Old 8th October 2011, 16:07   #1
Tassem's Avatar
Thanked: 1,448 Times
Adapter for Weird Lug Nuts
Hi All!
It's been quite a while since I started looking for an adapter that can help me open these lug nuts. Does anybody else have the same one on your car? Can someone help me find one? I just want to get rid of these and get the allen key type since they're much more commonplace.
I guess these are called Boxer nuts. There are 6 grooves on them.
Tassem is offline
Old 8th October 2011, 16:36   #2
Thanked: 568 Times
Re: Adapter for Weird Lug Nuts
That's something very unique and anti-theft design! It is ensured that no matter what happens, very few thief will carry a socket to open such a lock nut.
dip27in is offline
Old 8th October 2011, 22:04   #3
Tassem's Avatar
Forget thieves! Even full fledged workshops don't have the adapter for this nut! There lies my problem!
If I can find an adapter, I'll retain these.
Tassem is offline
Old 8th October 2011, 23:51   #4
Tejas@perioimpl's Avatar
Thanked: 9,764 Times
Google it and you will find a lot of vendors selling them. Or else take one to the local toolers' and he will make one for you.
Tejas@perioimpl is offline   (1) Thanks
Old 9th October 2011, 00:31   #5
Tassem's Avatar
I tried google. Most of the high security lug nuts are the allen key variety.
They type I have are called Spline nuts or Boxer nuts. But the websites that do have them are the chinese variety and haven't replied to my emails.
Do you know anyone in Bangalore who can tool a suitable adapter?
I really appreciate the help!
Tassem is offline
Old 17th January 2012, 09:24   #6
Thanked: 108 Times
Managed to get Boxer nuts Key or technically 6 Spline Drive Lug Nut Key? Incidentally, which brand of wheels are you using?
6 Spline Lug Nuts & Key
A sample from the Net.
The male 12 splines are used to remove the VW seats - I have only those with me. Many splines are available in India but you may have to hunt for your specific size. The normal spline nos are 6,7,8 & 12.
Please keep us informed.
basky is offline
Old 17th January 2012, 09:33   #7
arindambasu13's Avatar
Thanked: 2,558 Times
Recently I had to change the wheel nuts when I changed to new alloys on my Swift. the OE nuts, though they fitted, the bolt spanner did not work since the nut grooves were too small to accomodate the spanner head. Hence I changed the wheel nuts, and the set of nuts came with an adapter which can be fixed to the head of the normal spanner. Problem is, I need to be very careful not to lose that adapter (which is quite small in size). If that is lost, then I would not be able to take off the wheel in case of a puncture.
My question is, where can I buy that adapter separately (as a spare one). Would I get it on SP Road/JC Road?
arindambasu13 is online now
Old 17th January 2012, 09:41   #8
rjstyles69's Avatar
Thanked: 845 Times
Most allloy dealers would have it and yeah JC road is your best bet if you loose one. Ask for allen key bolt when on JC road, you say adapter and they might show you something else.
rjstyles69 is offline
Old 17th January 2012, 09:51   #9
Thanked: 81 Times
You should be able to find what you need here nut keys | eBay
If you don't see a seller that will ship to India then you a better of buying locally (or you could use a service like iccworld.com).
CrackedHead is offline
Old 17th January 2012, 11:20   #10
sgiitk's Avatar
Thanked: 4,808 Times
I doubt it. These are 'security keyed' and may have to be just rotated using a Mole Wrench or some equally drastic tool. Also, these may even be hardened steel, so may be tough to drill out.
sgiitk is offline
Old 17th January 2012, 12:01   #11
Thanked: 325 Times
Hope this 'special' lug nuts are of good quality and not the typical low cost ones which rust easily and create a mess. Please see the following thread
http://www.team-bhp.com/forum/tyre-a...-lug-nuts.html
I recommend only OEM wheel nuts with a long-neck adapter!
@arindambasu13, hope your got quality lug nuts (cost some hundreds +), and not free ones thrown in by alloy dealer.
lancer_rit is online now
Old 18th January 2012, 08:51   #12
Thanks. I will probably take along the adapter itself and show it to them so that there is no confusion whatsoever
Nope these are not low cost or free ones at all. I spent a pretty penny on the alloys so I made sure that the nuts themselves were also of good quality, and did cost me close to 1k (set of 16 plus adapter). Plus these were from Madhus, so I doubt they would be of inferior quality anyways.
However, from the referred thread it appears that there have been complaints for these after market nuts. Any idea where I can get the separate spanner and adapter (the long neck one) which will allow me to use the OEM wheel nuts (I have retained these with me)?
Old 18th January 2012, 09:43   #13
Thanked: 325 Times
Well, then you should be fine since these would be high quality aftermarket lug nuts. The ones I had on, were put on by Sai Iyengar (also a very big tyre dealer) for free when I bought alloys from them - I had no clue what to expect at the time, and trust me, the cheap ones are so shiny when new, I couldn't think of any issues. In any case, just inspect after 6 months and 9 months, and you're reassured.
Good that you retained your OEM lug nuts, I had to buy a new set :-(
Long neck adapter, I requested Lancer A.S.S. and they got one for me for a couple of hundred (IIRC). You should be able to find on JC road etc, I guess.
Old 18th January 2012, 09:59   #14
sgiitk's Avatar
A correction. A lot of these security lugs are Mild Steel so can be cut off. In fact I came across an advisory that be gentle with these
sgiitk is offline
Old 18th January 2012, 10:18   #15
Either ways, from what I see it would be better to switch back to the OEM nuts. Last thing I want is for the nuts to start rusting. What should I ask for on JC road- wheel nut adapter? And is Taparia the brand?
