Old 23rd October 2006, 17:15   #1
Wind's Avatar
Thanked: 75 Times
Opel Corsa : Tyre & wheel upgrade thread
My Corsa swing is running on stock 175/70 R13 tyres on steel rims.
I am planning to switch to tubeless with Aura alloys. With the ever increasing dimensions of humps in Bangalore, I am finding ground (hump) clearance to be bit of a problem now a days and I intent to go for 14 inch tyres.
It would be great if someone could suggest if 175/70 R14 or 175/75 R14 would be a better option. I am leaning towards 175/75 R14 since the factory fitted alloy variants of Corsa came with that specification and it may not need any suspension adjustment and it gives a better ground clearance.
Please share your thoughts
Wind.....
Wind is offline
Old 23rd October 2006, 22:54   #2
kpzen's Avatar
Thanked: 1,882 Times
185/60-14 potenza GIII for very good performance.....
Or same size Turanza ER60 for comfort ..
kpzen is offline
Old 23rd October 2006, 23:04   #3
Vid6639's Avatar
Thanked: 44,134 Times
185/60-14 would be the best bet. if you are looking for comfort go for the turanza ER60 else the potenza G-III.
Also while buying the tyres make sure you get the 4yr warranty for th tyres.
Buy them from bridgestone performance shops. i found they give the best rates as well as warranty.
Vid6639 is offline
Old 24th October 2006, 08:02   #4
Wind's Avatar
Thanked: 75 Times
Thanks, guys.
I just checked up the Bridgestone site. How about Potenza G-III 195/60-14 since the primary reason I am going for the upsize is to increase the hump clearance. Any cons?
Wind...
Wind is offline
Old 24th October 2006, 13:37   #5
kpzen's Avatar
Originally Posted by Wind
Thanks, guys.
Wind...
The Swing has a peculiar rear wheel arch that some part of the stock tyre itself goes inside when with half load....
So 195/60-14 is a taller than 185/60 n it can make the wheel foul with the wheel wells...Ya sure the 195/60 will increase the hieght....
kpzen is offline
Old 24th October 2006, 17:14   #6
I recently changed to Michelin 185/70 R13 with Aura alloys..
Ground clearance has increased and the ride is smooth over rough surfaces.
dhir_d is offline
Old 24th October 2006, 17:16   #7
I changed to michelin 185/70 r 13 with aura alloys..
ground clearence has increased..
dhir_d is offline
Old 10th November 2006, 14:13   #8
faithless_1984's Avatar
Thanked: 328 Times
this corsa is parked near my coching centre so i used to see it everyday and finally took the pics today.
sorry for the pic quality, its from a vga camera phone p910i.
Mods if these should be posted in some other thread then please move the post to the appropriate thread.!
faithless_1984 is offline
Old 10th November 2006, 14:15   #9
Thanked: 328 Times
Old 10th November 2006, 15:41   #10
kpzen's Avatar
Hey Faithless..!!!!
That looks like 17" alloys with 205/40-17......
kpzen is offline
Old 10th November 2006, 15:47   #11
Thanked: 328 Times
yes i guess they r 17" alloys and they look damn hot but the ride must be hard
hey guys any idea which alloys are those and how much do they cost?
Old 29th November 2006, 00:24   #12
sAP
sAP's Avatar
Thanked: 55 Times
Corsa OEM factory spec
Wind: Corsa's factory fitted alloys are 175/65R14, not 75 (for all variants of the Corsa, including the Swing, Sail or Sedan)
sAP
sAP is offline
Old 29th November 2006, 16:06   #13
esteem_lover's Avatar
Thanked: 513 Times
Wind.....
from what you have said, your wheel circumference is going to increase by almost 8% & that is huge & will naturally have an impact on the speedo & odo readings. go through this to find out how
Car Bibles : The Wheel and Tyre Bible
hope that helps. cheers
esteem_lover is offline
Old 29th November 2006, 19:19   #14
kpzen's Avatar
Originally Posted by faithless_1984 View Post
Saw this car yesterday the wheels look very big n odd for the car....
KP
kpzen is offline
Old 29th November 2006, 22:13   #15
Wind's Avatar
Thanked: 75 Times
sAP
Thanks esteem_lover and sAP...
I have decided to go for 175/65 R14 Turanza with Aura alloys.
Wind is offline
