Old 16th October 2013, 13:21   #286
Thanked: 562 Times
re: Maruti Suzuki Ritz : Tyre & wheel upgrade thread
Originally Posted by govigov View Post
Ar10 is made for taxi crowd according to him. He had high praises for Ar 20.
My bad! I misread your post. From your ownership thread I understand that you are using ER60 185/70 14 on steel wheels. Am I right? Can you please tell me what is the pressure you set?
pacman2881 is offline
Old 16th October 2013, 13:45   #287
govigov's Avatar
Thanked: 1,219 Times
Originally Posted by Nikhilb2008 View Post
Lucky you! Even today Bridgestone sent only 3 tyres to us!! Saying they dont have tyres!
Out of curiosity, since you are in tire business -
How do you sell three tires? People buy tires in pairs, correct?
Also, how can it be reasonable better available in chennai and not in bangalore? Do the dealers have a city preference for availability? May be dealer margins? I thought it would be a pan India launch and availability.
Have a look at our mod, n_aditya's ownership review thread, there you have the recommended tire pressure setting for the zdi variant. I am currently running 33 on all four tires, I feel it is a tad too high.
govigov is offline
Old 20th November 2013, 11:17   #288
MetalBuff's Avatar
Thanked: 258 Times
Hello All,
A query from a friend of mine -
He wishes to switch his Swift VXi tires (195/50/14r) to his Ritz VXi currently running on 165/60/14r tires. Anything we should be wary of prior to getting this done or is it safe/ sane?
-Shivang Gandotra
MetalBuff is offline
Old 20th November 2013, 11:55   #289
MetalBuff's Avatar
Thanked: 258 Times
Originally Posted by MetalBuff View Post
Hello All,
-Shivang Gandotra
Apologies for having missed out in mentioning that he has steel rims on both cars. So, it would just be the tires that need to be switched (if, possible and subject to responses!).
-Shivang Gandotra
P.S. - Mods, kindly merge these 2 posts if, possible. Thank you.
Old 23rd November 2013, 22:55   #290
Thanked: 1,632 Times
Gave my Ritz Vxi a new set of shoes last week. Switched from OEM rubbish 165/80/14R JK Tornado to 180/70/14R Michelin Energy XM2. Initial impression after changing the tires is excellent. My car is silent now- I can hear the music in my car without raising the volume when cruising on 90kmph
The tire well looks full and the look of the car is a little enhanced too.
headbanger is offline
Old 24th November 2013, 23:38   #291
S2!!!'s Avatar
Thanked: 10,136 Times
-Shivang Gandotra
Firstly, the stock Ritz tyre size is 165/80 R14 and not 165/60. Secondly, upgrading to 195/50 R14 will give you a 11.1% error. The correct upsize would be 195/65 R14 if your friend still insists on using 195 section tyres. Also if he is using the steel rims which are 5.0J (IIRC) then 185 is the maximum he may upgrade to. Ideal upgrade would be 185/70 R14.
S2!!! is offline   (1) Thanks
Old 25th November 2013, 00:05   #292
k_nitin_r's Avatar
Thanked: 80 Times
Hope to get lucky by finding a customer with 1 blown tire and 2 bald tires.
Sometimes, people genuinely need only 1 tire (recently bought 4, 1 gets punctured).
People returning to their abandoned vehicles with sketchy tires will take whatever they can get from their trusted stores - even if it's not in pairs. They'd take the risk with the 4th tire by using one of the a spare.
k_nitin_r is offline
Old 25th November 2013, 16:05   #293
Nikhilb2008's Avatar
Thanked: 10,177 Times
As someone replied, sometimes we sell tyres in single pieces. Sometimes people pick up 5 instead of 4.
In this particular case there was an issue with supply. We guys got it a couple of days late.
Nikhilb2008 is offline   (1) Thanks
Old 25th November 2013, 16:16   #294
Thanked: 323 Times
I upgraded the tyres of my wife's Ritz to 185/70R14 from 165/80R14. Opted for Michelin XM2 over Continental Eco Contact3 since the Conti kind of had sloped sides, and narrower as a result than XM2.
XM2 was ~250Rs more expensive ...
BTW, what is the offset (ET) of Ritz VXI steel rims ? I couldn't find any stamping of this one one of the wheels I checked ?
lancer_rit is online now
Old 27th November 2013, 11:06   #295
Thanked: 323 Times
Did a 90km+ roundtrip to airport and back last evening. The ride is definitely better, the handling has improved on single lane curvy roads with lesser body roll, and tyre noise is low (though wind noise is more perceptible at higher speeds!).
When going through potholes, undulating surfaces, the car doesn't sway left/right/up/down as much, so a big improvement over stock 165/80R14 JK tyres.
Old 23rd July 2014, 13:08   #296
BANDHAV's Avatar
Thanked: 2,989 Times
Got the Yoka A-drives in 185/70 R14 size for my 2010 Ritz Lxi, the Jks served me for good 65k Kms prior to retiring. I was keen on XM2 but got a decent deal on A-drives so opted for these.
There is a drastic change in the way car rides, the road noise has also gone down by a great margin.
BANDHAV is offline
Old 29th July 2014, 10:40   #297
meetbadri's Avatar
Thanked: 143 Times
Yes, Yoko has a softer rubber than the stock Tornado's. I have heard that there are side wall problems with Yoko's as well as on XM2. Just keep us updated about the tyres performance after driving about 10 K.
meetbadri is offline
Old 10th September 2014, 12:05   #298
Thanked: 2,187 Times
Will be getting delivery of my Ritz Zxi sometime soon which I am sure will be coming with JKs. I will be changing them as soon as I get delivery of the car. Was wondering if I should upsize to 195/70/R14 XM2's or stick to the stock size.
Altocumulus is offline
Old 10th September 2014, 12:21   #299
avinash_m's Avatar
Thanked: 486 Times
Since Zxi comes with 185/70 R14 as std (alloy size is 5J I guess), it won't take 195 X-section. Moreover, will the 195/70 R14 size fall under 2% error wrt overall wheel dia? Just a suggestion, 195 might be an overkill actually for the Zxi; the stock size is ideal for the power it makes. Change to Yokos or Michelin in the stock size.
avinash_m is offline
Old 10th September 2014, 12:45   #300
alexpaul's Avatar
Thanked: 84 Times
Congrats on your new car.. ZXI comes with JK - 185/70/14 tyre size from factory. I suggest you exchange JK with either XM or Bridgestone(ER 60/ AR 20)/ Yoko's. The best upsize for Ritz is 185/70/R14.
I dont think that there are any tyre size of 195/70/R14. What you might be looking for is 195/65/R14 which may scrape your car's wheel well when its is fully loaded.
alexpaul is offline
