Old 27th January 2013, 11:44   #46
ad75's Avatar
Thanked: 25 Times
re: Maruti Ertiga : Tyre & wheel upgrade thread
hi
whats the width(in inches) of OE steel rims in ertiga ?
ad75 is offline
Old 27th January 2013, 14:49   #47
zenren's Avatar
Thanked: 1,755 Times
Originally Posted by ad75 View Post
hi
Should be 5.5" as it is the ideal rim width for 185, which is the OE tyre width.
zenren is offline
Old 27th January 2013, 20:09   #48
Thanked: 205 Times
Hi All,
Is it ok, if only front two tires are upgraded to 205/55/16 & retain the stock size 195/55/16 for the rear two? Will it cause any problem?
Chitta Pradhan is offline
Old 27th January 2013, 20:59   #49
zenren's Avatar
Originally Posted by Chitta Pradhan View Post
Hi All,
Ertiga's stock size is 185/65R15. Are you referring to Ertiga or a different car?
AFAIK, it is not advisable to run different tyre sizes in ABS+EBD equipped vehicles as it could potentially lead to unexpected bahavior while braking. The OEM tuning and configuration in the ECU would be assuming same tyre size and hence not sure how the behavior with different tyre sizes would be in case of a scenario where ABS kicks in.
zenren is offline
Old 28th January 2013, 07:56   #50
Thanked: 205 Times
I am referring to Verna Fludic 1.6 CRDI, stock 195/55/R16. Seems like that I have to wait further to replace all four. Have done 27k on stock tyres till now.
Old 29th January 2013, 11:57   #51
ultimatechamp's Avatar
Thanked: 165 Times
Hi All,
Please note the thread title before posting. It is evident you have joined Team BHP in 2005. Being an old member, you should be aware of posting guidelines, before asking for Verna tyres in Ertiga tyre upsize thread !!!
ultimatechamp is offline
Old 29th January 2013, 12:12   #52
kpzen's Avatar
Thanked: 1,882 Times
Hi All,
Be it any passenger car, all four tires should have the same specs.
Mixing two different sizes is not advisable.
kpzen is online now
Old 29th January 2013, 13:08   #53
zenren's Avatar
Agree for Front Wheel Drive cars. Some RWD cars might need different tyre sizes in front and rear for better/safer handling.
Even the Nano comes with two sizes for front and rear for the same reason.
zenren is offline
Old 29th January 2013, 14:01   #54
kpzen's Avatar
Agreed.
Manufacturer's specs are always reliable.
What i meant, is, getting 2 different sizes as an aftermarket fitment is not advisable.
kpzen is online now   (1) Thanks
Old 21st September 2013, 07:58   #55
kailashnj's Avatar
Thanked: 384 Times
I am looking to change the tyres for my Ertiga to 205/60 R15. Which are the best tyres in this size, bridgestone MY 02 or Conti or Yokohama DB, please help.
kailashnj is offline
Old 23rd September 2013, 23:21   #56
drkritik's Avatar
Thanked: 41 Times
I bought Hankook 205 / 60 R15 tires Excellent road grip. ( Durability long term issues unknown)
The ride quality has improved considerably. So is cornering abilities. Feels rock solid road grip with lots of confidence boost.
Tire noise is slightly more than usual but not bothersome. They're cheaper than Yokohama. Recommended from my side.
drkritik is offline
Old 26th September 2013, 01:03   #57
kailashnj's Avatar
Thanked: 384 Times
How much did you pay for the Hankook tyres and what was the buy back offered to you.
kailashnj is offline   (1) Thanks
Old 26th September 2013, 07:04   #58
drkritik's Avatar
Thanked: 41 Times
I got 3200 per tyre and 3500 for Stepny, for Stock tyres
had to pay 11k including Wheel balancing and alignment.
I was in a hurry didn't bother much on bargaining.
drkritik is offline   (1) Thanks
Old 29th September 2013, 18:18   #59
Thanked: 165 Times
Can you please post pictures of your Hankook tires. I was of the opinion that Hankook tires are for large SUVs and are available in the plus 16 inch category only.
Old 21st April 2014, 14:42   #60
Prodigy07's Avatar
Thanked: 639 Times
Tyre Experts - What's the best tyre upgrade for Ertiga VXi? 195/60 R15 (or) 205/55 R15 (or) 205/60 R15? I know Michelins are the best for ride comfort. The Michelin Primacy LC on my Ritz is excellent but doesn't have an interesting tread pattern.
Prodigy07 is offline
