My ikon flair 2004 July has covered more than 1.5lacs kilometers so far! I don't understand why people are screaming about the high maintenance cost in ikon as i never had a problem with high service bills. Lathangi ford guys one time told me to replace many unwanted things like -there was a few degrees of bend or tilt in plastic tank where we fill coolant (don't know how he assumed as nobody could make it and hence I denied replacing it!). He also mentioned to replace head gasket and over haul engine. The vehicle has done 10k kilometers after that and the problem was a faulty O2 sensor and ignition coil! As per my knowledge if there is a problem with gasket, water will get mixed with engine oil and the color of engine oil will turn white! This I had seen my dad’s old jeeps! Now later changing the O2 sensor and ignition coil the Ford A.S.S agrees there was no problem with gasket or engine. But who will bear the bills if I would have listened to the wrong diagnostics? - The innocent customer. So my advice to all fellow bhpians, never do costly repairs with advice from just 1 A.S.S, what ever is your car’s make, research about the problem before making any decision.
Few Problems I had seen in ikons including mine are listed below, may be this will be useful to my friends here!
Another thing was the silencer pipe. Ford ikon's silencer pipe is hanged on rubber parts(don't know about other cars), so this rubber parts gets cut after a certain period of time and silencer pipe starts getting moving or even worst cases get cut. Initially there will be silencer pipe leakages and ford A.S.S will always insist in replacing entire stuff. My advice is to go to a good garage outside and try welding (I don't know the correct technical word!) and you can stop the silencer leakage for just 100bucks. The rubber parts will cost just Rs.30 if I remember correct.
Then the next problem part is ignition coil. This seems like a common problem with ikons. So mine to failed one fine day and vehicle started firing on 3 cylinders. Fuel efficiency and power too dropped considerably. I went to OEM supplier for the spare and got it replaced from outside garage at a cost difference of 1k from Ford A.S.S. Also changed the spark plugs from outside (here I made a mistake, my new plugs came at a price of 180 each, I believe these days the OEM plugs comes at a cheaper price at the A.S.S. Bangaloreans check with Metro Ford Lingarajapuram as there is a price difference between Lathangi and Metro in spar parts prices (This is just my opinion as I found Metro ford slightly cheaper for spares)
After replacing the ignition coil and spark plug, still my vehicle has not giving the fuel efficiency of 10-11 in city and 14-15 on high ways I was getting before! The mileage dropped to a mere 6-9 in city and a maximum of 10 on highways! What to do? I love this car a lot and it is ripping me off with poor fuel efficiency! Then I went for another checkup at A.S.S (Both Lathangi and Metro) to confirm the problem and the culprit was a failed O2 sensor. Replaced it and voila the mileage and pick up came back to normal! The vehicle started performing as if it was new (Cost 4.2k)
Apart from this what I have done in last few years to this car was replacing the front struts, changing lower arms both sides ( Never replace lower arms or suspension related spares outside as it won’t last long!) and replacing tires only.
My cost of repair was less than 40k including replacing both ORVMS, both Lower arms, front shock absorbers with few related parts, 4 tires to Bridgestone tourenzas(185/ 70/ R13 the OEM being 175/70/13), left side tail lamp(buy only OEM , others will fade quickly).
Issues I faced in my ikon and suggestions from my experience in short:
1. Ignition Coil – Get it replaced at A.S.S as ford has upgraded the ignition coil for ikon few months back. When trying to replace it from outside, you may be getting the same old design which came in car and it can fail again
2. O2 Sensor – Not necessary it can fail in all ikons. May be in a few high mileage vehicles. If the vehicle I running in rich fuel, it can emit black smoke and fuel efficiency can be less. There are many things (spark plugs, injectors, ignition coil and sensors) that can cause the vehicle to run rich.
3. Lower Arms, Struts (This is not a weak point in ikon as ikon has one of the best and strong suspension set ups in my opinion). Change only at A.S.S
4. Silencer Pipe. Try replacing only if you cannot get it repaired through welding or such procedures. You can save 2-3k here. My car has no issues after fixing the leakage in silencer 2 years ago and I travelled not less than 30k kms. after that.
5. Spark Plugs – Try OEM plugs as it is cheap and the manufacturer’s recommendations are best suited most of the times.
If you do proper research before any repairs I’m sure all ikon owners can reduce their service bills considerably. Happy motoring to all! |
