Unexpected Misfiring
Immediately 2 days after the coolant change I noticed suddenly the car was misfiring HEAVILY, it sounded like a Classic 350 I kid you not, I had to solve this ASAP as the car is a daily runner and no way was I going to let dad drive a car which is misfiring. Got in touch with DBHPIAN Vigsom to diagnose the issue the same day. It was late at night but still he chose to stay on the line till the end.
I started to check if the Ignition coils were firing correctly, Swift uses just 2 Ignition coils for 4 cylinders. They were all good. Next up was checking the High-Tension cables, I did not doubt them since they were replaced in 2021 January. I thought of checking the Plugs as well and one by one started removing the plugs. They had done just about 17,000kms.
Out of the 4 Spark plugs, one was completely black with carbon and a piece of carbon was stuck between the electrode. I did not have new plugs with me since it was well past 12 midnight, Vigsom suggested we just clean the plugs, adjust the gap and install them back for now and see if the misfire had stopped. Cleaned the plugs using wire brush and adjusted the gap uniformly across the plugs.
Assembled everything back and started the car with fingers crossed, Well past 1am Vigsom and me were curious and I cranked the car and it started with ZERO misfires ! I shrieked in happiness.
Now, I wanted to know what the reason for this sudden carbon deposition of one spark plug was, Vigsom asked me if I was running any additive or any Higher Octane Petrol, I acknowledged that I was running on XP95 for about 4000-5000km. He said that could be the cause to dislodge the deposit and got stuck between the electrode. I decided to get the Ignition coils and the spark plugs changed when I service the car.
Next day when dad started the car, he found it not misfiring one bit, little did he know I was up half the night diagnosing the issue whilst Vigsom on call.
![Rolling Laughter](https://www.team-bhp.com/forum/images/smilies/Rolling laughter.gif)
I cannot thank Vigsom enough for helping me through this unexpected issue. You truly have made your ‘Chacha’ proud.
85000km DIY Service
Car had clocked a cool 10,000km in a span of 9 months, which was decent running. Again opted for the Mobil 1 5W40 Fully Synthetic Oil from Amazon. Got all the required parts through boodmo.
Using few strong wooden planks and few bricks I managed to just raise the front of the car and choke the rear wheels to gain access to the oil drain nut and oil filter. I have ordered a set of jackstands and won't be using this setup.
Whilst I was under the car, I thought its good to clean the rubber parts and spray silicone spray on them to prolong their life. The drive shaft boots, Steering rack boot, stabiliser bar bush, Link rods, engine mounts, and control arm bushes were sprayed with Wurth Silicone spray.
![Azure Grey 2006 Maruti-Suzuki Swift VXi | Ownership Review-new-oil.jpg](https://www.team-bhp.com/forum/attachments/test-drives-initial-ownership-reports/2455549d1687276813t-azure-grey-2006-maruti-suzuki-swift-vxi-ownership-review-new-oil.jpg)
Lowered the car and poured in the new oil
Next up was the Ignition Coil and Spark plug replacement, Got 4 Denso K20PR-U Spark Plugs from Boodmo.
Thought it would be wise to clean the tappet cover as it was a bit dirty and also I had a bit of time on my hands.
![Azure Grey 2006 Maruti-Suzuki Swift VXi | Ownership Review-before-tappet.jpg](https://www.team-bhp.com/forum/attachments/test-drives-initial-ownership-reports/2455534d1687276745t-azure-grey-2006-maruti-suzuki-swift-vxi-ownership-review-before-tappet.jpg)
before cleaning the tappet cover
![Azure Grey 2006 Maruti-Suzuki Swift VXi | Ownership Review-after-tappet.jpg](https://www.team-bhp.com/forum/attachments/test-drives-initial-ownership-reports/2455533d1687276745t-azure-grey-2006-maruti-suzuki-swift-vxi-ownership-review-after-tappet.jpg)
After cleaning the tappet cover.
Removed the plugs, installed the new ones and tightened it to spec. New Ignition coils had a bit of a design change and looked more well sealed than the old one. Service Manual states that these must be changed every 80,000kms.
![Azure Grey 2006 Maruti-Suzuki Swift VXi | Ownership Review-new-coil-comparison.jpg](https://www.team-bhp.com/forum/attachments/test-drives-initial-ownership-reports/2455546d1687276745t-azure-grey-2006-maruti-suzuki-swift-vxi-ownership-review-new-coil-comparison.jpg)
Comparison
The left side Link rod had its boot torn and was having a bit of play, ordered new Link rod from Boodmo and installed it along with new nuts.
![Azure Grey 2006 Maruti-Suzuki Swift VXi | Ownership Review-link-rods.jpg](https://www.team-bhp.com/forum/attachments/test-drives-initial-ownership-reports/2455543d1687276745t-azure-grey-2006-maruti-suzuki-swift-vxi-ownership-review-link-rods.jpg)
Old vs new Link rod Cleaning the cowl panel
Started cleaning the Cowl panel thoroughly, using a brush and made sure the drain passage was also clean and free from debris. No signs of rusting was seen. Lubricated the wiper links using Maruti Hinge Relief.
Stuffing Grease onto the front strut top
Taking Leoshashi’s advice, I decided to stuff grease onto the strut tops since water ingress into it can cause the strut bearing to go bad and become noisy. Applied grease generously and fit the cap back on to it.
Replacing the open wheel nuts to Closed ones
Since I had put alloys, the Lug nuts were the same old open ended ones which come with V and L variants. Got 16 of the closed Lug nuts and installed them to complete the looks.
Replacing the Exhaust rubber mounts
The existing rubber mounts started cracking and the exhaust was shaking a bit too much, decided to get these replaced as well.
Ashton Castelino
