Some random pics of rear parcel tray, center console and the speaker door pads.
Amazing effort bull boy and the end result is definitely very clean, no wires can be seen anywhere. Do post some more details, where is the CPU box located and whats the big knob next to the gear box?
^ Cpu is bolted to an Mdf plank behind the rear seat . The big knob is griffin powermate used for volume control :)
Update : Nothing much to talk about as the car has done only 33k .I'm planning to schedule a service sometime late this month .I'm having some problems with gps receiver which the pc fails to detect when back to life from hibernation.
Nice to see your carputer up and running. I am using Mireo MMI latest and garmin Mobile PC for navigation. I can't get the navigation to work with CF 4.0. Could you share how to make phone calls using CF4.0/ synchronizing PC and cell phone.
Thanks for the Maps suggestion I assume Mireo is only for Android and not for windows?
I have the BS stack installed and mic is via Andrea Suma USB.
Once you have this in PC and BT working fine and pairing (remember to set the permissions in BT properties) then go to CF and configure the phone in settings > bluetooth. Once the phone is detected here , you can receive and make calls via CF.
If I need to stress on anything specific please do mention.
Originally Posted by bullboy
(Post 3258448)
If I need to stress on anything specific please do mention. |
Which BS stack are you using? Can you through more light on how to do setting in phone to receive calls via PC.
Mireo 8.0 for Windows has been released. That's what I sent you the links for.
A few more questions:
a) What is the wattage of your PSU?
b) Did you yourself fabricated the fiberglass panels?
Originally Posted by mercedised
(Post 3259770)
Which BS stack are you using? Can you through more light on how to do setting in phone to receive calls via PC. Not sure of the finer version.Will check and PM
Mireo 8.0 for Windows has been released. That's what I sent you the links for. I checked the link and it seems to be dead.
a) What is the wattage of your PSU? 250 W
b) Did you yourself fabricated the fiberglass panels? Yes . I did |
I have added my reply above
(Post 3259902)
I have added my reply above |
The links are working, I have checked them. Let me PM you them for your convenience. Any guide on how to fabricate panels, I am really looking into one for placing the 8 port USB hub somewhere on the dashboard. any suggestions on this one? Are you on FB?
Update on one more poor service at kairali ford :
Kms : 41256
Wash Fluid pouch :55.84
oil filter : 330.37
gasket drain plug : 36.44
brake pads : 1559.35
oil 5w30 -3.8L : 1088.59
tax :445
Labour
Shock abrsorber and spring front : 300
service : 1100
Total : 5089
