Old 5th February 2015, 12:36   #106
AZ911's Avatar
Thanked: 379 Times
Originally Posted by dynomite View Post
Hey everyone - though you'd like to know about this. Blaupunkt India has launched their own TPMS system. Plug and play, like the Steelmate one, with 4 external sensors that you can install yourselves. I'm currently reviewing it - so can also answer any questions you may have. (Disclaimer: I'm in no way connected to Blaupunkt)
Here's the box.
Attachment 1336577
Price label
Attachment 1336578
Attachment 1336579
Attachment 1336580
This is the display unit - plugs directly into the 12V socket and shows real-time pressure for all wheels.
Attachment 1336581
This is the 1 amp USB port behind the display. You can flip the display down and plug a phone in to charge if you like.
Attachment 1336582
Here's a shot of the sensor installed on the valve. No wheel balancing is required after installation. Total installation takes only 5 minutes. Each sensor comes with a silver and a black cap and the lithium coin battery inside is user replaceable.
Attachment 1336583
This TPMS looks good except the fact that the sensors are so easy to remove. I have had my valve caps stolen so many times that I can't even afford to have this kind of setup.
Are these caps individually available for buying? Also, what's the on road price of this thing. There's always some scope on the MRP. 😄
AZ911 is offline
Old 5th February 2015, 12:55   #107
dynomite's Avatar
Thanked: 110 Times
Re: Onboard Tyre pressure sensors
Actually, the external sensors are not very easy to remove.
i.e., you can't just unscrew them, like you would a valve cap. I think all TPMS units with external sensors come with this anti-theft feature.
You can't really see it when you look at the sensor, but there is a hex nut behind it. You get a tiny spanner with it (that you're supposed to keep in the car). First, you use the spanner to loosen the the hex nut behind the sensor - then the sensor screws off normally.
See the image for details - first, you put the hex nut on the valve, then screw on the sensor, then tighten the nut behind the sensor with the spanner. It stays locked.
A further question would be - is this required everytime you need to fill air in the tyres? The answer is yes, unfortunately. That's why you keep that tiny spanner in the car
dynomite is offline
Old 5th February 2015, 17:52   #108
Thanked: 402 Times
Thanks for sharing.
Looks good, but MRP of 18990 appears a way too higher than some of the units discussed on this thread.
mayuresh is offline
Old 6th February 2015, 12:34   #109
dynomite's Avatar
Thanked: 110 Times
Originally Posted by mayuresh View Post
Thanks for sharing.
I agree - 19K is way too much for a basic system. Steelmate is good. I've seen some different versions that they have (including the one that communicates with an iPhone and app). I wonder why they only sell the basic TP70 here. Still, 9k is an excellent price.
If someone wants - you can even import ones with a larger display, temperature/pressure readings and your choice of internal/external sensors from Aliexpress. starts at about $100 including shipping from trusted suppliers.
dynomite is offline
Old 1st November 2015, 22:55   #110
Thanked: 190 Times
I've been looking around for a good TPMS that can monitor 5 tyres.
After poring through a lot of threads and trucker sites it seems the external cap sensor option is as reliable as an internal tyre sensor, plus its an easier option as compared to internal tpms which are prone to damage during puncture repairs and don't have replaceable batteries. While the good thing with the american ones is that 5 tyres can be monitored, they're priced 300 quid and above :(
Guess I'll have to head to aliexpress after all.
Here s a video of alan whiting of outback travel australia, explaining the advantages of a tpms in the outback. its a plug/review for a tpms company, but worth a watch nonetheless.
famousshoes is offline
Old 10th July 2017, 20:09   #111
Shreyas Agarwal's Avatar
Thanked: 1,402 Times
I want to install a TPMS in my newly acquired Innova Crysta 2.8 ZX. It is shame that it was not provided even in a 25 lakh car. App based systems are not preferred as the car would occasionally be driven by a driver who does not own a smartphone. Also, it would not be sufficient for all time monitoring. If it is to be installed on the car charger then it should fit in the space around the socket
Source: Toyota Innova Crysta: Official review.
Your suggestions would be highly appreciated.
With Regards,
Shreyas Kumar Agarwal
Shreyas Agarwal is offline
Old 10th July 2017, 21:38   #112
archat68's Avatar
Thanked: 642 Times
With Regards,
You can check this one from AliExpress. I bought and it's very good. I also fixed this in my cigarette lighter socket.
Tpms tp620 Car Tire tire pressure alarm Car Tire Diagnostic-tool support Bar and PSI tire pressure monitor car electronics
http://s.aliexpress.com/eYVrAB32
(from AliExpress Android)
It measure around 1.5 inch by 1 inch approximately. You can get delivery within 30 days.
archat68 is offline   (1) Thanks
Old 10th July 2017, 22:11   #113
I don't think that this one would fit there as there is a design flaw in the car. There is alomst no space towards the right of the charging socket and the device you suggested appears very wide from the pictures. Hence, I fear that it would not fit.
Old 10th July 2017, 22:44   #114
archat68's Avatar
Thanked: 642 Times
The whole device measures around 1.5 inch i length and 1 inch in height. You can turn it at 90 degrees so will need around max 1inch space around the socket.
Old 15th July 2017, 08:48   #115
Can you please attach a picture with the device installed on your car, the pictures present on the internet give a very vague idea of dimensions.
Some reasons due to which it does not suit me: 1. Its shipping time is very loooonng.
2. It appears broader than any other TPMS I have seen on the internet.
3. Mounting it at 90 degrees will cause me to misread it sometimes.
4. Mounting at 90 degrees is even more difficult than mounting horizontally because there is even less space above it than below it.
5. Also, my debit card does not allow international transfers.
Old 30th July 2017, 14:06   #116
archat68's Avatar
Thanked: 642 Times
Sorry for the late reply. Here are pictures
archat68 is offline
Old 7th September 2017, 21:06   #117
Thanked: 1,788 Times
Just the thread i was looking for!
I got delivery of this TPMS from AliExpress today for my Hexa:-
tpms tp620 Car Tire tire pressure alarm Car Tire Diagnostic-tool support Bar and PSI tire pressure monitor car electronics
http://s.aliexpress.com/biQfAruq
Is wheel balancing required for such external sensors?
I see that the OP mentions it's not required but am a bit doubtful.
Have planned for a long journey this weekend, so any replies would greatly help!
abhi7013 is offline
Old 11th March 2018, 09:20   #118
Thanked: 1,011 Times
even I have this question : after installing TPMS sensors, will that disturb the wheel balancing, need to do balancing again ?l
appreciate if someone puts light on this matter.
PS: I dont have TPMS on car, but recently put TPMS on my motorcycle.
pcpranav is offline
Old 11th March 2018, 10:02   #119
manas27587's Avatar
Thanked: 81 Times
Can anyone put out a link on a good tpms for the tata hexa?
manas27587 is offline
Old 20th March 2018, 05:23   #120
Thanked: 21,450 Times
Budget that you are ready to spend on?
AliExpress has many available but I am not sure in terms of reliability and life! The one I liked is:
Solar type TPMS internal sensors
a4anurag is offline
