Originally Posted by tunedv8 What a simple yet stunning mod! Great job finding the parts and going through with the effort! |
Thanks tunedv. There are some folks who import the parts from India but the prices are quite unreasonable. 20k for a steering and 20k for a speedometer is a lot of money and even OEMs do not charge that much
Originally Posted by Mickey1986 Nicely done bro. Really like your customisations. I am wondering about sync 4 upgrade - do you think it’s possible to get that sorted now from current sync 3 ? What could be the costing for this ?
Also about the cluster - I read that now there is one fully digital cluster available. Any idea about that one ? |
Thanks Mickey! The sync 3 and sync 4 have modules called as the Front Controls Interface Module(FCIM) and Accessory Protocol Interface Module (APIM). Although the APIMs look identical, there are some firmware and electronic changes which is not a direct fit. I'm able to source the sync 4 module from Vietnam at a cost of 15,000Rs.
Difference between sync 3 and sync 4
APIM for sync 4
However IMO, sync 3 vs sync 4 not many tangible differences are there, sos I'd suggest to stick to sync 3.
Regarding digital meter, we need UCDS tool and the cost of the meter in European or American scrap markets in ebay are anywhere between 50-70k Rupees. Plus shipping to India and some tweaks have to be made.
If you're really interested, you can go ahead with the digital clusters of Ford Focus, Fiesta or Ford Escape cluster. Ford Puma I doubt if the config files are compatible for EcoSport.
Originally Posted by Rakshith220 It is always a delight to read through your modifications and the effort that goes behind it is commendable!
You are one passionate person who know how car's are modified in a delicious way!
I know that your a foodie too and mostly that hunger for the best modification appetizes you I believe!!
And hence your car becomes one of the tastefully modified EcoSport's in India!
Kindly keep up the good work going!
Good luck for your future upgrades too!
Dr. Rakshith GT |
Thanks a ton Doctor! We've always share that common passion for our car and you too are a proper enthusiast who does mods after a thorough research. I'm more on the experimental type
Nice analogy on the hunger for mods and my reference as foodie!
I forgot to update on another update previously. I changed my horn from the stock Ford one to a pair of Denso Horns(Low tone and high tone) at a cost of Rs. 1400
I picked up the horn from Engineering Exponent and they were suggesting that the horn terminal from the car might need to be crimped. However, I ordered a pair of audio connectors from Amazon so that the installation is plug and play without cutting of any wires. This connector can be used for any horn to convert it into a Ford compatible one
Here's the Amazon Link for the connecting wire for the horn:
2 Pieces Car Audio Speaker Wire Harness 72-5600 for Chevy Ford Focus Mazda https://amzn.eu/d/1J7uHwd
The Denso Horn pics
As I was doing the installation myself after my shift time at 3 am, I couldn't get an opportunity to record a video of the installation and how I've changed the place of the horn location.
Here are some pics of the horn before and after installation
The front design. Japs are always ahead in design (look at the design covering the trumpet so that water does not seep through)
The rear side. Direct fit to any car except Ford! Please don't try to remove the horizontal bar as you might end up getting hurt if your try to unscrew it.
Caution instructions by Denso. Never use the honk continuously for 30 sec or beyond as it can cause damage to the horn!
The big L plate gap is the new place for the horn. Actual location for the horn is under the fog lamp housing
The Denso horn fitting snugly at the new L plate location. Once you open the headlight, you can find this place. You will need a 13" Socket wrench to unscrew the L plate
I chose this spot as there is a minimum chance of water seepage as the horn will be protected by the headlight above and the metal/fog lamp housing below the horn
The stock horn is doing duty in the Blue Baby as the Blue Baby's hella horn had gone kaput.
