Old 2nd August 2008, 19:20   #1
Knight Rider's Avatar
Thanked: 28 Times
Help required (From Potenza's to tube type)
i know it sounds strange, Please read through (taken from an earlier post)
(I dont know about others,But I drive an ALTO and never had a puncture for a year with my Stock tyres, I switched to potza's, In a year I have had more than 9 punctures, Again the road to my house is not all that great..
I had to change one tyre becuase it developed some sort of a bubble and the delaer told me that it cannot be fixed, it would have to be replaced, So I spent another 3k on one tre and recently other two tyres have the same problem,
It was not there when I bought it. The dealer said he cannot do anything and I dont have the time and most importantly 'patience' to run around for this.
One more thing I noticed is that the tyre noice is too much compared to the stock ones. So after considering all the above mentioned factors,
I might have got a bad set, however the last tyre also had the same problem, Now I am left with only 3 tyres.
Thank you for reading so far
So this time I will stick to Tube type.
Profile that I am looking for is 165/60/13/.
How are the indian brands??? Ones that I know
Appolo accelere (Asymetrical pattern,)
MRF (ZVTS)
JK Vectra (Does not have a profile in 13')
Are there any other good brands??? would be really greatfull if someone can mention the prices also..
Mods - Please merge the thread if similar topics exist
Knight Rider is offline
Old 3rd August 2008, 15:52   #2
GTO - Touring's Avatar
Thanked: 56 Times
I understand that you have had a bad experience with tubeless / Potenzas, but dont wash your hands entirely off the tubeless type. They have several advantages over tubetype. In fact, even in this era of cost-conscious manufacturers, more cars are sold with tubeless than vice versa.
If its durability you are looking for (over outright grip), then the S322's will suit your purpose fine. TSK & gang have given decent ratings to the Apollo Acceleres. My choice for 13 inchers would be the Michelin XM1s.
GTO - Touring is offline
Old 3rd August 2008, 21:23   #3
A S H V I N's Avatar
the Apollo Accelere asymmetric pattern starts from size 15" onward. you can go for the regular Apollo Acceleres. a very reliable tyre. long lasting, comfortable and dependable. they are tubeless as well but i had no trouble with them while i was using a set. ironically, i am using Potenza GIIIs now thankfully nothing wrong with them till now. keeping my fingers crossed though.
A S H V I N is offline
Old 3rd August 2008, 23:14   #4
iraghava's Avatar
Thanked: 277 Times
165/60 R13 is not available in either Michelin, Yokohama or Apollo Accelere. Seems like in that size GIII's are your only option.
iraghava is offline
Old 4th August 2008, 11:28   #5
Thanked: 68 Times
Perhaps you have fitted you new tubeless on steel rims that were rusted? Not on alloys?
I too have been wanting to switch from tubed 155/80/13 to tubeless 170/70/13, but without changing the steel wheels to alloys, as I will be keeping the car max one year. Now your experience makes me think twice.
I have had good service with Bridgestone S322 tubed, on a Santro, and these were also the earlier tyres on my Baleno before I switched the latter to Michelin XM1 (and must say not a whisper of trouble for the last one year, but then Baleno has alloys).
filcord is offline
Old 4th August 2008, 11:37   #6
ashutoshb's Avatar
Thanked: 5,259 Times
Have used acceleres on my alto for two-three years. Never faced a problem (be it city or highway).. but it all depends on the roads. Looks like the potenzas could not handle your neighbourhood's roads!!
ashutoshb is offline
Old 4th August 2008, 11:58   #7
tsk1979's Avatar
Thanked: 23,306 Times
Switching to tubless won't give you lesser amount of punctures. My suspicion is that you got a very old/bad batch of Potenza's
For your needs, the Apollo Acceleres are decent. They are cheap, and hardy. You don't need alloys too.
One question, when you found a puncture, did you also find a nail in the tires?
If thats the case, looks like you are driving on a road which has
1. Lot of industrial area truck traffic which means lots of nails on road
2. A tire puncture repair shop which sprinkles nails on road just to generate more revenue.
tsk1979 is offline
Old 4th August 2008, 12:55   #8
Thanked: 28 Times
Thanks GTO, ASHVIN, Iraghava, Ashutosb, TSk1979
To clear some doubts
(Perhaps you have fitted you new tubeless on steel rims that were rusted? Not on alloys?)
@Filcord, the G3's are on 13" Aura Alloy wheels, So we can rule out that scenario.
(when you found a puncture, did you also find a nail in the tires?)
@TSK, I did find the nails and I also suspect I got a very old batch, However, i had to change one of the tyres because of that bubble thing. And that tyre also had a puncture after a while,
How about MRF ZVTS??? Also can someone tell me the rates for appolo accelers in Bangalore?
Thanks in advance people
Old 4th August 2008, 15:29   #9
tsk1979's Avatar
Check out Apollo tires website. They are available with almost all multibrand shops.
MRF ZVTS is kind of okay. I had them on the indica, and braking was terrible.
tsk1979 is offline
Old 4th August 2008, 15:40   #10
trrk's Avatar
Thanked: 34 Times
Hi Knight Rider,
I have Apollo Acceleres in my Marina. After a Bangalore drive one of them did develop a bubble. Since Apollo refused to replace it (the cut inside was a shard raxor blade sort of cut, and they said it is not manufacturing fault - no damage to the exterior) it is doing duty as a tubed stepney.
What I meant to say was any brand of tyre can have troubles.
The remaining Apollo tyres did not / have not given me any problems. Only one puncture so far in 45000kms.
Apollo Accelere Sportz is the asymmetric tyre.
trrk is offline
Old 4th August 2008, 17:33   #11
Thanked: 28 Times
Thanks @tsk1979. I just checked the appolo website.
Apollo Tyres,Car Tires,Truck Tires Manufacturers
Found two.
Appolo Acelere - 165/65/13
Appolo Amazer XL - 165/60/13
Which one should I go for? has anyone used these tyres before? How much should i Shell out for these?
TRRK, Thanks for that info friend, I thought I was the only one with this issue :-)
Old 4th August 2008, 19:40   #12
trrk's Avatar
Thanked: 34 Times
Hi Knight Rider,
This would be +1% error to the original 145/80R12
This would be -2% error to the original.
I would suggest the former. It has more sidewall height and the error is minimal.
> issue :-)
Like in the X files TV serial - we are not alone!
trrk is offline
Old 4th August 2008, 20:03   #13
lohithrao's Avatar
Thanked: 225 Times
Knight rider, thats a very bad experience... i have been using Turanza's for over 15k kms and i have driven extensively on bad roads! till now they are doing great!
Btw can people list out the names of the tyres which can take bad roads, i will vote for turanza anyday!
lohithrao is offline
Old 4th August 2008, 20:49   #14
iraghava's Avatar
Thanked: 277 Times
I don't think you can use 165/65 R13 on the Alto, it fouls with the wheel arches especially at the rear.
KP - what's your opinion on this?
iraghava is offline
Old 4th August 2008, 22:03   #15
WasavaTyres's Avatar
Thanked: 456 Times
165/65/R13 is a definete no no
WasavaTyres is offline
