Originally Posted by ais
1. Most important is that the tyre pressure remains steady for a few weeks. Changes are mostly due to weather changes. I have TPMS in both my cars and a digital pressure gauge. Also, I maintain pressure in my performance Polo right down to 1/10th PSI. So I know! |
A couple of basics on normal air filling and nitrogen filling. Contrary to popular belief on the internet, when it comes to pressure fluctuations due to changes in temperature, air and nitrogen behave almost identically. It is basic physics and the internet can't change that. (At least that is what I think/have been taught).
In practice, it means that a tyre filled with air or nitrogen will increase or decrease pressure in a nearly identical way due to changes in ambient temperature. They just follow the basic gas laws. If memory serves me right I think the difference is less than 0,1%.
When it comes to leaking of air/nitrogen, on a tyre two main reasons can cause these leaks. (apart from punctures and so on)
Rubber tyres permeate the air. So air molecules can make their way, very slowly, through your tire. Nitrogen molecules do so too!!! Just a bit slower than air molecules, about 40% slower.
These days modern tires are made with a special inlay on the inner layer of a tire, so permeation is a lot less. It's always there, but these days it is really small. There is as far as I know legislation in many countries that regulates how thick this layer needs to be. I am not sure if it applies to tyres in India.
Various consumer organisations around the world have looked into this. On average, they found only about 1.3 PSI less over an entire year,
The other possible problem is how well the tyre seals on the rim. This is, by a long shot, a much larger area of concern for most of us car owners. If you need to fill up all your tyres every few weeks, it is never due to permeation, always due to a problem with the sealing of the tire/rim. Or incorrectly fitted items, such as valve stems or TPMS sensors.
Very often this can be solved by removing the tyre, cleaning the rim thoroughly refitting the tire and balancing it.
But then again, adding a bit of air is much quicker and cheaper of course. Also, regardless of whether you have TPMS, it is good practice to check the pressure in your tyres now and then. (And don't forget the spare!)
I would be very interested to learn a bit more about a pressure gauge that can read with 0,1PSI accuracy. Just because your pressure gauge shows values with 1/10th increments on its digital display does not mean it is accurate to 1/10th of a psi. I can almost guarantee it is not. It would have to be a pretty accurate pressure gauge and it would require a lot of calibration too!
I am not quite sure why you would want to measure air pressure at 1/10 psi either. I don't think car or tyre manufacturers specify tyre pressures at that level.
I will say this though: The biggest problem with pressure in tyres, be it air or nitrogen filled is the accuracy of the gauge used. Very few, if any pressure gauges get calibrated regularly. I have experience in my own shop with how quickly, even high-quality pressure gauges, become in accurate. I just buy a new one every 12-18 months. The only way to ensure I get good, sort of half-decent, accuracy. One simple check is to use two different gauges and see if they indicate differently.
Originally Posted by ais 2. Pressure changes due to driving are certainly lesser than normal air. |
Maybe according to you, but not according to physics. There could be other reasons for your observation of course. For the average driver, there’s no discernible difference between driving with nitrogen-filled and air-filled tires
Originally Posted by ais 3. The ride does feel softer, though I dont know why, but its probably because nitrogen is less dense than oxygen, so more pliable. |
The molecular weight of pure nitrogen is 3% less of typical air.
Again, not due to physics. There must be something else to cause this observation of yours.
Originally Posted by ais 4. Nitrogen is an inert gas. The pumps supply it from bottled nitrogen (just checked- I am at Indian Oil pump, Bandra, as I type this). So the nitrogen is 100% pure and dry. This will definitely extend the life of whichever parts come in contact with it compared to air. |
I doubt very much that the nitrogen is 100% pure. There are two reasons for this. It is very expensive to produce 100% nitrogen. The other reason is that at a percentage of over 93% nitrogen, oxygen from the outside air starts to migrate back into the tire! Look it up.
Nitrogen for tyres is always somewhere between 93-95% pure.
Originally Posted by ais I would not think of reverting back to air. |
If it makes you happy and comfortable, by all means, keep doing it!
Lastly, if you want to fill your tires with nitrogen, for any effect, because of the effects (mainly slightly slower permeation losses) the tires need to filled and flushed with nitrogen several times over. I you just deflate the tire and fill it up with nitrogen, it is not going to make any difference whatsoever.
Just my 2 cents of insights. It is enormously valuable to debunk all kinds of crap on the internet.
Jeroen
