Old 26th August 2022, 23:18   #181
anjan_c2007's Avatar
Thanked: 22,848 Times
Re: The right tyre pressure?
Originally Posted by NerdSpeaks View Post
A quick observation : I feel that front & rear tyre pressures have got swapped in the chart. Usually, engine side gets more pressure. Or ?
Rightly pointed out by you but for cars only. The two wheeler column is though intact.
PAINTER'S DEVIL
anjan_c2007 is offline   (1) Thanks
Old 27th August 2022, 09:47   #182
earthian's Avatar
Thanked: 2,131 Times
Not necessarily. The recommended pressures for my Mercedes C class is 28 psi for front tyres and 32 for back tyres.
earthian is offline
Old 18th November 2022, 14:00   #183
bravo82in's Avatar
Thanked: 1,273 Times
Sorry for the noob question or if it has been answered before.
When we talk of tyre pressure, is it the cold tyre pressure in the morning or max pressure when car is running or something else?
Thanks and regards
Bravo
bravo82in is offline
Old 18th November 2022, 14:23   #184
Thanked: 462 Times
Thanks and regards
Bravo
It's always cold tyre pressure. On hot tyres the tyre pressure will automatically go up so all measurements should be taken when the car has not run for a bit.
Gupts007 is offline   (1) Thanks
Old 18th November 2022, 19:32   #185
Gansan's Avatar
Thanked: 5,917 Times
Thanks and regards
Bravo
Cold tyre pressure, with no occupants inside the car. If four people are sitting inside, the pressure reading will be wrong. And the pressure should be checked within a km or two after leaving home in the morning.
Gansan is offline
Old 13th May 2023, 14:21   #186
Thanked: 154 Times
I recently purchase a new A35 AMG in India.
The tyre specs as per Mercedes Benz are R18 with a 2 person occupancy front: 38psi and rear 31psi.
For 4 person occupancy front: 39psi and rear 35psi
On the day of delivery the 4 tyre were 42 psi and I drove close to 300kms until next tankful of petrol and correcting the pressure to 39 and 35psi. But after filling the manufacture recommendation I see the car bottoming on few speed breakers when compared to 42 all around.
Can I stick to 42psi all around, drive feel wise I don't see much difference when driving around at 42psi.
Please let me know your suggestions.
Tvk1991 is offline
Old 13th May 2023, 14:55   #187
Gansan's Avatar
Keep 2 psi more than full occupancy recommendation on all tyres, no more. We can never tell exactly when an additional passenger will be there and immediately correct air pressure.
Did you correct the tyre pressure immediately after doing 300 km? Then the pressure indicated will be wrong. Tyre pressure should be checked when they are cold. And nobody should be sitting inside while checking pressure.
Take the car to a fuel station within 2 km from your place and check the pressure after making everyone get out.
Gansan is offline   (1) Thanks
Old 13th May 2023, 16:57   #188
Thanked: 107 Times
I suppose the MAX tyre pressure indicated on your tyre sidewall is 51 or 44 psi.
On either scenario, 42 psi all round is fine and safe.
zeng is offline   (1) Thanks
Old 13th May 2023, 17:06   #189
Thanked: 154 Times
No it was after driving a around 300kms (42 psi without scrapping anywhere) and fill petrol and air pressure early in the morning at my a fuel station <1km from home.
I have a air pressure monitor in my car and I reduced it to manufacturer recommended.
Tvk1991 is offline
Old 20th May 2023, 07:59   #190
Thanked: 163 Times
I need a bit of advice here. I have a 1st gen Innova (diesel). As most of us know, the recommended cold tyre pressures for the stock 205/65R15 tyres are 33 PSI all round for two persons.
I needed AT tyres for the roads (and ocassional dirt tracks) I drive on. So I got a set of 205/70R15 all terrains.
I would like to know what pressures would be optimum for these slightly taller tyres? I usually travel with just one or two passengers. And if the load increases for substantially longer rides, I have a tyre inflator at hand.
The tyre shop did recomended 35PSI all round, but could it be the other way around...
...same vehicle + larger tyre = lower pressure ??
One more thing, the ride quality is not much different from 33 to 38 PSI.
aravind422 is offline
Old 20th May 2023, 19:08   #191
Thanked: 107 Times
If the larger/newer tyre has higher Load Index (as embossed on the sidewall), YES.
Old 21st May 2023, 11:22   #192
Thanked: 163 Times
Thank you, and yes, the OE tyres had a load index of 94 and the new ones are rated 96.
Old 21st May 2023, 17:43   #193
Thanked: 107 Times
LI 94 at 33psi (OEM) carries a load of 1411 lbs per tyre.
LI 96 at 29psi carries a load of 1422 lbs per tyre (higher than above) , hence may be selected for replacement tyre.
LI 96 at 35psi recommended by your tyre shop would carry a load of 1554 lbs per tyre, can one select this??
Why not?
Now can you select 38psi??
Of course you can.
zeng is offline   (2) Thanks
Old 22nd May 2023, 00:02   #194
Thanked: 163 Times
Of course you can.
Ok...
...THAT was quite a bit to digest
So, I now understand that 29 PSI is enough for the higher profile tyre, and that even 35 or 38 is not too much.
I occasionally have to drive 200 to 300 km's in a day. Given that I do get the front tyres aligned at proper intervals for this 1.6 ton (RWD with IFS) vehicle, I would love to know the correct pressure so that the tyres maintain an optimum contact patch with the road and do not suffer overheating or uneven wear.
Thanks.
aravind422 is offline   (1) Thanks
Old 29th May 2023, 12:14   #195
Thanked: 19 Times
Why does similar cars from same manufacturer carry very different pressure ratings.
Eg: Our ignis has a recommended psi of 36 in the front and 32 in the rear unloaded and cold
Our swift had recommended psi of 29 all around.
carreragt6 is offline
