View Poll Results: Combined weight of each wheel/tyre.
5 - 10 Kgs 6 25.00%
11 - 15 Kgs 10 41.67%
16 - 20 Kgs 4 16.67%
20 and above..... 4 16.67%
Voters: 24. You may not vote on this poll
Old 4th March 2006, 04:33   #16
Thanked: 175 Times
Tyre Make/Model - Bridgestone Potenza GIII
Tyre Size - 165/60 R12
Wheel Make/Model - Aura
Wheel Type (Alloy, Steel etc) - Aluminum Alloy
Wheel Width - 5.5J
Recomended tyre pressure - 28
Combined weight of each tyre/wheel - 10 Kgs.
Edmund is offline
Old 4th March 2006, 20:40   #17
kb100's Avatar
Thanked: 22 Times
wonder what the weight of the AIR inside the tyre is... what would the difference be uninflated..
kb100 is offline
Old 19th December 2006, 18:56   #18
supremeBaleno's Avatar
Thanked: 2,906 Times
Originally Posted by Shan2nu
Does anyone have stock Baleno tyre/wheel on their car?
Just got around to weighing the stock tyre/wheel on my Baleno. It weighs 14kgs.
Tyre Size - 165/80 R13
Wheel Make/Model - Stock Baleno Wheels
Wheel Type (Alloy, Steel etc) - Steel
Wheel Width - 5 "
Recomended tyre pressure - 29psi
Combined weight of each tyre/wheel - 14 Kgs.
Planning to move to alloys soon and then will post the weight of alloy/tyre combo.
supremeBaleno is offline
Old 22nd December 2008, 09:51   #19
Finally have the weight diff between steel & alloy wheels.
Ha, took me exactly 2 years to weigh the alloy wheel on my car to know the weight difference between stock and alloy wheels of the same rim size and same rubber.
Was trying to rotate the tyres during the weekend and got a weighing scale along. It helped that I have alloys only on the 4 running wheels, with the spare tyre still retaining the stock steel rims.
Stock 13" steel rims with stock 165/80 tyre : 14kgs
13" Alloys with stock 165/80 tyres ---------: 12kgs
That is a whopping 8kg reduction in unsprung weight for 4 wheels.
Though I am not sure about the benefits this translates into. Anyone ?
Old 11th September 2009, 10:47   #20
goandude's Avatar
Thanked: 1,298 Times
Tyre Make/Model - JK tornado
Tyre Size - 165/80 R14
Wheel Make/Model - Stock Swift Dzire Wheels
Wheel Width - 5 "
Supreme baleno, is 2 kgs weight reduction a significant differnce?
previous post 9 months ago and previous to that 2 years and 9 months ago!!
goandude is offline
Old 14th September 2009, 15:27   #21
Rehaan's Avatar
Thanked: 36,067 Times
Good question. To quote from another site :
To summarize, an additional 5lbs (2.3kgs) per corner of wheel/tire weight (20 lbs (9kgs) total) has an equivalent effect on acceleration of 50-80lbs of weight in the car.
And that doesn't even touch on the non-rotational inertia negative effects on ride and wheel response to bumps in the road.
Source : Wheel & Tire Rotational Inertia Spreadsheet - NASIOC
cya
R
Rehaan is offline
Old 21st September 2009, 21:32   #22
Thanked: 268 Times
Other good links :
Auto Racing
http://se30.dyndns.org:8080/SVX/rot_inertia.html
mithun is offline
Old 21st September 2009, 23:03   #23
breezydrive's Avatar
Thanked: 131 Times
Stock rim of Esteem 4.5J + 155/65 R13; Air pressure-30 psi = 10 kg
breezydrive is offline
Old 4th August 2010, 07:24   #24
mooza's Avatar
Thanked: 375 Times
Requesting Scorpio owners, does anyone have the comparative figures for the Scorpio, for stock versus alloy wheels ? And the handling benefits experienced upon the switchover ?
mooza is offline
Old 3rd March 2011, 23:54   #25
Thanked: 206 Times
Re: Whats the weight of your wheel-tyre combo??
Tyre Make/Model - Goodyear GPS-II tubless
Wheel Make/Model - Palio MJD stock wheel & tyre
Wheel Type - Steel
Wheel Width - 5 "
tyre pressure - 32psi
Combined weight of each tyre/wheel - 13 Kgs.
