Old 14th May 2014, 06:13   #841
Thanked: 241 Times
re: Review: 1st-gen Toyota Fortuner
Is your model the prefacelift one or the facelift one?
Both of them have projectors whereas the prefacelift has halogen projector on the edges and facelift has HID on the innder side. They are only for low beam. The High beam is a direct halogen bulb without projectors so when the car is low beam only the projectors are on and when in highbeam both are lighted. I think you are referring the main bulb as the high beam bulb and dip and the projectors as dim. If I am correct in understanding what u asked then the answer is there.
V12Doc is offline   (1) Thanks
Old 15th May 2014, 02:29   #842
maddy42's Avatar
Thanked: 1,648 Times
Thank you V12Doc.
Thats correct.
Mine is a Facelift model. The projector is on the inner edge and this is for Dim. The main halogen gives the Dip.
I had trouble driving, and so did my dad with the Halogen projector in a hilly area as we get curves too frequently and this light is just not enough to spot any characters walking on the side of the road or any potholes which may come up.
So wanted to know if i can improve this without adding any new lights to my car or is that the only option left?
Maddy
maddy42 is offline
Old 15th May 2014, 02:40   #843
ecosport rules's Avatar
Thanked: 2,063 Times
Originally Posted by maddy42 View Post
Thank you V12Doc.
Thats correct.
I had trouble driving, and so did my dad with the Halogen projector.
Maddy
It is HID projector and not halogen.
If you want still better lightning go for a 36 inch LED bar.
It has both flood light and spot light LED reflectors
ecosport rules is offline   (1) Thanks
Old 15th May 2014, 02:45   #844
Thanked: 241 Times
Thank you V12Doc.
Thats correct.
Maddy
I think fortuner comes with one of the best OEM lights on any car under 30lacs today. Lights up the road like charms. Your need is cornering headlight which are not there on the fortuner. You could try attatching hella light on the grill or bumper. That might help but not sure if it will. Have never used those personally
Old 16th May 2014, 00:26   #845
maddy42's Avatar
Thanks for clarifying. I will check my options here.
Thank you. I will have a look at these and also request the service center to get the light allighnment checked to confirm thats not at fault here. The reason i am stressing is the throw from the projector is all on the ground and has less than 2 second distance in distance covered(less than 20 feet distance).
Maddy
maddy42 is offline
Old 16th May 2014, 00:50   #846
Maddy
At what setting is the headlamp levelling at?
If it is at anything other '0', the beam throw will be closer to the car.
Old 17th May 2014, 03:18   #847
maddy42's Avatar
I am away so i wont be able to look at the same so i informed dad. Thank you.Will confirm once we get to know more.
Maddy
maddy42 is offline
Old 17th May 2014, 04:13   #848
Thanked: 241 Times
I don't think you can level the headlamps on the fortuner. They are auto levelling afaik. I tried finding the leveller when I bought it but couldn't so assumed they would be auto levelling.
V12Doc is offline
Old 17th May 2014, 09:48   #849
My bad. Apologies. The Fortuner comes with an auto-levelling projectors setup, so if that is the case, check that self-levelling device also to know whether it is working or no.
Old 17th May 2014, 23:21   #850
Thanked: 28 Times
Is there any plugin upgrade for navigation with the stock Head Unit of the fortuner? Has anyone tried it?
TorquePeedo is offline   (1) Thanks
Old 19th May 2014, 01:35   #851
Yes ,there is one model available from Caska and megaudio.
Old 22nd May 2014, 20:27   #852
D4D
D4D's Avatar
Thanked: 336 Times
What is the low ratio of the transfer box? A friend of mine is interested in buying this vehicle as he wants a proper vehicle for off-roading.
D4D is offline
Old 22nd May 2014, 23:47   #853
nilanjanray's Avatar
Thanked: 2,946 Times
1:2.566
See here:http://www.team-bhp.com/forum/long-t...ml#post2485984
nilanjanray is offline
Old 30th May 2014, 16:41   #854
Thanked: 28 Times
What security options are generally put in the fortuner to protect it against theft especially in the NCR region? Is the stock central lock and engine immobilizer enough?
Old 30th May 2014, 18:31   #855
scopriobharath's Avatar
Thanked: 1,335 Times
Put in a gear lock to act as a visual deterrent and also invest in a sim based telematics device. This is the best way as you could disable the engine through SMS, in case of a theft. Sim based ones costs 15-20K and is miniscule to protect a 30 lac toyota
scopriobharath is offline   (1) Thanks
