Old 7th December 2005, 13:50   #1
Rtech's Avatar
Thanked: 369 Times
Tire size and Speedo error calculator
This is useful for anyone looking at upsizing their wheel and tyres. What's different about this calculator is that it also show you you speedo error after the change.
The basic rule in upsizing is that you want to keep you overall diameter the same as the OE tyre.
Link: http://www.miata.net/garage/tirecalc.html
Rtech is offline   (1) Thanks
Old 7th December 2005, 14:00   #2
speedsatya's Avatar
Thanked: 741 Times
http://www.carbibles.com/tyre_bible.html
this also will help
speedsatya is offline   (1) Thanks
Old 7th December 2005, 23:16   #3
kpzen's Avatar
Thanked: 1,882 Times
these links are of great help for tyre upsizing...
Can anyone please enlighten on pros n cons of having different rim sizes while going for a tyre upsize...??
KP
kpzen is offline
Old 8th December 2005, 09:51   #4
Rtech's Avatar
Thanked: 369 Times
kpzen, read through the link Satya has posted. It will tell you everything you need to know about tyre upsizing. It goes into great detail there, but if you still have some questions, post them.
Rtech is offline
Old 8th December 2005, 11:04   #5
speedsatya's Avatar
Thanked: 741 Times
keeping same OD ,smaller rim means higher aspect ratio or higher profile ...so this will give good ride quality but poor handling...
on the other hand bigger rim size means lower profile ...so this means harsh ride quality over bad roads ...but better handling when compared to the higher profile tires...
Old 8th December 2005, 15:12   #6
kpzen's Avatar
hey rtech
By different rim sizes...I meant having upsized tyres with different rim width size..
For eg. If we upsize the tyre of zen from stock 145/80-12 to 165/65-13...and use 13x 4j rims...wat are the disadvantages of this combination..?
KP
kpzen is offline
Old 8th December 2005, 15:18   #7
Rtech's Avatar
Thanked: 369 Times
As per the rim width calculator (check Satya's link again) you should use:
145/80/12: 4-5.5 J
165/65/13: 4.5-6 J
The upsize seems to be within limits though.
The disadvantge is that you are now running a lowr profile, so your ride will be way more harsh on a small car like the Zen.
Rtech is offline
Old 9th December 2005, 22:09   #8
kpzen's Avatar
hey Rtech
I agree low profile tyres will give you a harsh ride.....
But... I'm facing a different problem with rim width size...
I upgraded my zen tyres to 165/65-13 with stock steel 13x 4j rims....I know the width of rim isn't correct as per rim size calculator...
My handling n braking become pathetic....and driving at high speeds have become scary to say the least...
I just want to know the how a wrong size rim affects the running of a car...??
Will it have any affect on any other parts like suspension and of course tyres..
KP
kpzen is offline
Old 8th January 2006, 16:56   #9
angelfire's Avatar
awesome link satya!!...hey guys..please check out the links...its got everythin you want know about tires..upsizin..etc..
angelfire is offline
Old 27th January 2006, 02:24   #10
nitrous's Avatar
Thanked: 333 Times
Whats the max difference(%) to be kept in mind while choosing an upsize?
Is it 2%??
nitrous is offline
Old 27th January 2006, 03:40   #11
v1p3r's Avatar
Thanked: 7,422 Times
http://www.1010tires.com/TireSizeCalculator.asp
This site also gives you a warning if your OD changes by 3% or over, which is the limit, according to them.
v1p3r is offline
Old 24th February 2006, 12:55   #12
nitrous's Avatar
Thanked: 333 Times
Can the difference also be in the negative (-3)%??
nitrous is offline
Old 20th March 2006, 14:09   #13
~~VinZ~~'s Avatar
Thanked: 7 Times
These links provided are of great for ppl to know about upsizing the tyres
thanks guys....
~~VinZ~~ is offline
Old 26th March 2006, 10:59   #14
Jay
Jay's Avatar
hey Rtech and Speedsatya, thanks for the links dudes.... until i saw these links i wasnt sure of the differences.... helping me a lot now....
Jay is offline
Old 5th April 2006, 22:35   #15
Ya the link is really helpful
princesri1981 is offline
