INTRODUCTION
I want to pen down the side-by-side comparison of my 2 SUVs i.e. Jeep Compass Limited Option Diesel and Kia Seltos HTK Plus 1.5 NA Petrol. Although they are not of the same segment yeah size-wise wise they are quite similar.
In this thread, I want to discuss how Compass and Seltos compare to each other based upon my ownership i.e. what things you get when you pay approximately 10 to 15 lakhs more than the Seltos and in which aspects Seltos is better.
DRIVING EXPERIENCE
JEEP COMPASS-
1. The first thing you will notice is the hard clutch which you will have to press to start the car.
2. After pressing the push button to start the engine, it comes to life with a slight shaking of the car.
3. The moment you start the car you will realise that now you have the command over a big turbo diesel thanks to its high NVH and diesel clatter.
City -
-The first-gear ratio is very short and the second-gear ratio is high.
-On the speed breaker, if you take out 2nd gear then the vehicle starts to stop and if you take out 1st gear then the RPM becomes high which causes a jerk.
-From 3rd gear, things go great, it drives very smoothly with good torque and power.
-Due to its hard clutch and bad 1st and 2nd gear ratios, the Compass feels unsuitable to drive inside the city.
Highway - this is where the compass truly shines and feels at home.
-It is fast on open roads with a power-to-weight ratio of 110 bhp/ton and torque torque-to-weight ratio of 225 nm/ton which results in 0 to 100 kmph in 9.5 secs.
-The suspension setup is mature and doesn't break a sweat on any undulation on the road or potholes which come your way while the car is cruising at higher triple-digit speeds.
-Highway stability is excellent, it feels like there is no limit, and it doesn't break a sweat at high speeds. 120 kmph feels like doing 80 kmph.
-The gear ratios of 4, 5, and 6th gear are very good. In fact on highways, 90% of the time all you need is 6th gear. You will beat 90% of the traffic on the highways even when you accelerate in 6th gear.
-It's a mile muncher on the highway, you can drive it at triple-digit speeds all day long with the engine spinning at 1750 rpm @ 100 kmph and 2100 rpm at 120 kmph.
-You will love to take corners at triple-digit speeds on the highways, COMPASS TELLS YOU TO PUSH IT EVEN MORE HARDER.
KIA Seltos-
1. The clutch feels so light in comparison to the compass. It feels like I am shaking my legs in the air.
2. The car starts with no vibrations and minimalistic noise, of course, it is a trait of a petrol engine.
CITY -
-Seltos is easier to drive in the city thanks to its lighter steering wheel, soft clutch and good 1st and 2nd gear ratios.
-Due to its less kerb weight approx 400 kg lighter than a compass, it feels nimble to drive in the city.
Highway -
-The moment you take out Seltos on Highway, you will notice that there is no torque in the 1.5 NA engines compared to the compass.
Now to extract more power you will downshift and floor the throttle but it will make no sense, you will keep on accelerating while waiting for the car to accelerate fast but it does not and will let you feel the thirst for more power with a sudden drop in mileage.
-But do note here that it takes a few extra seconds to accelerate but once it reaches a certain speed it can maintain that speed with ease up to 120 kmph.
-Highway stability is decent for speeds up to 100 kmph due to the stiff suspension setup.
-Cornering capability is also good, while other cars reduce their speeds while approaching the corners you glide through the corners leaving the other cars behind.
-Compass handling on highway outshines seltos after 120 kmph, if you drive below 120 kmph then both are good.
- After 120 kmph, the pace of picking up the speed drastically reduces.
- 100 kmph engine spins at @2250 rpm, at 120 kmph @ 3000 rpm.
- 0 to 100 comes in around 12.5 seconds.
