Old 21st May 2009, 00:03   #661
Gill's Avatar
Thanked: 16 Times
I am not alloy fan,would stick to silver rims(I love them).what about height 14 or15?
Gill is offline
Old 21st May 2009, 00:15   #662
karankapoor's Avatar
To fit a 195 tyre on steel rim you will need a 6j rim that you will get only in 15", i don't have idea about 14" steel rims with 6j.
When you are spending so much on tyre why not buy alloys, swift with alloy looks really good. Buy the what is the color of your swift ?
karankapoor is offline
Old 21st May 2009, 00:22   #663
Gill's Avatar
Thanked: 16 Times
I have white swift,I prefer rims to alloys.Thanks for the info KK, appreciated!
Would look for carolla rims and get a 15".Is S-drive available in 195-60-15?
Gill is offline
Old 21st May 2009, 00:31   #664
aerohit's Avatar
Thanked: 989 Times
To all swift owners.................
Putting anything more than 185 tyres (globally accepted suzuki spec) on a car with 2 digit Hp isnt the best idea.
Car feels much heavier, power loss can be felt, steering feels heavier... when compared to driven on factory 165 tyre car. Probabaly effects your mileage and pickup also. You are not going to go faster - you are going to become like a ROAD-ROLLER (see my icon on left hehe)
If you believe in "show" then go for it, and keep in mind, reducing the profile means reducing the rubber, hence more bumpy ride = more rattles, more wear/tear to suspension components.
185 is an all rounder, comfort + performance
I am not specifically talking about 195...I am just trying to say too much is not necessary...like some people putting 205 + and so on.... Also 205 type tyre may damage your Fenders, as there wont be room left for suspension travel
aerohit is offline
Old 21st May 2009, 00:52   #665
Gill's Avatar
Thanked: 16 Times
Is there such a drastic difference in 195 and 185?
Plz suggest Tyre in 195-60-15 profile!If it's the right profile?Low road noise would be a high priority.
Gill is offline
Old 21st May 2009, 00:59   #666
I agree with aerohit on some points like bumpy ride,mileage but on the other hand you get stability which you don't get with 165 they are total waste, we have many bhpians who are running their swift on 195/205 and i think even on 215 with no problem ask lbm he is running his swift on 17inchers with that black tape on.They all are happy with their ride.
If you are so confused why don't you test drive a swift with 15" rims on 195/60 tyre and then decide.
Old 21st May 2009, 01:12   #667
Gill's Avatar
Thanked: 16 Times
Finding a swift in Chandigarh with 195-60 would be quite a hard work,to be honest Karan!
I am not confused,will be opting for 19/60/15,suggest a good tyre is this profile.
Gill is offline
Old 21st May 2009, 01:19   #668
there are many available in that size, Michelin/Yokohama/Bridgestone they all have some really good pattern and are reliable chose from any of these.
Old 21st May 2009, 10:06   #669
DieselFan's Avatar
Thanked: 259 Times
This is not true. when increasing the tyre width on the same wheel, profile does get reduced but not the tyre thickness. IMHO it will have no effect or ride/rattle or suspension components. All that will get affected if you increase the Dia of the wheel itself.
DieselFan is offline
Old 21st May 2009, 14:20   #670
anshurao's Avatar
Thanked: 85 Times
Originally Posted by _abhishek View Post
@anshurao,
I am using 15" AVA alloys with Yoko S drive.
Which combination are you using?
15" Lenso Samurai with Yokihama S-Drives.
anshurao is offline
Old 21st May 2009, 14:56   #671
ram_hyundai's Avatar
Thanked: 53 Times
Whatever size you upgrade try to keep the perimeter of the tyre same,Else it would have an effect on the mileage,power etc.Power in the sense torque.The speedo readingg would also change as the perimeter changes.One more way to use this factor is that suppose the perimeter is lesser then you can feel an increase in the low end torque ,and if the tyre size increases the final speed also tends to increase.Mileage of the car also increases as the DIA increases.
ram
ram_hyundai is offline
Old 21st May 2009, 15:28   #672
When you upsize you wheels that means you are changing the main thing related to suspension, upsize do cause some problem but 1" will not make a big difference and as far the ride quality is concerned when you upsize the rim by 1" you decrease the side wall by 20/30 mm, the sidewall works as cushion so lesser hight (sidewall) means more bumps.
Old 21st May 2009, 16:27   #673
Gill's Avatar
Thanked: 16 Times
Yokohama S-drive is not available in 195/60/15 profile,A-drive is available.Michelin is bit expensive then A-drive!Does Yokohama was a website for products available in India.
Gill is offline
Old 21st May 2009, 16:30   #674
Technocrat's Avatar
Thanked: 2,701 Times
My friend will be getting delivery of his Swift VDi on Saturday. Now he wants to upgrade the stock tyre. He doesnt want anything fancy just something which is better than the stock JKs & which is available easily.
I understand that following sizes are suitable without compromising on mileage (actually VDi that should not be a problem )
185/70 R14
185/60 R14
He doesn't want to spend more than Rs 500 per tyre after exchange (wish to head to tyre shop straight from Showroom.)
Please advise on which make to choose, Thanks
Technocrat is offline
Old 21st May 2009, 16:49   #675
tsk13's Avatar
Thanked: 361 Times
Yokohama as of now has no India specific website but you can contact them at:
Yokohama India
517 & 519 Antriksh Bhawan, 5th Floor, 22 Kasturba Gandhi Marg,
New Delhi -110 001, INDIA
Tel: +91 (11) 6609-9559, Fax: +91 (11) 6609-9558
Email: customercare@yokohama-india.com
Tanveer Singh
tsk13 is offline
