Old 5th November 2015, 10:23   #1996
Sheel's Avatar
Thanked: 14,684 Times
Re: Maruti Suzuki Swift : Tyre & wheel upgrade thread
Do look at MRF Z.L.O's if he is ready to upsize to 195/60 R15 from the stock 185/65 R15 just like what I have done.
It would be a good idea to update this thread with your experience. I haven't read the entire experience at one place, so...
Sheel is offline
Old 5th November 2015, 10:55   #1997
Thanked: 21,423 Times
I have broadly put the links that'll take you directly to the posts where the main issues are highlighted.
1) Tyre Purchase:
Link to post of Purchase
This link contains all the data pertaining to the tyre purchase and fitment.
__________________________________________________ ___
2) Humming Noise Reported:
Humming noise
This post contains the humming noise that I have encountered between 40-50 kmph.
__________________________________________________ ____
3) Tyre Problem - Humming Noise:
Tyre is at fault - Humming Nosie
Visited one of the best wheel alignment guys in Hyderabad and asked him to analyse where it was found that the tyres are at fault.
__________________________________________________ _____
4) MRF's first response to the complaint filed by me:
MRF's first repsonse to complaint filed by me
The first response by MRF's team from Chennai when I registered a complaint on their website.
__________________________________________________ ______
5) Humming noise analysis by MRF's Technical Executive:
Analysis by MRF's Technical Executive
Here is the analysis and outcome that was carried out by MRF's Technical Executive.
6) My R&D on the humming noise:
My R&D on Humming noise
I interchanged the wheels from another Swift just to zero down on whether the tyres are faulty or something wrong with my car. OUTCOME: My car is good but not the tyres.
a4anurag is offline
Old 26th November 2015, 19:47   #1998
scarecrow's Avatar
Thanked: 160 Times
Hi All
Just upgraded the tyres on my Swift Vxi (2010) model to Michelin XM2's. The stock JK tyres served me well, but had become slightly hard and were loosing grip under spirited acceleration and turns.
Upgraded from 165 to 185's, so still getting used the slightly different driving feel.
Had 2 queries
  1. Is there a certain no of kms to scrub / run-in new tyres?
  2. What tyre pressure do i need to maintain for this tyre? The dealer mentioned 32, but somehow feel its slightly higher.
scarecrow is offline
Old 27th November 2015, 13:50   #1999
khoj's Avatar
Thanked: 1,287 Times
Tyres will bed in between 500 to a 1000 kms
The air pressure sticker on the bottom of the A pillar gives the air pressures for both the 165 & 185 profile tires, refer the same for correct values.
Originally Posted by scarecrow View Post
Had 2 queries
khoj is offline
Old 29th November 2015, 15:14   #2000
scarecrow's Avatar
Thanked: 160 Times
@khoj - thanks for the response
Old 27th December 2015, 20:06   #2001
Thanked: 110 Times
Guys
Need an urgent help from you guys... I have been using Yokohama A Drives 195/65R14 which has run 64000kms in my 2010 Swift vdi. Now its time to change and I was looking for 15 inch or 16 inch ..
I am offered I20 Asta 16inch Diamond cut alloys with Apollo Alnac for 31000/-. What is your opinion guys? Shall I go with the purchase?
Dilip Kumar V
dilipkumar7278 is offline
Old 28th December 2015, 02:58   #2002
khoj's Avatar
Are the PCD and the offset for the Swift and the i20 same?
If yes then it is a commercial decision
and
If they do not match, then walk away
Dilip Kumar V
khoj is offline
Old 8th January 2016, 19:04   #2003
Lij
Thanked: 252 Times
I had some queries on the zero plus upsize for Swift VXi. Planning to change from OEM 165/80-R14 to 185/70-R14 (Michelin XM2).
1. Since the Swift VXi rim width is 5", will the 185/70-R14 tyres bulge out of the rims, tyresizecalculator.com says that 185mm is the maximum 5" rims can take while the ideal is 5.5 to 6"?
2. Should I continue to maintain the same tyre pressure as is recommended for OEM tyres?
3. There will be some speedo error, but will it also affect the distance calculated by the odometer since both are inter-related I guess?