Tyre Make/Model - Goodyear Eagle NCT5
Tyre Size - 185/65 R14
Wheel Make/Model - League
Wheel Type - Alloy
Wheel Width - 6 "
Combined weight of each tyre/wheel - 14.8 Kgs!
santosh.s is offline
Old 4th March 2011, 11:45   #26
@santosh.s, I was initially surprised to see that your alloy wheels weighed more than the steel rims they replaced. But then noticed that you upsized to 14" & wider wheels.
Old 20th March 2011, 18:37   #27
Dolphin's Avatar
Thanked: 45 Times
I was so curious after going through this thread that I went out, bought a weighing machine and checked the weights of the wheels I have.
Adding to this thread the information I found out.
Details of my Swift VXi's steel, 15" and my latest 17" wheels.
Stock Wheels:
Tyre Make/Model - JK Tornado
Tyre Size - 165/80-R14
Wheel Make/Model - Swift stock wheels
Wheel Width - 5J
Recomended tyre pressure - 33psi
Combined weight of each tyre/wheel - 14.1 Kg (Total weight for 4 wheels = 56.4 Kg)
15" Alloys:
Tyre Make/Model - Bridgestone Turanza ER-60
Tyre Size - 195/60-R15
Wheel Make/Model - Elegant (ELG)
Wheel Type (Alloy, Steel etc) - Alloy
Wheel Width - 7J
Recomended tyre pressure - 28psi
Combined weight of each tyre/wheel - 16.1 Kg (Total weight for 4 wheels = 64.4 Kg)
17" Alloys:
Tyre Make/Model - Yokohama A-Drive R1
Tyre Size - 205/45-R17
Wheel Make/Model - Lenso Samurai SC-04
Wheel Width - 7J
Combined weight of each tyre/wheel - 18.2 Kg (Total weight for 4 wheels = 72.8 Kg)
So, my present alloy & tyre combination (17") is 4.1 Kg heavier at each wheel than the stock wheel & tyre combination, making it 16.4 Kg heavier
overall for a set of 4 wheels.
Dolphin is offline
Old 21st October 2011, 20:14   #28
goandude's Avatar
Tyre Make/Model - MRF ZVTV
Tyre Size - 185/65/15
Wheel Make/Model - new swift alloy stock on Z version "Enkai Suzuki"
Wheel Width - 5 1/2 J
Recomended tyre pressure - 32 psi
Combined weight of each tyre/wheel - 15.3 Kg (digital weighing machine)
1.2 kg HEAVIER than stock steel 14" with thinner rubber as posted by dolphin
goandude is offline
Old 21st October 2011, 22:35   #29
Dolphin's Avatar
Thanked: 45 Times
goandude, all,
I would like to make a correction to one particular detail in my previous post. The stock wheel (rim+tyre) weight of the Swift (old) is 14.8 kg not 14.1 kg. I had weighed a almost bald tyre previously. With a brand new JK Tornado 165/80-R14 tyre, it's 14.8 kg.
So goandude, your wheel combo is 0.5 kg heavier than the stock.
Some latest updates:
Tyre Make/Model - Kumho Ecsta
Tyre Size - 205/50-R16
Wheel Make/Model - Lenso Raiden PD6 (16")
Wheel Width - 7J and 8J
Recommended tyre pressure - 30psi
7J: 16.6 kg
8J: 17 kg
Tyre Make/Model - Yokohama ES100
Wheel Make/Model - Lenso NX (15")
Wheel Width - 6.5J
Combined weight of each tyre/wheel - 15.5 kg
Wheel Make/Model - Lenso Raiden PD1 (15")
Wheel Width - 7J
Combined weight of each tyre/wheel - 15.7 kg
Dolphin is offline
Old 4th July 2012, 19:43   #30
Thanked: 9,250 Times
Nice thread
Car: Swift 1.2
Stock 14" steelies -- 7.5kg without wheel trim
Neo Wheels Thrust 14" -- 6.2kg
Goodyear Duraplus 165/80/14 -- 6.8kg
Stock steelies+165/80/14 Goodyear Duraplus = 14.3Kilos
Neo 14" Thrust+165/80/14 Goodyear Duraplus = 13kilos
A reduction of 1.3 kilos at each corner, not bad
Sankar is offline
