Old 9th May 2022, 04:16   #16
shiven2207's Avatar
Thanked: 57 Times
Re: XUV700 : Tyre & wheel upgrade thread
XUV700 : Tyre & wheel upgrade thread-img_20220503_071448_bokeh__01.jpg
Updated my AX5 P AT with 255/65 R17 AT tyres from Maxxis. Loving the looks and the stance for now, Looking ahead for lots of bad roading ahead .
shiven2207 is offline   (5) Thanks
Old 13th August 2022, 15:06   #17
Thanked: 460 Times
Originally Posted by shiven2207 View Post
Attachment 2305839
Oooh.. sweet shoes you got there sir, the stance looks so much more purposeful with these! I'm waiting for my AX7 AWD and am eyeing the exact same tyres but am hesitant due to the ~ 3.5% gain in circumference. Would be much obliged if you could please answer a few questions
1. How much clearance does the tyre have in the wheel well now? Do the tyres foul with the wheel cladding on full turn of the steering?
2. How much would you say is the increase in the road noise over the OEM's?
3. How does the 13 mm gain in sidewall height affect the ride? Does it cushion the low speed broken road ride better than the OEM's?
4. Any negative effect on braking distance noted?
5. What's the damage to the wallet?
Much thanks!
Vtach is online now
Old 22nd August 2022, 13:06   #18
Thanked: 341 Times
Attachment 2305839
Very worthy upgrade. Where did you procure them from in Delhi and what was the final paid after buyback?
saurabh041086 is offline
Old 13th September 2022, 00:19   #19
Thanked: 477 Times
The OEM tyre size for the top end XUV500s (W11) and the XUV700s are the 235/60/R18s. The options that I could find are
Apollo-Apterra-HP
Apollo-Apterra-HT2
CEAT-SportDrive-SUV
Continental-ContiSportContact-5-SUV
Bridgestone-Ecopia-EP850
GOODYEAR EFFICIENTGRIP SUV
GOODYEAR EXCELLENCE
Yokohama-Geolandar-SUV-G055
Yokohama-BluEarth-RV02
Michelin-Pilot-Sport-4-SUV
Michelin-Primacy-SUV
I have not been able to find a A/T tyre. Is there any other tyre model available that fit this rim size?
ohaak is offline   (1) Thanks
Old 13th September 2022, 10:47   #20
Thanked: 659 Times
Hello. You're right, there's no A/T tyre available in the market in this particular size. You have 2 options if you're particular about A/T tyres:-
1. Downsize your alloys to 17" and fit 235/65R17 size where you have many options like Ceat Czar A/T, Apollo Apterra A/T2, Yoko Geolandar A/T, GY Wrangler A/T, etc. This is the more cost effective option. You can trade in your 18" rims and tyres so that the hit on your pocket is minimal. Even the tyres cost in the range of 11-13k only per tyre.
2. If you want to stick to 18", you need to up-size to 255/60R18 size where you have the option of Continental CrossContact AX6. However, the tyres are not cheap and would set you back around 18~20k per tyre.
Just some food for thought - is your off road usage really so much to warrant going for A/T tyres? These tyres can get noisy on the highway.
RubberGuru1113 is offline   (3) Thanks
Old 13th September 2022, 13:39   #21
Thanked: 477 Times
My XUV500 has done about 40,000KMs and it is due for a tyre change. I don't know if there is value attached to my 18 inch rims. My car has AWD.
The normal H/T tyres for the 18inch rims are also in the similar price range of about 15-20K. Upsizing is something that I have not considered so far. I will look into it.
95% of car usage is on good roads. The problem is with the 5%. When I travel with my family on off-beat roads / tracks, I don't want to get stuck. I used to run with GoodYear Wrangler SA A/T on my older XUV500 which had 17inch rims. The steering becomes tighter, the side wall strength makes it a bit less comfortable and the mileage drops a bit with A/T as opposed to H/T. But I get peace of mind on muddy roads, etc.
ohaak is offline
Old 13th September 2022, 15:54   #22
Thanked: 659 Times
Honestly, 5% usage on bad roads can be handled by any competent H/T tyres fitted on an AWD vehicle, you would not get stuck purely on the account of not having A/T tyres unless you are on extreme trails. Put your mind at ease and go for a good H/T tyre among the options you listed above
I'm merely re-iterating Shreyans' piece of advice on the same thread.
Originally Posted by Shreyans_Jain View Post
The kind of usage you are describing doesn’t really require all terrain tires. The stock MRFs should be good enough. Why go through all this trouble for a bit of extra traction once in a blue moon? Not only will A/Ts be more noisy and less grippy on highways where you’ll do 95% of your driving, you will also get into complications with warranty.
My suggestion is to keep the car stock for the time being. Will not suggest anything that compromises warranty on such a brand new and complex car. Over time, choice in R18 is only going to increase, this size of getting popular. We can consider our options when this set wears out.
RubberGuru1113 is offline   (1) Thanks
Old 16th September 2022, 23:17   #23
Thanked: 477 Times
I decided to change to 17inch rims from Plati and I am getting the Yokohama Geolander A/T G015. I now have the original 18inch rims available. Will try to sell them on OLX.
