Old 28th February 2013, 00:55   #7771
blackfire_9's Avatar
Thanked: 191 Times
Strange noise/vibration when making a U-turn
Hey everyone,
I have been noticing this strange sound & mild vibrations whenever I am making a U-turn. Its more prominent in the 2nd gear (say, when one makes a U-turn normally after braking near the turn & shifting to a lower gear), but far less prominent when I am stationary (say, at a red signal) & then start off in the 1st gear.
Its been there for quite a while but I didn't think much of it, but lately, it seems to have increased & I am sure that I am not lugging the engine. I have driven a friend's Figo as well to ensure this & his car didn't make any noises like mine.
I am supposed to go in for my car's 2nd service at the end of this week & thus, would request urgent responses so that I can accordingly take it up with the ASC.
blackfire_9 is offline
Old 28th February 2013, 17:17   #7772
jayded's Avatar
Thanked: 548 Times
Re: Strange noise/vibration when making a U-turn
Are you sure it's coming up when you take a U-turn, or have you noticed it while driving over rough patches in the road too? If the sound resembles a bassy metal to metal "trrrr" striking noise, it can be the brake calliper vibration. It's a known issue in the Figo.
Originally Posted by vnabhi View Post
Thanks guys for your prompt response. I'm not sure if it is a bearing sound, as I don't regularly use the Figo. I'll check and report again in a week.
Could it be the hum jayded reported at a particular rpm? Let me check and get back.
Even I get a humming sound while cruising above 60-70 kms and I i turn off the fan. I was thinking it was due to the tire noise since my stock MRFs are on their last legs. Not sure if it's something else.
jayded is offline   (1) Thanks
Old 28th February 2013, 18:59   #7773
swiftnfurious's Avatar
Thanked: 9,731 Times
Originally Posted by jayded View Post
...Even I get a humming sound while cruising above 60-70 kms and I i turn off the fan. I was thinking it was due to the tire noise
Could be the turbo? If you drive in the non-turbo zone, you should be able to verify it, based on what rpms does the turbo start spooling.
swiftnfurious is offline
Old 1st March 2013, 00:55   #7774
Thanked: 191 Times
The brake calliper noise is there in my car, but this just seems a lot more prominent. The sound appears as if the engine is vibrating a lot, or something inside the engine bay is vibrating (maybe some plastic thing), but not sure. In fact, it is because of this nature of the sound that I first ensured the correctness of my driving style (so that I am not lugging the engine).
Old 1st March 2013, 07:35   #7775
jayded's Avatar
Thanked: 548 Times
re: Review: 1st-gen Ford Figo (2010)
Are you referring to the turbo whistle or speculating an issue with the turbo? It's definitely not the former, since this is not the pleasant whistle, but more of a sad hum. I hope it's just a tire noise and nothing big.
I too used to get the same sounds. I even asked the guy at the A.S.S. to check the engine mounts, but he insisted that was not the problem. Next time the vibration pops up, I am trying to push for calliper replacements. Better to do it before the warranty expires.
jayded is offline
Old 1st March 2013, 10:26   #7776
Arch-Angel's Avatar
Thanked: 285 Times
A question for current figo owners:
Does the tdci engine develop noise after 1L+ kms like other engines?
Arch-Angel is offline
Old 1st March 2013, 10:50   #7777
Skyline GT-R's Avatar
Thanked: 232 Times
The most used Figo i know (from FB Figo Owners Club) is 70000+ kms old & as per the owner is running like new without any issues in driveline.
Skyline GT-R is offline
Old 1st March 2013, 14:54   #7778
Sheel's Avatar
Thanked: 14,718 Times
Akshay4587's friend's Figo has done over 1L and as per him, its running like it used to. No issues/niggles to report of. I am tagging him here (via FB) hope he responds.
Sheel is offline
Old 1st March 2013, 15:42   #7779
akshay4587's Avatar
Thanked: 4,545 Times
The Car(June 2010) is 1.04L on odo today,and it just returned from a 1200 Round trip.Just before this trip,the car went through cooling coil replacement,as gas had leaked,and some parts were replaced in the front suspension.Not to mention,this car goes through a lot of abuse,as my friend never slows down for potholes and is always revved hard,and the engine still feels good for another 1L.I will confirm,but timing belt\Chain was recently replaced as a part of preventive maintenance.
akshay4587 is offline   (2) Thanks
Old 1st March 2013, 16:05   #7780
Thanked: 307,024 Times
Here's the link to watch the Figo Special Edition unveil.
4th March, 1330 hours.
GTO is offline   (4) Thanks
Old 1st March 2013, 16:54   #7781
Blow Horn Ok's Avatar
Thanked: 985 Times
Yesterday after driving 10-12 kms, I observed an unusual kind of noise when the revs were exactly @ 1000 RPM. At first it thought that it might be some stick or bush entangled to the wheel but when i stopped and observed, found that the sound was coming from the engine itself. The sound is a sort of friction/rubbing kind, As if a bearing is running without any grease. Its emanating from the area near the pulley/belt/power steering pump. When I started the car today morning, I could not hear the sound. May be it would reappear when the engine heats again. What could be the Issue? I cleaned the engine bay with half bucket of water day before yesterday. Could it be the reason?
Its a 2010 1.4 TDCI done 19000 kms. Last service was carried out @ 15k kms. I have decided to get the service done every 5k kms, owing to extreme dusty and bad roads here. Will take the car for 20000 service as soon as it completes the 20 k mark.
Should I go for the diesel filter change? What is the cost and time involved?
The car is frequently stalling when the clutch is pressed to down shift. Last time I missed a turn and went on a wrong side, as the car died just before the turn. Will get the ECU flashed this time.
Also, the left brake caliper noise is another fly in the ointment. Should I go for change in caliper? Greasing is not helping for more than 500 kms.
Blow Horn Ok is offline
Old 2nd March 2013, 12:49   #7782
Arch-Angel's Avatar
Thanked: 285 Times
Talked to a person who is employed in ford regarding the figo anniversary edition and he didn't tell me much except that it may not sport rear power windows. A new paint/decal and a small badge is one of the few features that will differentiate it from the other versions it seems. There may be other changes as well, but he wouldn't tell me about it.
Old 2nd March 2013, 18:14   #7783
jayded's Avatar
Thanked: 548 Times
This is what I received in my mail today. It's like a teaser/invite for the launch of the special edition Figo on 4th. While it gives some hints about what we can expect, I just hope it just doesn't be one of those crazy artwork-ed cars like the cheetah XUV Edition.
Review: 1st-gen Ford Figo (2010)-ford-mailer.jpg
jayded is offline
Old 3rd March 2013, 01:35   #7784
Arch-Angel's Avatar
Thanked: 285 Times
Found this online on the ford figo page.
Not much in the way of unveil, but its clear the anniversary edition figo will sport some decals(pretty obvious) and i did notice the door handles had a subtle difference in the sketch the guys were doing.
Old 4th March 2013, 09:31   #7785
Thanked: 31 Times
Got the front right Link rod replaced, as there was some noise from it and it had developed 'Play' as per the SA.
Cost ~ 1300/-
They refused to do it under warranty, as my car had done 35K, and the warranty of the link rod is only till 20K.
dhinchak is offline
