@ramkya1 @mathranik @akroy @akbaree @ravibhat @jigbarai @muralisk @Indian Ranger @milindajp @KRRaj @kannan666 @sami316 @emkay456 @kiren @maddy42
Thank you all for your comments!
Originally Posted by ramkya1 ...Remember, 20 years back when we went for our honeymoon, took a train from Mysore to Goa, took 24 hours to Vasco on Dec. 22nd. There was this one compartment which was full of honeymooners, compartment gets detached and attached to 3 different trains on the way, last one at Arisikare and goes over Doodsagar falls, have photos of it in an album somewhere!!!! Brings back lovely memories, thanks for starting the thread....Wonder if that train runs now???? |
Ramkya Sir, I Googled around to check out the trains that used this route and looks like this is a fairly busy route even if we consider only passenger traffic. (Link below). I think the Mysore-Goa trains have been discontinued.
Castle Rock Station | Cleartrip Quote:
Originally Posted by akroy ...How much distance did you walk on track? |
@akroy; The distance between Castlerock to Dudhsagar is 14 kms. Ideally it should take around 3 hours to cover the distance. But we took 5 hours; since we stopped for a leisurely lunch, took a 30 minute break at the smaller waterfall and paused at a couple of places for pics etc.
Originally Posted by ravibhat ...Castle rock name is because of lot of castle type rocks around that area mostly named by British. I heard Jungle lodge people conduct safari too in that area although animal spotting is limited. Rafting is famous activity there. Its advisable to visit that area before Feb end. (summer is hot) and avoid rainy season. Best time to visit is October to Feb so you visiting in perfect time.
Do trekking next time around Kali river around Kaiga-Ganesh Gudi-supa area although there might be security issue since that area has lot of reservoirs.... |
Yes, Ravi; even I heard the same comment when we were there... that the JLR jungle safari may not be great due to very limited animal sightings.
As for rafting, normally water is released from the dam into the river every weekend and the rafting trips are timed accordingly. However there seem to be some changes in the release schedule and even the JLR folks were caught unaware. Water had been released the previous evening due to a spike in power-demand and the weekend rafting had to be canceled.
Since rafting is a good money-spinner for JLR, they will re jig their schedules as per the new release times. Anyone headed that way should confirm with JLR the evening before the trip to confirm that rafting is on. (The JLR folks had tried to reach us the previous night, but we were out of phone range.)
The JLR folks also organize light treks/ nature-walks.
Originally Posted by jigbarai ...However, is it safe to walk thru train tunnels ? |
As far as the train is concerned, yes; there is space on both the sides to stand aside and let the train pass. However you have to carry a torch to ensure that you don't step on any snakes that may have taken shelter inside the tunnels. Also, the gravel between the sleepers may have been removed during the maintenance work, so need to walk carefully.
Originally Posted by KRRaj ...What is the best time to go? I heard it as December, but also was told that too many tourists come and it would be crowded. Is Jan a good time to go? |
As @ravibhat has mentioned in his post, the best time would be between Oct to Feb, which is a pleasant season. If you do the trek during the rains, you can catch the falls at its best. Water levels steadily decrease from the June / July peak.
December may be a bit crowded due to the holidays and the year-end tourists, but the area is quite spread-out, so no problems.
Just remember to ask at the Castlerock station and also reconfirm at the Dudhsagar station about the trains that stop at DS. If you miss the last train, there are no night-stay / food options at DS. I don't think there is any proper road access / alternative transport facilities from DS station either.
Originally Posted by kannan666 ..And are the tunnels wide enough to go through in case a train passes by when you are actually in the tunnel ? |
Yes, Kannan; there is gap on both sides. There was repair work going on inside a couple of tunnels and the workers would just stand aside and let the trains pass. But it gets very noisy inside the tunnel!
