December 2020 turned out to be surprisingly busy juggling retrofits and the winding up of my even semester activities. I was not even sure how much I'd be able to achieve in the last week of December, but somehow, it all came together and now my Sunset Red beast feels so much better to drive! I will be staggering the upgrade information, but this post is all about the most delightful changes I've made on the Polo -
8K OPS Upgrade and the gorgeous
MaxiDot Cluster.
8K OPS Retrofit
So the Polos sold in India come with 4 Rear Parking Sensors, which Beep depending on the Proximity. I've frankly never been a huge fan of these, but what has consistently been helpful to me on my Jetta, was the 0K to 8K OPS Kit fitment that I did. It upped the Parallel Parking precision. Now one might argue that a small Polo does not need such an advanced parking system, but hey, we're in 2020, and already being sold a decade old vehicle, and the Kia Sonet has it too, and it's always good to have something than not have it, and so I made the plunge and ordered the parts. The detailed installation guide on TeamBHP was quite helpful for guiding this retrofit, but as per my experience, new challenges await, on every curve.
Sensor Painting
I was initially considering having the sensors installed at Volkswagen's Dealership, so I could have a responsible entity taking care of removing and refitting my bumper and ensuring a perfect paint match, but I realised it'd have been far too cumbersome doing all the installation work at their premise. As a middle ground, I had only the sensors painted from them at about Rs. 500 + GST, with a perfect paint match, in Sunset Red.
Two years ago, when I installed 8K OPS on my MK5 Jetta, I trusted an outside garage to paint the sensors, and didn't bother to check the technicalities involved, and for the most part, everything has been fine.
However, there are a few small things to know like removing of the Black Silicone Rings, and ensuring a certain paint thickness, and Volkswagen was prompt at doing these things without even mentioning the same. My OnePlus 6T has a bad habit of playing with the colours, but the paint match is absolutely spot on, just as you'd expect, from a good workshop. Here is a photo of the mounting plate and the painted sensor, after the Silicone ring has been installed. The mounting plates typically have different part numbers depending on the fitment location since some sections on the bumpers are curved while some are flat, but for the most part, the holders I received were pretty much the same. The adhesion was not the strongest, and I did add a few drops of Fast Adhesive to ensure a snug fit.
Mounting Locations
I was quite skeptical as to whether the bumper would have locations marked for the sensors since most Polos did not come with 8K OPS, even internationally. The 8K OPS was special to the GTI and the Polo Sedan in Russia for instance. I had a picture of a beautiful white GTI downloaded on my phone, but on taking the bumper off, it was quite a pleasant surprise to see 3 out of 4 locations already marked on the bumper.
The hole size you need is an 18mm diameter, but using a normal drill doesn't ensure the perfect surface finish and so we used the Original Volkswagen Skoda Parking Sensor tool for ensuring an immaculate smooth finish on the bumper.
Some Cues and the End Result Warranty Aspect
For the entire retrofit, I have endeavoured to not damage or tap or cut into any stock harness, but the warranty still lies with the mercy of the dealership, who may view this as an "Unnecessary Task" performed by the Customer. Since this is our third Volkswagen, and I have the right resources (VCDS, ODIS and more importantly, a lot of talented friends) to self diagnose, repair my vehicle, I did not care too much about the implication of this retrofit on my warranty. However, a perfectly executed retrofit leaves no ounce for errors and my car has Zero Fault Codes to its credit as we speak.
How Much Work?
While I initially thought the 8K OPS Upgrade would be a cakewalk, it sure needs it's sweet time to ensure everything is smooth. The work involves Removing the Front bumper, Drilling Holes, Fitting Sensors, Laying the Harness from the Engine Bay to the Rear of The Car which needs removal of all the Floor Panels and taking care of Metal and Plastic Clips which often tend to break, and lastly, making changes to the Stock Connectors to Feed and replace a few wires.
The entire AC Panel, Radio Headunit, instrument cluster, needed to be removed to lay out all the wires correctly and make appropriate connections. There was a point where I felt bad for ripping apart a tight, brand new car, and I almost started to regret it. But with patience, the job was completed, and once everything has been put back together, the convenience and satisfaction is unparalleled.
Some Little Things
On removing the Air-Condition Panels, I noticed the three 6 Pin Connectors for the ESP, Rear Defogger and the Hazard Switch and it put a smile on my face to see the colour coded connectors and buttons. A small touch, but truly brilliant.
The Blank Switches on the Polo are not alike. Each has a different groove. The OPS Button I received, was not a perfect match to the Shade of the Buttons on the car. It also is a little offset, and looks a tiny bit sore on what is otherwise, a solid looking dash.
The rear OPS Module on the Polo is located on the Rear Right and it was just plain dumb on Volkswagen's part to omit the CAN enabled wiring Harness. Honestly, how hard is it to simply have left two wires for future users, when they were already offering it in the beginning.
MAXIDOT
Initially, when I first drove the car during the test drive, it did not strike me how much I'd come to hate the existing cluster on the Polo. Sure, it does display quite a lot of useful information like the :- Consumption, Amount Refilled, Coolant Temperature etc - and to the delight of many, it could even needle sweep. However, I started losing it, when I couldn't realise which door was open, and it started happening quite a number of times.
I also started hating how bad the cluster looked like when it was super sunny outside and it was then that I decided it was time to MAXIDOT my Polo, but even then, I had no idea that this would be the best thing I'd do for upping the premium-ness of what's a decade old car.
What I Love- Premium, Clean and Suave Look
- Coolant Temperature and Fuel Tank Levels are back as Gauges!
- Incoming Caller Notification - from RCD 340
- In-Built Light Sensor
- Exact Door Open Indicator
- ESP OFF Triggers a Notification
- Oil Temperature Display
- Scope for Direct TPMS
- Scope for Displaying Audio Information after MIB 2 Upgrade - If I ever consider it.
- Windshield Washer Fluid Level Sensor Compatible.
Both of these upgrades were concluded when the car, reached a very special figure, the 1000km mark, in record time, considering our driving pattern. Overall, I truly love the MAXIDOT upgrade and it is worth every penny, if you love driving your car. I feel every Polo TSI deserves it, and its a shame Volkswagen didn't consider it, considering this is the last of the Polos they'll sell here!
On that note, I start 2021, with a mandatory shot at one of my favourite place, The Mechanix Automotive, where the magic happens and there's quite a lot of magic tricks on the way! Wishing everyone a happy new year!
What's Next- LED License Plate Lights Installed - Update Coming Soon
- EuroSpec Intake Conversion
- Flip Reverse Camera - Awaiting the Correct Plate.
- TPMS - Maybe?
