Old 29th May 2008, 21:29   #211
rippergeo
Posts: n/a
I didnt know that the 14 inch OEM steel rims could take 195/65...or, am I getting the wrong message?
@kpzen- would you please confirm that? if it is true-I'm changing up to that size ASAP
currently running 185/70 R14 potenza G3s(love them)
Old 29th May 2008, 22:03   #212
kpzen's Avatar
Thanked: 1,878 Times
Ripper
I have seen all kinds of weird tire sizes on Swift with stock rims...
Most of them are all show and no go...
Since the stock rims are 5j(width) the best upsize for Swift on stock rims would be 185/70-14..
195/65-14 is not recommended on 5j rims, u need minimum 5.5j.. 5j may or may not work well(depends on various parameters of the car) and if doesn't work well the handling characteristics of the car will go for a toss...
Since u are diesel torquaholic head i don't think it would be a good idea...
kpzen is offline
Old 29th May 2008, 22:07   #213
rippergeo
Posts: n/a
Ripper
thanks kp- for a moment i thought i had made the wrong choice. i was actually starting to plan how to wear out my current set of tyres quicker.you saved my G3s. i'm staying with 185s
Old 30th May 2008, 09:39   #214
garyjacob's Avatar
Any reason why i shouldn't go for the 205/60/r14???
garyjacob is offline
Old 30th May 2008, 09:52   #215
kpzen's Avatar
1. Almost 3% difference in circumference.
2. Speedo error.
3. GC reduces by almost a cm.
4. What are the good tire options in that size?? I think only ES100 is available.
kpzen is offline
Old 30th May 2008, 10:19   #216
garyjacob's Avatar
What do u mean by quite old???are u referring to the tread pattern or that its not a good tyre anymore?I have read in the forums that bridgestone has sidewall bulging problems now.
Originally Posted by revved_up View Post
I think this ^ should help you.
regarding ES100 i would not suggest to go for it as it is quiet old.
Bridgestones are good but wear out early.
I would suggest you to go for XM1+ 195/65 r14.
Old 30th May 2008, 10:21   #217
garyjacob's Avatar
Can i use spacers to make the 195/65/r14 tyres to get a broader look???
Old 30th May 2008, 18:36   #218
yzfrj's Avatar
Thanked: 142 Times
I've seen the local Maruti Service guy using 195/65/14 in his VDi, he is using stock alloys seen in the Swift Zxi.
I asked him if there is any issues and he said its running fine.
He does long drives and said did't face any issues.
He also advised its better to go for the stock alloys.
But you guys are correct 195 does need 5.5
I'm not the expert but
just FYI...!
yzfrj is offline
Old 30th May 2008, 20:31   #219
Thanked: 86 Times
doesnt 195 need 6.0 ....?
rana_kirti is offline
Old 30th May 2008, 20:34   #220
Thanked: 86 Times
Hey guys,...
which of the above mentioned tires is better in terms of...
1.Comfort
2.Grip
Tyres will be used on mumbai Roads
i hope they get better in the near future....
peace...
rana
Old 30th May 2008, 20:39   #221
revved_up's Avatar
Thanked: 792 Times
195 on ZXI stock alloys is ok, even Jaggu is using it on his VDI AFAIK.
He is asking about 195 on stock steel rims.
revved_up is offline
Old 30th May 2008, 21:02   #222
rjstyles69's Avatar
Thanked: 845 Times
And I thought spacers were used to stop the wheel arches from scrapping the tyres.
rjstyles69 is offline
Old 31st May 2008, 00:12   #223
Thanked: 86 Times
Hey guys,...
Yokohama A Drive vs. Michelin Energy XM1+
1.Comfort
2.Grip
Tyres will be used on mumbai Roads on a swift VDi
peace...
rana
Old 31st May 2008, 00:53   #224
iraghava's Avatar
Thanked: 268 Times
No, don't even go there. You don't know how well engineered the spacers are & what effect they are going to have on your car's handling. And making them give a broader look will almost certainly mean your tyres at the rear could be scraping the arches in bumps. Not recommended at all.
IIRC stock alloys are 5.5J & hence there is no problem with 195's on them.
No, 5.5 will do just fine.
iraghava is offline
Old 31st May 2008, 19:51   #225
Thanked: 86 Times
hi iraghava,
thanks for the reply to the post... "doesnt 195 need 6.0 ....?"
yesterday i went to tyre market to look for rims... and all of the rims in 14" size were 6.0J size.
i'm putting 195/65/R14 Yoko A.Drive on my swift vdi (ABS)
which is the optimum size for the above tire size? 5.5J or 6.0J ???
will the tyre upgrade affect the functioning of ABS ?
thanks.
Rana
