the damaged tail lamp flaps with new ones which are now sitting flush and are snugly fit. No more minor rattles from these sections anymore.
It was 7:15 PM when I left the dealership ASC. The MAPPLS update was left pending for my next visit when I return for the spare tyre pressure sensor. The total bill came to Rs. 2,572/-, with the lower arm replacements being done under warranty.
Filled nitrogen to 35 PSI in all tyres on the way and am now happy with the functioning TPMS.
The ride back home was a short one, but from what I observed, the suspension is now much more firm than before and the minor thuds and squeaks I was hearing from the front sections before have disappeared. The steering is now weighing up a bit more than before, even in Zip mode. At low speeds, the suspension is firmer now. The ride quality is pliant. I shall drive around a bit more in all sorts of road conditions and get back with a more detailed opinion on the changed suspension later.
Also, after the EMS update, I am observing a more lethargic response from the engine in Zip mode. It's as if the mHawk is strangled a bit more and the response has gone down a bit. Previously, the Zip mode was pretty zippy inside the city. Now, I am inclined more to use the Zap mode for in-city commutes. As said before, the steering feel has gone heavier too.
More detailed observations in the days to come.
A few days back, I had the unpleasant experience of hearing the speaker scratching thuds yet again (the first time since the software version update). The system rebooted slowly and came to the default MID screens and, to my surprise, it started up in the Zoom mode!
The AdrenoX is still pretty much a TantrumoX. I guess we all have to learn to live with it.
ODO is currently at 5,869 kms.
