Old 14th December 2013, 11:41   #8851
MorePower's Avatar
Thanked: 78 Times
re: Review: 1st-gen Ford Figo (2010)
Need urgent help. I've just dropped my car at Lathangi Ford for the 20000km service. I've been quoted Rs 10000 INCLUDING Rs 2700 for the underbody coating. Isn't the overall cost a bit steep?
Figo 1.4 owners, what has been the cost of your 20k service?
MorePower is offline
Old 14th December 2013, 11:52   #8852
sameerg001's Avatar
Thanked: 434 Times
Do you really need underbody coating, I believe that modern cars don't need all this, I haven't got in my figo or any other cars in family for that matter. Be it linea, i20, dzire and accent.
Also, can you please share, the break up of 10 k quoted to you? 10k is too high for 20k service.
sameerg001 is offline
Old 14th December 2013, 11:57   #8853
Deep Blue's Avatar
Thanked: 745 Times
Need urgent help. I've just dropped my car at Lathangi Ford for the 20000km service. I've been quoted Rs 10000 INCLUDING Rs 2700 for the underbody coating. Isn't the overall cost a bit steep? Figo 1.4 owners, what has been the cost of your 20k service?
It is abnormally high even excluding underbody coating. My Figo D 20k service cost 4050 in 2011 and 50k service last month cost 3960
Deep Blue is offline
Old 14th December 2013, 12:24   #8854
MorePower's Avatar
Thanked: 78 Times
Am going for the underbody coating as the undercarriage scrapes the humps a lot in Bangalore. Was worried that if its starts rusting, might face problems in the future.
Here's a break-up of costs. They had included something called 'door waxing' which I've now asked them not to do. But even then, the cost is around 8000 with coating.
Engine oil - 458
Oil filter - 458
A/c filter - 355
Drain plug gasket - 64
Air filter - 317
Wiper liquid - 62
Engine oil - 1800 - 3.6 litres
Labour service - 1050
Consumables - 456
Brake bleeding - 150
Underbody antirust - 2720
Door waxing - 1620
Battery test - 105
Old 14th December 2013, 12:33   #8855
Thanked: 1,467 Times
My last service bill at Lathangi (13/9/2013)mentions oil(3.6 litre) cost as Rs.1257 including tax. Now why has it shot to 1800?
Also, there's wheel alignment which will cost around 1k at Ford.
ramzsys is offline
Old 14th December 2013, 12:59   #8856
sameerg001's Avatar
Thanked: 434 Times
Engine oil - 458
Oil filter - 458
A/c filter - 355
Air filter - 317
Wiper liquid - 62
Consumables - 456
Door waxing - 1620
Battery test - 105
Okay, the battery test is not required. But even the cost is abnormally high, the engine oil seems to be over priced, rest I guess there's nothing in the estimate which seems un reasonable.
The cost is quite substantial, i'll be getting my 10k service done within 2 weeks, seems like it is going to pinch my pocket too.
Old 15th December 2013, 00:14   #8857
sameerg001's Avatar
Thanked: 434 Times
How do i make track name come on stereo display, while playing from pen drive?
It only shows track number and when I press info button, 5-6 times it shows track name, but only for a while. I want track name to be shown then their numbers.
Btw sandisk 8gb pen drive works well with the stereo, however transcend and hp doesn't works. I've tried Kingston, transcend, sandisk and hp. Kingston and San disk works, others don't.
Old 15th December 2013, 00:54   #8858
Thanked: 501 Times
I think you have to switch off 'info' setting. I'm not quite sure since i don't use the stock system anymore.
nishantbhatia84 is offline
Old 15th December 2013, 12:31   #8859
Thanked: 282 Times
Engine oil - 458
Oil filter - 458
A/c filter - 355
Air filter - 317
Wiper liquid - 62
Consumables - 456
Door waxing - 1620
Battery test - 105
Go by the manual, check and see if all these filters need to be changed in the 20K service. Its shouldn't cross more than 5k for a standard service with wheel balancing and alignment.
sansvk is offline
Old 15th December 2013, 14:27   #8860
sameerg001's Avatar
Thanked: 434 Times
No, there's no info off option. But I got it, you've to press info button for 4-5 seconds, then select file instead of track. Then you're ready to go.
Old 15th December 2013, 14:43   #8861
And this setting change is not permanent. You have to do this every time the unit is powered on.
ramzsys is offline
Old 15th December 2013, 16:02   #8862
sameerg001's Avatar
Thanked: 434 Times
Any option to make it permanent?
Old 15th December 2013, 18:04   #8863
EFF-EIGHT-BEE's Avatar
Thanked: 113 Times
I guess unfortunately no, I just scanned through the instruction manual and couldn't find any appropriate procedure regarding the same..
EFF-EIGHT-BEE is offline
Old 15th December 2013, 22:17   #8864
Thanked: 501 Times
There is a permanent setting. I'll check it on my mom's Figo and let you know.
nishantbhatia84 is offline   (1) Thanks
Old 15th December 2013, 23:11   #8865
Thanked: 113 Times
Hi guys need an urgent advice, toady after washing the car(Figo d) I accidentally left the boot open(was nor latched properly) and I realized my folly in late evening which means that the boot's light was also on for atleast 7-8 hours. Now my fear is that could the battery be discharged by this act? I checked the voltage through diagnostic mode and it was showing 12.3, after which I ideled the car for 15 min and voltage was back to 12.6/7. Now is this sufficient or shall I get the battery charged? I also have to make a highway trip in the morning, is it safe to take the car or will it be unreliable in this state?
