Old 21st August 2007, 14:16   #16
vikram18's Avatar
Thanked: 27 Times
I have the PP1s on my Civic. PP2s weren't in stock and patience isn't a virtue, so got these right away. Very nice indeed
vikram18 is offline
Old 21st August 2007, 15:10   #17
VC12's Avatar
Good choice of tyres, for another Ford.
Michelins are impeccable tyres, how are PP1, PP2 compared to XM1 energy?
I understand XM1's are specifically made for Indian cars and conditions.
By the way I am a customer too at Ashoka Wheels, the person here has very good knowledge of tyres, alloys wheels rather than othet guys hwo are only make money.
VC12 is offline
Old 21st August 2007, 15:57   #18
satish_appasani's Avatar
Thanked: 110 Times
Where did you enquire about Yokohama in Hyd? After reading threads in tbhp, Yokohama is also in my list for my next change which is not very far away.
satish_appasani is offline
Old 21st August 2007, 16:52   #19
vikram18's Avatar
Thanked: 27 Times
I believe the Precedas are made for "Asian" conditions too: bad roads, noise etc. SO while I haven't driven on the XM1s, I can't comment on what's better. Anyways, I don't think there'll be a helluva difference between the two
vikram18 is offline
Old 21st August 2007, 18:29   #20
iraghava's Avatar
Thanked: 281 Times
Actually Vikram, the Preceda's are not made for Asian conditions since they are mainly performance tyres. It is the Energy XM1's which are much better suited to our condition given their low road noise & excellent ride comfort.
And there is a helluva difference in their performance, the Preceda has amazing grip compared to the Energy's whereas the Preceda is not anywhere even close to the comfort provided by the Energy's.
iraghava is offline
Old 22nd August 2007, 09:26   #21
VC12's Avatar
Yes,
I have have seen on XM1 drive is much smooth and importantly is comfortable, less tyre noise , unlike MRF ZVTS which is not that great and claims as most comfortable tyre... heheheheh.
VC12 is offline
Old 22nd August 2007, 09:31   #22
VC12's Avatar
Satish,
Try at Ashoka wheels.. Contact Ritesh 9391219111
VC12 is offline
Old 22nd August 2007, 12:26   #23
vikram18's Avatar
Thanked: 27 Times
I meant that they're performance tyres, which have been engineered to suit Asian conditions and that extensive testing has been done for these conditions, esp. with regards to the PP2s, mainly in the area of tyre noise.
vikram18 is offline
Old 22nd August 2007, 12:36   #24
gaurav_diavolo's Avatar
Thanked: 91 Times
Good rubber there... but your car is in desperate need of some good alloys. The handing would also improve by leaps n bounds!
gaurav_diavolo is offline
Old 4th September 2007, 23:14   #25
theexister's Avatar
Thanked: 7 Times
So far the tyres have been great. The ride has vastly improved just by bringing down the pressure to 30 PSI. Though this is what I was told was filled during installation, it was showing 31.
I agree with some of the comments that the PP1 wasnt great on wet conditions as this was the improvement made on the PP2. But reading around a lot, I realised this is an ideal choice if one is not doing too much wet weather driving above 100Kph. In dry conditions they are a gem.
theexister is offline
Old 4th September 2007, 23:58   #26
iraghava's Avatar
Thanked: 281 Times
Oh come on! You guys really think that travelling on PP2's above 100kmph is a problem? I've been using it throught some bad rains here & I'm very happy with the wet-weather performance. I don't think it lacks in any way & whatever improvement has been made to the PP2 can only be more beneficial to the tyre's overall performance.
Apart from that let me ask you guys, how many cars (stock) do you think there are in our market that can test the PP's limits under normal driving conditions? Discounting some nut case drivers obviously.
iraghava is offline
Old 5th September 2007, 00:36   #27
theexister's Avatar
Thanked: 7 Times
Exactly Raghav. Most of the bad reviews of the PP1 on wet have been on extreme driving conditions (above 140kph cornering).
Wheels 2005 Tyre Test - aussiefrogs
This link rated the PP1 pretty high on everything except wet.
So complaints that they make a helluva difference in normal city driving, compared with the new PP2, isnt exactly fair. Even on the highways, if one is cornering in wet conditions at very high speeds, they must be insane.
Old 5th September 2007, 00:47   #28
reignofchaos's Avatar
Thanked: 2,527 Times
Well cornering at 130kph in the wet is definitely not a problem with the PP2. Been there, done that. No issues with aquaplaning either. I've never had an experience with PP1 so really can't comment. Compared to these, my older Bridgestone Potenza was sad in wet weather.
reignofchaos is offline
Old 5th September 2007, 01:56   #29
Mpower's Avatar
Thanked: 1,735 Times
Energy XM-1
"The Energy XM1 range of tyres has been developed using the Green "X" silica-based compound, which not only reduces the rolling resistance, resulting in lower fuel consumption, but also helps in replacing carbon black, which is a fossil fuel derivative," said Mr Herve Dub, Chief Executive Officer, Michelin India.
The Hindu Business Line : Michelin launches new range of tyres
Mpower is offline
Old 22nd January 2008, 12:39   #30
theexister's Avatar
Thanked: 7 Times
This morning I noticed a few cuts on the sidewall of my rear left tyre.
I am positive these were not present even 2 weeks back because I had put on 3M tyre shiner.
Could this be dangerous and also I have read sidewall damage cannot be repaired.
