Originally Posted by BlackPearl Congrats on taking the Scorpio to Sandakphu and Phalut. The people there should no longer say that other vehicles cannot do this stretch after two Boleros and one Scorpio did it . Great narration and pictures. As you have mentioned, the ascents are quite easy compared to descents. This threads reminds me to put up the pictures from our last journey to Sandakphu in February this year. |
Thanks. Do put up the pics, although I had seen Ritik's version of the pictures of a snow filled Sandakphu where your white Bolero merges into the scenery. Can't really imagine how cold could Sherpa Chalet have been that time.
Originally Posted by premjit Awesome, detailed and at times very scary travelogue. Little Anoushka looks super excited in every pic. She's surely well set to be a chip of the old block as well. |
Thanks Premjit. Lets see what the future has in store!
Originally Posted by himadrimondal Well I would salute your Mom and Dad for accompanying you on this trip.
This is seldom seen, infact the mental determination in them seems unparalleled.
Rest of the trip is a beautiful route, never went up to Sandakphu or Phalut but as per my birding interest,
did go to Sangalila National Park a couple of times.
Guess what, I did this in my good old Tavera, a 2WD.
Was not a TBHP member in 2009, |
Thanks Himadri Mondal. Your passion for birding is applaudable, will post the picture of a bird that we snapped for help with identification. Kudos for being able to take up your 2wd Tavera upto Sangalila and Neora valley NP's. Am anticipating looking out for your exploits with a 2wd Tavera to Sandakphu in a big way.
I am not sure if it was your Tavera, but at the Sangalila National park entry, they did mention Tavera's, 2wd Sumo's having crossed the point.
Infact on our own drive itself, I was thinking to myself about how doable will this journey be on a 2wd. I also had the option of switching back to 2wd mode to find out, but did not, as even if 2wd takes us there, 4wd has other significant benefits.
4WD's like the Scorpio/Bolero/Safari/Fortuner have a low ratio/range gearbox. This is an additional reduction gear (say for example of a 2.38:1 ratio as in the Scorpio). This multiplies the torque likewise in each gear, at the same time reduces the idle rpm driving speed by the same ratio for the same gears (in comparison to the usual high ratio 1:1). What this allows is a very very slow but steady progress through the rocky surfaces without need to modulate either the accelerator or the clutch. The low speed allows you to drive slowly on the rocks rather than making the suspension work overtime and sacrifice the suspension components. The slow movement also does not require clutch usage hence clutch is also saved. Lastly no stress on the feet operating the pedals, because they are mostly off the pedals. Besides, on some of the hairpins after Gairibash, the steep turns are strewn with loose and sharp rocks, you cannot afford to go over them at even 10+ kmph (whereas a 2wd or a 4wd without Low ratio, will require substantial momentum/speed to make it through, like the local Landy's do). Thats where the low-ratio helps by moving at a snails pace allowing enough time for the suspension/tyres to play out and flex or even choosing the right path quite precisely without bouncing about.
Here is something I had written on another thread on going with a 2WD on this sort of terrain, with a few modifications
The only collaterals for going with a 2wd are
1> Higher momentum required, necessitating higher speeds and subjecting the suspension tyres (and in some cases the underbody - if there is bottom scraping) to higher speed on rocky terrain.
2> Tyre slipping - apart from 1 above you would require the only driven wheels to claw, slip against rocks to gain traction, subjecting the driveline, the suspension at the driven end and the driven tyres to stress. For a 4wd, that drivetrain, suspension and tyre stress is distributed front and back
3> Clutch slipping - to counter 1 and 2 above , you would need to keep the engine revved right up, to prevent stalling, speed control through clutch.
4> When the going gets very steep, a 2WD is less likely to make it, even if it does, it will need to speed up and take the hairpins at a significantly higher speed.
In comparison, on a 4WD, simply switch onto 4WD-Low and just stroll slowly a little off the idle rpm, as if nothing happened!! Just enjoy the scenery!
Originally Posted by himadrimondal The one that leads to the right takes you to Neora Valley Base camp, from where the 3 day trek starts.
Do drive it sometime and I am sure you may exceed the adrenaline rush you had while climbing Sandakphu. I did that in my Tavera too. |
You mean driving up the 3-day trek route from Neora Valley BC? Where does it reach?
Originally Posted by himadrimondal How was Kolakham, did you get to see any birds?
My personal experience is horrible, I too went down there in 2012 but was not offered a room as I had not booked.
Did not see any signs of birding and felt guys were just trying to promote the place in the name of birding.
It took me almost an hour to reach from Lava but only 20 mins to climb up, again in my Tavera. |
For us the appeal for Kolakham was not related to its birding prospect. No one pitched in that aspect as well. We did see some real snaps taken by a family friend and they had been fortunate enough to be able to have multiple Red-Panda spottings that too on the main dirt road. Infact the Panda's even posed for photographs! (Note: we are not talking Puri here).
Kolakham to us, as I mentioned was an intermediate destination while we moved from the west to east (to the Dooars). We chose Kolakham as it was near Lava, a point we were proposing to drive by. The Panda spotting definitely played a part in its selection.
From a birding perspective, Kolakham itself will not be too good because of the settlement there. But a km or so on either side of it, one could spot birds, but whether you would have the proper setting to photograph them is a big question.
Originally Posted by himadrimondal The stunning part of your trip is the timing of your photographs.
Steep inclines or declines, you have managed to stop and shoot.
An awesome set of photographs from a real traveller, superb to say the least. |
Most "road" snaps were taken by my father on his camera. Besides the going was so super slow, we had adequate time to take snaps even while moving!
