Old 29th December 2021, 11:53   #646
Thanked: 27 Times
Re: Volkswagen Vento : Tyre & wheel upgrade thread
I am looking for used tyres for my vento, tyre profile is 185/60/R15. I am based in Mumbai thane area.
Uday
udaydesai is offline   (1) Thanks
Old 3rd January 2022, 14:47   #647
Adrian Stephens's Avatar
Thanked: 25 Times
Originally Posted by Keenobserver View Post
205/60r15 for Vento
Wanted to ask if anyone has used 205/60r15 on their Vento? Does it scrape the inners?
The standard wheel diameter for Highline Plus (195/55r16) is 621mm so that is perfectly alright since the company is fitting those. The 205/60r15 diameter is 627mm, would that be alright to use?
I understand 195/60r15 or 205/55r15 are good options, but wanted to fill up the wheel arches better without upgrading the rims to 16 inches.
Try 205/55 R16...
Volkswagen Vento : Tyre & wheel upgrade thread-capture.jpg
Adrian Stephens is offline
Old 3rd August 2022, 00:51   #648
Altimatum's Avatar
Thanked: 22 Times
Originally Posted by Adrian Stephens View Post
Hi Guys,
Recently discovered that 2 of my 15" alloy wheels on my 2013 Vento TDI have bends in them and need to be replaced.
Does anyone know where can I get my hands on a pair of them in Chennai. Either used or new.
Attaching a picture of the alloy style for reference.
Please let me know if available and details.
thanks in advance. ����
I know it’s been a while since you posted this but if you are still looking for one, I have got a couple of them. I have the same wheel on both my Polo and Vento. I live in Bangalore and if you are still interested, feel free to get in touch.
Vento is up for a big 90k service and I bought a set of 16 inch wheels black wheels to go with the black car. Still debating on the tire size though. 205/55/16 or 195/55/16. 205/50/16 is probably the way to go but not too many options with that profile. Also, worried about breaking rims with the low profiles in our wonderful roads of Namma Bengaluru.
Altimatum is offline
Old 3rd August 2022, 07:51   #649
Thanked: 6,097 Times
If Adrian Stephens requires 2 pieces, I wouldn't mind grabbing the other 2. Will contact you in the DMs
Edit: Can you please enable contacting via email for the time being? DMs are disabled for Newbies and I think it's a bad idea to share contact details in a such a public forum.
Turbohead is offline
Old 3rd August 2022, 10:31   #650
Thanked: 25 Times
Hi Altimatum, Thanks a ton for remembering - much appreciated.
For the moment I've fixed the wheels. Put off replacing them for a later time coz I have a huge service bill coming up with 1.7lac kms. The car is still everything stock apart from the front suspension. So clutch, rear suspension, timing belt, water pump, gear cable and some body work due.
BTW your new rims look smoking. Going to leave them black ? , if it was me i would do a nice dark or light bronze to go with that black beauty.
Will get in touch later on how the 16inchers feel on the car.
Cheers and thanks again.
Old 3rd August 2022, 10:36   #651
Thanked: 25 Times
Hi Turbo ... Its all yours buddy. Cheers
Adrian Stephens is offline   (1) Thanks
Old 3rd August 2022, 11:39   #652
Altimatum's Avatar
Thanked: 22 Times
I have enabled that. Hope that helps…
Altimatum is offline   (1) Thanks
Old 3rd August 2022, 11:46   #653
Altimatum's Avatar
Thanked: 22 Times
I think I will leave it black for now. Love the all black look. Might go for a blue or red caliper paint and accent the same colour on the bumper grill. Will change the rim colours once I get bored of these.
Just curious, when did you last change the timing kit on your Vento. Did you do it at 90 or 100k? Or is it the first time you are getting it done?
Old 4th August 2022, 14:36   #654
Thanked: 25 Times
Hi Altimatum, this will be the first time I will be replacing the timing kit incl the water pump and clutch...
So in love with those new wheels... can you please give me an idea how much they costed you? (Need for budgeting purposes )
Last edited by aah78 : 25th August 2022 at 03:56. Reason: Additional information. EDIT: Typoss.
Old 16th August 2022, 00:31   #655
Thanked: 18 Times
I have a Vento TSI 2015 Dec model. The stock tires are from Goodyear (185/60 R15). It's been 6.5 years now and the car has run 45k kms.
Recently, one of the tires got damaged and have encountered plenty of punctures. Hence, I have decided to change all the 4 tires. I would like to go with the same tire dimensions.
I have gone through various threads here on team-bhp for the suitable tires for my car. Based on this, I have narrowed down my options to the below:
Yokohoma BlueEarth GT AE51
Continental CC6
Note:
- I did come across couple of reviews on sidewall damage with Yokohoma BlueEarth AE50 (older model). However, there are not many reviews for Yokohoma BlueEarth GT AE51
- I read here that Continental CC series tires require careful monitoring of air pressure to ensure that they are not low even slightly.
Please advise.
Gurudeep BN is offline
Old 16th August 2022, 20:56   #656
JoshMachine's Avatar
Thanked: 6,176 Times
Yokohoma BlueEarth GT AE51, Continental CC6.
I would suggest to go for the Continentals, based on my own experience of having driven them for 45k+ km on my (ex)Vento. Great ride quality + very good comfort and grip. I preferred to remain with the stock 185/60 R15 size.
And for the monitoring bit, I don't think there is anything to worry. Just check them regularly as you would do for other brands. I used to do that every 2-3 weeks or so, with Nitrogen filled in them.
JoshMachine is offline   (1) Thanks
Old 16th August 2022, 21:57   #657
Thanked: 63 Times
  • Yokohoma BlueEarth GT AE51
  • Continental CC6
Please advise.
I recently changed mine owing to multiple punchers on one tire and all the tires had missing pieces of rubber on the outer side. Was offered Bridgestone B290, Ceat, MRF and Yokohama Earth 1 E400. Didn't want to upgrade as the options were not interesting at all.
Picked up the E400 and it's been 10 days. The experience has been good so far and muted response when rides over potholes. the stock was 3022. Got 5 years unconditional warranty based on pro-rata (kms driven)
thenomad is offline   (1) Thanks
Old 16th August 2022, 22:14   #658
Rajeevraj's Avatar
Thanked: 19,126 Times
Continental CC6
I just change to the Continental UC6 last week. Too early to make any specific observations, but initial impression is pretty good
Rajeevraj is offline
Old 17th August 2022, 08:48   #659
Hi Rajeevraj,
Is the tire size 185/60 or did you upsize to 195/60?
Would like to hear more about these tires and how they perform with respect to your previous pairs.
Old 17th August 2022, 14:13   #660
Rajeevraj's Avatar
Hi Rajeevraj,
I had already changed to 195/60 when I changed from the stock Apollo Alnacs to Michelin 3ST. Of course there significant difference compared to the current state of the tires at the point of change, but need to drive some more for some detailed observations.
Rajeevraj is offline   (2) Thanks
