▲ Go to Top ▼ Bottom
Old 24th October 2012, 09:42   #31
Samurai's Avatar
Thanked: 49,656 Times
re: Review : Yokohama Geolandar AT-S
Originally Posted by jaysmokesleaves View Post
Too early for me to comment on the handling and braking of the Wanderer. Its done just 1000kms till now. Any tire comes into its own only after about 2k kms.
One immediate observation is that tire noise is almost non existent. Ride is not as soft as the Yoko but not hard enough to bother about - similar to the Bridgestones. I cant comment on the braking yet, since ony 1 tire upfront is MRF. But i feel pretty confident about its durability.
What are your thoughts on Wanderers now? I am split between Yoko and Wanderer now for my new purchase. The sidewall weakness is the only thing that is holding me back from Yoko.
How is road grip, braking in wanderer compared to yokos?
Edit: Anybody tried this new Wanderer Sport? http://www.business-standard.com/ind...etyres/177433/
Samurai is offline
Old 25th October 2012, 10:37   #32
jaysmokesleaves's Avatar
Thanked: 1,466 Times
My experience with MRF wanderer:
The grip is good but not as good as the Yokos. Ride is slightly on the harder side compared to a Yoko.
The sidewall is slightly better than the Yoko for sure(thicker) but the tread design leading to the sidewall does nothing to prevent cuts, etc.
The tire life(in terms of tread wear) is surely better than the Yoko, probably due to harder compound.
My Wanderer sidewall has developed cracks in 20k kms with very little offroad use. Note: cracks are not due to impact and are clearly due to manufacturing defect.
Devil and the deep sea. Both suck. neither the MRF not the Yoko is cheap. I will compare the Mrf with the Apollo AT instead. Yoko sidewall is just plain hopeless. Im thinking of replacing with continentals or maybe go for the cheapest AT tire in the market because honestly, from most of the reviews ive read, the tires are highly overrated for indian conditions. They may be good elsewhere in the world.. Yoko's should try offroad testing for their sidewalls in Bombay city potholed roads.
Hope this helps.
jaysmokesleaves is offline   (2) Thanks
Old 25th October 2012, 10:47   #33
KMT
Thanked: 882 Times
I have just decided to try something different for an Estate use Scorpio.
I know they are low on street cred but they are cheaper and have good reviews in Aus and SA. Nankang FT7 A/T OWL.
They are really new and I dont have comments as yet.
KMT is offline
Old 27th October 2012, 21:20   #34
condor's Avatar
Thanked: 16,860 Times
Common point in the feedback about the Yoko's is the softer side-walls. After reading Samurai's posts about the off-roading experiences with the Yoko's, Jay's experieces about damaged tyres even on highways comes like a contradiction, and is not helping things.
So what are the options ? Driving does not involve off-roading.
Should I retain the BS Dueller's as one of the options as replacement for the OE Duellers ? My OE set have done 75k now, with enough tread for another 25k. Just that they are Aug 2005 vintage now.
condor is online now
Old 27th October 2012, 21:40   #35
Jaggu's Avatar
Thanked: 17,293 Times
@Condor dont go by the looks can you post the picture of tire wear indicator area? Also old tyres are not a good idea for highways and for that matter for suspension coz they become hard and transmit lot of unwanted shocks to the system.
Jaggu is offline
Old 27th October 2012, 22:30   #36
Lukeskywalker's Avatar
Thanked: 1,243 Times
Even I am on the lookout for a good AT tyre for my Safari, currently I have shortlisted Yokohama Geolandars and the Continental Cross Contact, I am somehow inclined towards the Contis, but would love to buy the Michelin LTX AT if made available, my Safari has done 68k kms on the Michelins and the tyre guys say I can easily run another 10k kms on them.
Here's a side by side comparision of the tread and shoulder of the Continental and the Geolandar.
Review : Yokohama Geolandar AT-S-photo1-1024x768.jpg
The Continental seems to have a harder sidewall and the shoulder too is vertical compared to the tapered shoulder of the Geolandar. I love the rugged looking tread too, but it could prove noisy.
Lukeskywalker is offline
Old 28th October 2012, 11:41   #37
condor's Avatar
Checked the tyres: 1.5-2.5 mm at the Tread wear indicator points.
Also old tyres are not a good idea for ...
That is the reason I am looking out ! But dont know which one to go for ..
Old 28th October 2012, 19:05   #38
condor's Avatar
Guys, any comments about Bridgestone tubeless ?
Cross-quoting BD sir's comments in Chandrajeet's jeep thread:
DHABHAR.BEHRAM : The only "good tire" in my humble opinion is either the Bridgestone P215/75R15 or the P235/75R15, both tubeless.
Old 29th October 2012, 09:22   #39
jkdas's Avatar
Thanked: 1,496 Times
Condor, Yokos gives you more confidence on highway driving/high speeds/braking. If you just do highway and normal village roads, it should do.
So wanted to get Wanderer but seems I will have to wait for more review now. Crack's @ 20k!
@ Jay, got pix since Condor was saying that it looks wider?
jkdas is offline
Old 29th October 2012, 11:27   #40
condor's Avatar
Thanks.
Tube type or Tube-less ? I have steel rims. (Question specific to Yoko-G A/T)
The corner of the tyres on the Wanderers will look similar to the Conti's in the pic above.
Old 29th October 2012, 11:51   #41
rjstyles69's Avatar
Thanked: 845 Times
Noisy as hell and the braking is the worst at-least from my experience.
Wonder why people have been complaining about the Yoko sidewalls ? Just 2 days back I just drove into a paddy field and then from there on for 8kms thru non existent roads riddled with medium sized stones and yet to see something drastic. Touche Touche !!
Not that I do this on a daily basis, but yes once a month for sure .
rjstyles69 is offline
Old 29th October 2012, 12:42   #42
condor's Avatar
I just drove into a paddy field ..
Next time, pls try a sugar-cane field.& let us know. Or even corn.
Old 29th October 2012, 12:48   #43
rjstyles69's Avatar
Thanked: 845 Times
Next time, pls try a sugar-cane field * let us know
If you dint know, no one simply drives into a sugarcane field right after the harvest that would be the dumbest thing to do . They usually call for the tractor and these dude's are also pretty careful about running the tractor through it. Only after the stumps have gone dry, do they use the plough attachment and get into the fields.
Out of curiosity which sugarcane fields do you drive through on a daily basis ?
Old 29th October 2012, 13:31   #44
condor's Avatar
Why do you think I even suggested sugar-cane ?
(Paddy fields ! The other sections you mentioned would have been more challenging than the paddy fields)
Question was never/is no longer relevant - see my response above
Old 18th November 2012, 07:58   #45
On a recent trip to UP another Yoko casualty to report. Left rear went flat at about 140kph. I could sense a wobble and stopped in time to save the tire from complete damage.
Discovered the sidewall had cut approx 1" starting from the end of the tread footprint.. this was on proper highway use. Its quite disgusting. This is my 3rd Yoko casualty. Left with no option i am now using it with a tube inside though i hate to do so.
By the way, i saw some brand new chinese brand tire selling for 5200Rs. Tread looked good. But the tire felt as soft as a cycle tire.
I feel like trying out Apollos or Continentals now. Yoko, and Mrf have failed me.
jaysmokesleaves is offline   (1) Thanks
