Old 7th August 2011, 13:54   #451
supertinu's Avatar
Thanked: 1,247 Times
Re: Michelin Energy XM1+ & Bridgestone Turanza ER-60....The Best Allrounders?
Originally Posted by para_7k View Post
Yes, it is a stone magnet. The tread pattern and the way the sipes are designed makes it so.
Guess what, some times the stones are big enough to make a continuous click click. But they get spit later off the tyre when you reach some speed.
But most of them will get off the tyre themselves. Small stones are not a bother.
When you hit different surfaces, the way in which the tyre and the tread patterns make contact, will get rid of the stones.
yea you are right some of them go off on there own, but in my experience in city like bangalore where avg speeds are fairly low and max i manage on ring rd is 80 kmph i accumulate more than i get rid off, hence looks like as long as i have XM1+ on, i will continue this monthly exercise of removing stones from the tread
supertinu is offline
Old 8th August 2011, 12:32   #452
Nikhilb2008's Avatar
Thanked: 10,162 Times
Why bother? Just leave the stones as it is. Why do you want to take so much trouble for something so useless?
Nikhilb2008 is offline
Old 29th August 2011, 14:55   #453
MadRash's Avatar
I'm looking for 185/60R14 tyres for my Fabia. Tyrestore, Chennai is quoting Rs. 5100.00 per tyre for XM1+. Is it a right price?
MadRash is offline
Old 29th August 2011, 18:38   #454
Thanked: 1,366 Times
I've just fitted Bridgestone Turanza ER60 185/70/R14 on my Swift VDi. The entire character of the car has changed. I would recommend Bridgestone any day!
swiftdiesel is offline
Old 29th August 2011, 18:41   #455
sumeethaldankar's Avatar
Thanked: 3,487 Times
what was the price paid for each tyre?
sumeethaldankar is online now
Old 29th August 2011, 22:39   #456
The price per tyre in Chennai is Rs. 4500 for Bridgestone ER60.
swiftdiesel is offline   (1) Thanks
Old 14th September 2011, 20:53   #457
Soccerfan's Avatar
Thanked: 59 Times
Changed my Punto Emotion tyres to 195/70 R14 XM1+ from the old 185/70R14 A-drives. Immediate difference is no tyre noise compared to the small noise from the A-drives. Upsized as I found the GC not sufficient in the pot holes of Kerala
Soccerfan is offline   (1) Thanks
Old 26th October 2011, 12:57   #458
manasmadaan's Avatar
Thanked: 326 Times
hi, i am plsnning to change my lineas shoes.. which ones are the best to go for? My priority is low noise and harshness from the tyres. Which one do u all suggest?
1. Michelin
2. Yokohama
3. Bridgestone
4. Apollo
Also if i upsize my tyre to 65 instead of 60, how much of ground clearance ll it increase and is there any major disadvantage of doing so?
Suggestions are welcome
manasmadaan is offline
Old 26th October 2011, 13:23   #459
goandude's Avatar
Thanked: 1,292 Times
1. Michelin
2. Yokohama
3. Bridgestone
4. Apollo
michelin would be a good choice considering your priorities. 2nd yoko A drives or apollo.
if you go to 65 you will get 9.3 mm extra GC, but your wheels may foul with wheel well. moreover you will be increasing circumference by >3% resulting in odo and speedo error. check with anybody else having 65 section tyres for Linea.
goandude is offline
Old 27th October 2011, 08:25   #460
Thanked: 326 Times
Thanks for the information. How much problem ll be the wheels hitting the wheel well. If someone has the experience of this, kindly tell because if it occurs frequently, i dont think it ll be worth going for it. As regards the odo-speedo error, i can live with it
Old 27th October 2011, 10:18   #461
Thanked: 60 Times
Good. Now you are running with 178mm ground clearance. 2 mm more than innova(176 mm).
johnjojo08 is offline
Old 27th October 2011, 18:46   #462
Soccerfan's Avatar
Thanked: 59 Times
No issues with tyres hiting the wheel well. I have friends who haev upsized to 195/65 R15 in Linea
Old 27th October 2011, 21:29   #463
Thanked: 326 Times
Thanks soocerfan. This made my decision final to go for michelin 195/65 R 15. Thanks
Old 28th October 2011, 20:06   #464
Thanked: 326 Times
update: i bought michelin primacy LC FOR MY LINEA WITH THE SAME DIMENSIONS AS BEFORE : 195/60 R 15. The dealer discouraged me from going for 65 by showing me the space between the wheel and the suspension handle. It looked like it ll most probably hit the handle while going over potholes.
Following are the pictures
Michelin Energy XM1+ & Bridgestone Turanza ER-60....The Best Allrounders?-20111028-17.07.42.jpg
Michelin Energy XM1+ & Bridgestone Turanza ER-60....The Best Allrounders?-20111028-17.08.03.jpg
Old 31st October 2011, 17:32   #465
ManualShift's Avatar
Neat looking set of rubber. How much did they cost to you.
ManualShift is offline