Lij is offline
Old 8th January 2016, 20:32   #2004
Darth Sid's Avatar
Thanked: 119 Times
1. Though these tyres will be most comfortable on wider rims, 5" is also OK. I am attaching some pictures of my '15 Swift VXi when I got the same tyres you are looking at. I was very happy with the upgrade as the car became more stable. However, when I later purchased aftermarket alloy wheels (6 inches wide, one pic attached) handling became somewhat better with those tyres.
2. I continued to maintain the same pressure. No issues observed.
3. Very minor. Not enough to be noticed but then I didn't do any detailed testing.
Maruti Suzuki Swift : Tyre & wheel upgrade thread-1452265141288.jpg
Maruti Suzuki Swift : Tyre & wheel upgrade thread-1452265225657.jpg
Maruti Suzuki Swift : Tyre & wheel upgrade thread-1452265240472.jpg
Maruti Suzuki Swift : Tyre & wheel upgrade thread-1452265309282.jpg
Darth Sid is offline   (1) Thanks
Old 18th January 2016, 12:20   #2005
swift_guy's Avatar
Thanked: 254 Times
Don't know where to post this query, but posting here as the car in question is a Swift.
The spare tyre (used for first 2k kms, before 2 punctures happened) has some rubbery (but hard) substance coming out from the point on sidewall where 2 punctures were found earlier. It has been almost an year and 8k kms since I checked that tyre (checked it yesterday while cleaning the boot area) and it looks like the material which is used to repair punctures. It is brown-red colour and has come out like toothpaste comes from a tube.
Do I need to show this to a tyre shop or is it normal? I will post a photo in some time.
swift_guy is offline
Old 18th January 2016, 15:36   #2006
Lij
Thanked: 252 Times
Got the below quotes from dealers (includes WB and WA) for replacing my Swift tyres. One of the dilemmas that I am in is should I go with 185 section tyres or stick to 165 ones since I might be replacing my car end of this year or next year so is it worth spending around 3.5 - 4K more?
185/70 R14:
Bridgestone Turanza - 4500/- each
Michelin XM2 - 4600/- each
165/80 R14:
Bridgestone B290 - 3500/- each (budget tyres but are these better than my current GY Duraplus?)
Michelin XM2 - 3900/- each
Yokohama Earth1 - 3000/- each (first thought I heard it wrong and checked again, didn't check the manufacture date)
Also would like to know if there are any freebies available, all dealers said no freebies from the manufacturer. For Michelin there is some lucky draw for which I need to register online.
If its the 165 section I would mostly go with XM2 since Turanzas are not available in that size, if 185 then I am a bit confused between the 2.
Lij is offline
Old 18th January 2016, 15:56   #2007
Thanked: 1,959 Times
If the tyre has 2 punctures in the sidewall, put a tube inside the tyre and use it only as a spare all the time. Whenever you need to use this tyre, use it only till you get to the next puncture repair shop.
Had you put any puncture sealing liquid in the tyres in past?
Rahul Bhalgat is offline
Old 18th January 2016, 16:57   #2008
swift_guy's Avatar
Thanked: 254 Times
Have a look at the pictures below. Actually the punctures were very small and not very far apart, the sticky thing has come out from those 2 punctures and has almost covered the portion between it. I gave it to the puncture repair guy and didn't inspect what he was doing; but the tyre looked normal after repair.
I just need to confirm if this is the puncture sealing liquid only or not. Is there any way to cure this without adding a tube?
Maruti Suzuki Swift : Tyre & wheel upgrade thread-1453116412281.jpg
Maruti Suzuki Swift : Tyre & wheel upgrade thread-1453116422083.jpg
Old 18th January 2016, 18:15   #2009
Darth Sid's Avatar
Thanked: 119 Times
That brown stuff is the cold mending rubber strip used to repair punctures in tubeless tyres. I am surprised it works in the sidewall. This tyre may not be as reliable as a regular one with only tread punctures. Tube might be the safer alternative. In any case it seems this tyre might only be suitable an emergency only spare. Others should comment on this too.
Old 18th January 2016, 18:19   #2010
swift_guy's Avatar
Thanked: 254 Times
Yes I am using it as spare only. Can I remove this strip with some tool and get the tyre repaired again by some more experienced person?
My guess is that this brown strip is expanding due to heat (or with time) and thus came out. I was thinking of removing it entirely by a plier and getting the tyre repaired properly.