Old 14th October 2022, 19:13   #24
Thanked: 993 Times
I got my tires changed to Michelin Primacy SUV+ on my XUV700 AWD - I would definitely recommend them to anyone looking for a quieter, softer ride as compared to the MRFs that came in my XUV700. With the Bangalore roads taking a beating from rains this year the Michelins have been a lot comfy over the potholes and broken roads.
Sandegov is online now   (1) Thanks
Old 21st October 2022, 18:01   #25
Sommos's Avatar
Thanked: 1,591 Times
May I know the price that you expect for the original 18 inch rims.
I need only one for the spare.
Sommos is offline
Old 31st October 2022, 19:30   #26
Thanked: 477 Times
One of the employees at the tyre shop that did the fitting purchased the old set of four alloys from me. Apparently there is a good market with resellers for used alloys.
ohaak is offline
Old 4th May 2023, 19:39   #27
Thanked: 460 Times
The "Eco" (? Economy) in the MRF Ecotreds was triggering my OCD. If there's a possibility of even a small improvement in braking distance/grip/ noise reduction by having better tyres, I would want it. So drove straight to the tyre shop from the showroom and exchanged them for Scorpion Verde's. Have driven about 3500 kms over past 10 days(mostly highways), very happy with the performance.
And to Mahindra's bean counters, what's up with the joke of a 155/90 113 M R18 balloon supposedly to be inflated to 60 PSI, mounted on a 4.5 J rim, that's supposed to be a stepney? At least provide a proper 6/7 J steel rim onto which a proper sized spare tyre can be mounted by the customer at his own expense, it's your flagship car for heavens sake.
XUV700 : Tyre & wheel upgrade thread-20230425_105420.jpg
XUV700 : Tyre & wheel upgrade thread-20230425_105400.jpg
XUV700 : Tyre & wheel upgrade thread-20230425_104435.jpg
Vtach is online now   (1) Thanks
Old 10th October 2023, 15:39   #28
sumobom4's Avatar
Thanked: 197 Times
Hi All! I am getting delivery of my new XUV7OO next week and wanted to know my options to change from the OEM tyres (235/60 R18). I am not looking to change the size as I feel that the stock size is quite good. I contact Super Tyres in Nahur, Mumbai and they have Conti CSC 5 and Pirelli Scorpion Verde in stock. Are these good replacements, or is there another option that I should be looking at? My current car is a Suzuki XL6 and I was very happy with the change from stock Ecopias to Yoko Blue Earth GTs.
Would appreciate any guidance from the experts here. Thanks!
sumobom4 is offline   (1) Thanks
Old 1st May 2024, 23:37   #29
Hello Friends,
I am a proud owner of a silver XUV 700 D AX7L AWD Sep-22 model.
So far I have clocked 37000 km and covered a 1600km trip to Spiti (including the dreaded Kaza to Koksar strech) and a 4600km Ladakh circuit (delhi-srinagar-kargil-zanskar-sarchu-leh-turtuk-pangong-umling la-tso moriri-manali-delhi). Now I am planning for my next road trip this summer
Till date I have used the stock tyres Bridgestone ECOPIA - EP850 235/60/R18 103V which are about 70% worn out. And i wish to change to All Terrain tyres (AT) but due to unavailability of AT in R18 it has been a big problem so far. I have been searching Team BHP forums and other resources like car enthusiasts and tyre dealers for almost two years but could not find a suitable replacement. Though I got my hands on a set of Comforsor CF1100 235/60/R18 AT 104S (imported from Canada by a fellow enthusiast) through someone I met in the Mahindra workshop who had come for service of his XUV700 but something didn't sit quite right with me (also the lower rated top speed of 180km/h which is non negotiable for me), so I let it go.
Fortunately, my persistence has paid off and I have found out that now Bridgestone is manufacturing the AT tyre in the same specs for R18 tyres for AX7 model. If any one is interested they can reach out to Bridgestone dealers and ask for the tyre mentioned below.
Details - Bridgestone Dueler All Terrain A/T 002 235/60/R18 107H.
Besides impact in areas like comfort, noise and fuel efficiency, there is also a decrease in the top rated speed of the tyre from 240 Km/H to 210 Km/H as compared to the stock HT tyre ECOPIA - EP850. Although the trade should be acceptable for the off road enthusiasts like me who have been waiting for AT tyres with exact specs for so long.
So fellow enthusiast splurge and enjoy exploring new territories, and don't forget to drive safe!
Best Regards,
Appy
Appy_Wanderlust is offline   (5) Thanks
Old 23rd May 2024, 17:29   #30
Hi All,
I recently purchased the XUV 700 D MT AX5 2024. I would like to know your views on replacing the spare wheel with matching alloys and tyre. The dealer is quoting around 28K (17K for matching alloy and 11k for MRF wanderer).
Does it make sense to go with this fifth alloy or continue with the spare wheel where it has its own restriction on speed and distance. I do plan to use it in some rugged areas occasionally. So, I'm very much confused on this.
Could you please guide me on this, whether the price makes sense and do I need to go with replacing the space wheel.
Thanks in advance.
Hemanth.
hemanth.hg is offline
