Old 19th May 2011, 10:34   #1711
Thanked: 85 Times
re: Review: 1st-gen Mahindra Thar (2011 - 2019)
Originally Posted by vj_k2001 View Post
...Can you'll also check if you'll have this problem....
Yes, It is in mine and the many Thar's I have seen. Standard Feature.
BlackRaven is offline
Old 19th May 2011, 19:20   #1712
Jaggu's Avatar
Thanked: 17,181 Times
I will follow up the stalling issue with BD Sir and Spike.
Can you'll also check if you'll have this problem.i.e the metal exposed below the rear mudguard as shown in my images.The dealership told me that this is the case with all Thars so I just need to confirm the same.If yes then this is the first place that is going to rust and we need to resolve this asap.
Vijay
Lol thats horrible! can you guys atleast get it painted. Not at all good idea to leave it like that. A 3M undercoat will be a good idea.
Jaggu is offline
Old 19th May 2011, 21:07   #1713
Thanked: 41 Times
Hey Jaggu,
Where do they do the 3M undercoat in Bangalore and how much does it cost.
vj_k2001 is offline
Old 19th May 2011, 21:17   #1714
Jaggu's Avatar
Goto one of the 3M shops, i believe there are two in town. Search here to find the details, charges will be 3-5k depending on the type of vehicle.
Jaggu is offline
Old 19th May 2011, 21:54   #1715
Thanked: 3,612 Times
^^^ Kinda inquisitive how this is happening to all Thars? I mean, is this another production defect or due to some design flaw, that causes parts to scrape against each other? Very disappointing, to say the least.
roy_libran is offline
Old 19th May 2011, 22:24   #1716
Thanked: 85 Times
Spike/Vinod/DB Sir, What is the standard warranty on Thar? Is there an option to buy additional warranty? If yes, what is the period and how much does it cost?
I am not getting concrete information from the bangalore dealership.
Thar Owners, have any one of you enquired about or purchased the additional warranty?
Old 19th May 2011, 22:38   #1717
starter's Avatar
Thanked: 930 Times
Hey Jaggu,
Here you go..
http://www.team-bhp.com/forum/bangal...ml#post2353892
Cheers,
Deepak
starter is online now
Old 19th May 2011, 22:40   #1718
Thanked: 85 Times
Originally Posted by starter View Post
IIRC I was quoted Rs.3200 for the Thar.
Old 19th May 2011, 22:53   #1719
Jaggu's Avatar
I say go for it, really worth the cost. Am planning to do it underbody and inside area on DwArF
Jaggu is offline
Old 20th May 2011, 11:54   #1720
Thanked: 13 Times
From the look of the close-up pic it seems that this is the part where they clamp/hold the body while the underbody coating is done. And once the clamp is removed, they should ideally have touched up that portion too. But, that may be asking too much from Mahindra
manualManuel is offline
Old 20th May 2011, 13:10   #1721
Thanked: 2,999 Times
In that case the omission would be symmetric, on both sides of the chassis if not at four points. Best to get it painted over. One can also try to get it done as a warranty job, as it is clearly a manufacturing defect (omission?)
Aroy is offline
Old 20th May 2011, 19:33   #1722
Thanked: 41 Times
We have located the reason for my vehicle stalling at low rpm.It was the fault of the LSPV spring.The spring is supposed to be installed at a tension length of 9.2 inches but it was 11 inches which resulted in the rear brakes locking up everytime I braked.At low rpms the vehicle used to stall due brakes locking up and later free up every when enough momentum was achieved.This also happened during cold temperatures.
I will post images of what went wrong over the weekend.....
Behram Sir...thankyou again for your timely intervention.
Vijay
vj_k2001 is offline   (1) Thanks
Old 20th May 2011, 19:50   #1723
headers's Avatar
Thanked: 563 Times
I'm just beginning to wonder if we did not have BD Sir on this forum
Sorry guys, its a genuine thought - am shocked at the hand holding required for a life style vehicle.
OK guys [my X teamie Vinod] time for a THAR V2 CRDe with:
1. Better Switchgear [I hate the current M800 ones]
2. Better LSPV springs
3. Better Suspension [enough debate has happened on the forum]
4. Better crawl ratio [optional switch on the dash]
5. Better Tyres [I mean offroad tyres]
6. Lastly, ofcourse a factory fitted AC and a decent Lockable cabin [some people call it a Hardtop]
And a ONROAD Price of 6L Maxxx.. we want to see more THARs on the road.
headers is offline
Old 21st May 2011, 11:00   #1724
rrsteer's Avatar
Thanked: 3,418 Times
I hope there was an option to do this to the whole thread :
The thread has almost acquired a pattern. A wish or criticism is made by someone, then someone jumps in to support or attack the argument and then someone come in with a totally vague description and ends it with a totally unrelated but a statement which can be described as blowing ones own trumpet, like, 'hey today I took out a xxx bhp powered xxx type modded car on my xxx jazzy colored MH-xxx numbered jeep on NHxx highway at xxx time!!'.
After this the whole process repeats again and sustains itself for time before withering away only the process to be kick started again by somebody.
(I am sorry if this post appeared to some in bad taste)
rrsteer is offline   (6) Thanks
Old 21st May 2011, 11:02   #1725
DesertKing's Avatar
Thanked: 24 Times
Originally Posted by AWD View Post
What was evident on the Board was that both MM & its Reps. were not keen on Mdi outdoing Thar. All the marketing effort was concentrated towards Thar Crdi. Di is still not available with most dealerships. Also, the BS3/4 issue doesn't help.
Yes customers want a more comfortable vehicle with better fit & finish, A.C, H.T, Lockable cabin, no niggling issues, etc. Specially at the given price, there can't be any other way.
AWD, I am from a city located in the Thar desert. We do not have BS4 compliance as a must in our city. To your wonder, the MDi is doing a very good sale here, though I have never been to the local dealer but telling you based on my observation on sighting the new Thar MDi on the roads. M&M is doing very good advertising for MDi here and almost every alternate day, you can see a advertisement in the local news paper.
I just meant to point out that it is not that all over India, the marketing effort of M&M was concentrated towards Thar CRDe.
PS :: I am among those who are waiting to see Thar MDi 4WD on the roads and offcourse to die to see her with hard top (AC can be though fitted through the dealer).
DesertKing is offline
