Old 3rd January 2014, 18:25   #8926
Thanked: 2,060 Times
re: Review: 1st-gen Ford Figo (2010)
I recently went on a 2100 Kms trip in South india. One day while driving in the hot sun with 4 adults and 2 kids and a full boot, the a/c stopped working. I had to drive with my windows open. After about half hour, it automatically became alright. This has happened twice before. ( over 2 years back)
Do I need to do anything about it?
wildsdi5530 is online now
Old 3rd January 2014, 19:19   #8927
Thanked: 1,463 Times
If everything is alright, then it is safe to assume that the ECU has switched off the AC. So is it that the coolant temperature has gone up? This can happen in crawling traffic conditions.
ramzsys is offline
Old 5th January 2014, 17:11   #8928
keshav1426's Avatar
Thanked: 181 Times
Guys
My Figo Tdci has run 24k kms. Off late, i can hear some humming sound coming from the wheels.Pretty sure from the front right side. These sounds surface at speeds of 40-60km/per especially while slowing down after the brakes are used. Kindly let me know if this might be a bearing issue or something to do with the tyres. Car is running on MRF , appreciate the help.
I have taken it to a wheel alignment station and they told me that there is slight wobble from the front tyre and their advise was to use it for another 5-10k kms and then change them. I am not so convinced with their diagnosis. I have also taken it to ford but as usual their reply was that everything is normal !
keshav1426 is offline
Old 5th January 2014, 18:26   #8929
Thanked: 282 Times
It could be a faulty thermostat that controls the AC. I got mine changed for a similar issue under warranty.
sansvk is offline
Old 5th January 2014, 20:27   #8930
Deep Blue's Avatar
Thanked: 689 Times
I too had this problem twice in Sept 2013, but unlike yours, the AC started working within about 10-15mins. During my 50k service in Nov 2013, I asked them to check and they said everything is fine. Now, since 2 weeks, again I am having the problem intermittently. The overall cooling on a hot afternoon is also slower.
I guess as sansvk said, the thermostat is the culprit.
Deep Blue is offline
Old 6th January 2014, 05:23   #8931
Thanked: 497 Times
Hello everyone!
Lately I've noticed that my Figo has started rattling a lot from the door panel area - both driver and passenger side. The rattling is not only when going over bad roads, but also happens when driving slowly or when braking. Anyone else facing the same issue? Is there a diy fix to it?
Thanks!
nishantbhatia84 is offline
Old 6th January 2014, 11:17   #8932
shuvc's Avatar
Thanked: 353 Times
My car has this problem. But the sequence is different. It has never stopped working on the run. It happens when the car is parked after a drive. And then when it's started after a while, the AC is dead. Then again it'll sometimes start working on it's own sometime later but rarely on the run. Maybe after it's parked overnight.
Between 20 and 30K kms the problem had ceased. This was after Ford serviced the blower motor. The problem recurred once again last October. Since then the AC has not been used much. I'll get the blower motor serviced next time.
QUOTE=nishantbhatia84;3336512]Hello everyone!
Thanks![/quote]
No rattles from the door panel, but the window panes do rattle a bit when completely rolled up. Roll it down a bit and the rattle disappears. Strange. I'd think it should have been the other way, if at all !
My car has also developed a nagging RHS C pillar rattle. Barring these 2, it's fairly ok.
shuvc is offline
Old 6th January 2014, 12:49   #8933
tharian's Avatar
Thanked: 8,153 Times
Originally Posted by keshav1426 View Post
Guys
It sounds like the wheel bearing for sure. To be sure if it is the tire or not, run with the spare tire on that wheel and check for the sound.
Lok of members have had the same issue of the bearing failing quite early.
It costs around 3.5k for a single wheel. If your car is under warranty, check if you can get it done under that.
tharian is offline   (1) Thanks
Old 6th January 2014, 12:58   #8934
keshav1426's Avatar
Thanked: 181 Times
Tharian
thanks, i will go get my tyres rotated and balanced, then will see if there is any improvement.
Old 6th January 2014, 14:07   #8935
sameerg001's Avatar
Thanked: 434 Times
Just gave my car for 10k service, have been given estimate of 1900/- bucks, I said no for alignment and balancing, will get it done outside.
I'll post the invoice as soon as i get the car.
sameerg001 is offline
Old 6th January 2014, 15:42   #8936
vnabhi's Avatar
Thanked: 2,395 Times
Guys,
My 16K run Figo tdci is producing a mild squeak whenever I release the brake pedal. The sound is coming from the pedal area.Braking is fine though. Has anyone else faced this issue? I do plan to take it to Ford A.S.S this weekend, but was wondering why that sound is coming.
vnabhi is offline
Old 6th January 2014, 17:19   #8937
Venkat_Figo's Avatar
Thanked: 168 Times
Originally Posted by vnabhi View Post
Guys,
Had this issue with my Figo, but it was prevalent during the first 5k kms only. The service guy told me the sound comes if you press & release the brake pedal while the clutch is pressed.
I found the explanation strange but after a few more kms the issue disappeared. Also this used to happen more often when the car was moving down a slope.
Venkat_Figo is offline   (1) Thanks
Old 6th January 2014, 19:25   #8938
Thanked: 497 Times
Guys,
I'm facing the same issue with my Figo. Since the braking is fine I haven't bothered.
nishantbhatia84 is offline   (1) Thanks
Old 7th January 2014, 11:59   #8939
sameerg001's Avatar
Thanked: 434 Times
With all the car companies hiking prices across their range, do we expect figo to follow same trend? Or ford is going leave figo as it is?
Old 7th January 2014, 13:25   #8940
Thanked: 168 Times
The Figo is the best priced hatch IMO, it sells well even today (though not as good as it used to) & this is attributed to it VFM tag.
Since all manufacturers are bound to hike prices across segments, Ford should be taking the plunge with the Figo. Also I believe the next gen Figo is due in 2015 & the increased focus on Ecosport, this may not hurt Ford much.
