Moderator note: Back to back posts, please use Multi Quote [Quote+] instead. Thanks. Quote:
Originally Posted by 4x4addict @vipin: Unless you are going to go off-road regularly, do not put Bighorn or any MT Tyre. They are noise, hard & unsafe on roads. Keep a set only for off-road use.
265 is too big and will stress the already weak front axle/steering components. Your best bet is to go for stock size or if you want bigger go for 245/70/16 (Ford Endeavour Size) or 245/75/16 (JK Elanzo). Beyond this is too big for your original rims. |
@4X4addict. Thank you for replying. I must confess the primary reason for my considering the Big Horns is vanity. I just love the way they make the Thar look. Now having said that, what would say that the difference between an MT and an AT Tyre, in terms of safety, huge?
Or would you say its a marginal difference?
Also, the wear and tear that you warn me about, in the front axle/steering components, have you seen or experienced it in another Thar in the past?
Yes, the wider the tyre, more the surface traction and stress, but I want to ascertain if the trade off between looks and the wear and tear is a fair one.
Originally Posted by obaidhakim @vipin: I was in the exact same position about a year back as you are today. Coincidently I was considering the exact same tyres that you are considering and chose to go for the maxxis bighorn. And man am I glad!
The bighorns are really good tyres, fairly good performance on road and fantastic off-road performance. In fact I was quite pleasantly surprised how well they performed on road, even in the monsoon. Yes they are a bit noisy than what you would prefer, they are also a little stiff as compared to the stock tyres adding to the already harsh ride, but then jeeps were never supposed to be practical.
But let me tell you they will never let you down ever. They are a dream off-road, self cleaning and excellent sidewall protection. Even on the road they they manage to get everyone's attention in a jiffy. Hugely complement the look of the Jeep.
What's more they fit right on to the stock wheels, thereby saving the moolah to be spent somewhere else on the Jeep.
I have done about 14K kms on these tyres by now, 80% road had only one puncture and a fantastic drive everyday.
One of the best investments that I have done on my Jeep. |
Thanks obaidhakim. I'm happy to see your post as it re affirms what I'd love to settle with as far as the choice of tyres on my Thar are concerned.
Do you off road a fair bit? And in those times or on occasions of going over a bump on the highway at high speed, do the 762's touch the fender?
At full turning radius, do you feel that they're touching the insides of your jeep?
These along with the accelerated wear and tear that 4X4addict mentioned are my main concerns.
Originally Posted by Avigo71 Factory fitted Bridgestone are good enough for daily use & basic off roading. If you want A/T tires then go for the Geolander ATs in the same size as stock. If you fit a broader tyre than 235, then make sure it's not 70 R16. It should be less than 70 otherwise the clearance of the 'wheel arch' reduces and the tyre hits the wheel arch when the car goes in a dip or a speed breaker at a moderately high speed. I think 255/65/R16 is good.
The Bighorns are very good but you should put them only if you are 60-70% on off road terrain. Else you should put them if looks matter more to you than highway performance or money! Because they are a bit noisy, they give a bit lesser performance on highways in terms of grip & braking & also they wear out real fast on normal tar roads.
PS: I am no expert but have done a bit of research on this issue, and this is the feedback I received from experts & a few test drives I did with different tyres before settling on the 235/70R16 Yokohama Geolander AT s |
Thanks Avigo71. Yes the Geolander AT 255/65R16 seems to be the most sensible swap and the Bighorn the most desirable one, more from a "look" point of view, I agree, as 20% off roading time is the most I can expect to get.
However, I'm eager to hear from obaidhakim if he's had any issues with his tyres touching against he fenders.
If not, then getting the Bighorn might be a fair trade off of looks vs highway performance and kmpl.
