Old 12th November 2017, 19:58   #76
karan561's Avatar
Thanked: 22,854 Times
re: My 2001 BMW 328i (E46) Project Car - Build Thread! EDIT: Cooling system update & short shifter
Originally Posted by S2!!! View Post
What a fascinating project Karan! Many congratulations for the car as well as the successful engine and transmission swap . Glad that you aren't planning to go overboard with the modifications on this car. I'm pretty sure the engine swap would feed your need for speed. One suggestion though, please keep the cosmetic mods limited and subtle.
Thanks Saumil, yes i am going to keep it basic with the engine mods for now as the stock engine with the lightweight body of the e46 is capable enough to have fun (0-100 km/h sprint in under 7.5 sec). Cosmetically i am going to keep it subtle but sporty, something like what v12 earlier posted.
Would love to check her out in person sometime, give me a shout when you're heading for a zombie drive or something.
Done
karan561 is offline
Old 10th December 2017, 19:32   #77
karan561's Avatar
Recently changed the rear number plate lights to white LED's to refresh the look of the car at night as before only one of the lights (yellow) were working;
My 2001 BMW 328i (E46) build thread | EDIT: New video & upgrades on page 15-imageuploadedbyteambhp1512914526.734844.jpg
It was a simple DIY & here are some pics;
My 2001 BMW 328i (E46) build thread | EDIT: New video & upgrades on page 15-imageuploadedbyteambhp1512914198.708358.jpg
Old & New housing;
My 2001 BMW 328i (E46) build thread | EDIT: New video & upgrades on page 15-imageuploadedbyteambhp1512914210.491094.jpg
After;
My 2001 BMW 328i (E46) build thread | EDIT: New video & upgrades on page 15-imageuploadedbyteambhp1512914222.344957.jpg
My 2001 BMW 328i (E46) build thread | EDIT: New video & upgrades on page 15-imageuploadedbyteambhp1512914231.827185.jpg
karan561 is offline   (15) Thanks
Old 10th December 2017, 22:23   #78
NH7
Thanked: 67 Times
Good subtle change this, looks up to date without looking too blue/ over the top. Hope you have no light busted indications on your cluster. I did for a while, then just changed to a new set and that solved it. Though the fit was compatible, the resistance (??)wasn't I'm thinking. Something to keep in mind if you are thinking of the reversing lamps next.
Last edited by bblost : 10th December 2017 at 22:51. Reason: Avoid using unnecessary ...
NH7 is offline   (2) Thanks
Old 10th December 2017, 23:25   #79
karan561's Avatar
^ No.
Ok
karan561 is offline   (2) Thanks
Old 22nd December 2017, 19:14   #80
karan561's Avatar
Clutch Arrives;
Stage 3 clutch kit just arrived;
My 2001 BMW 328i (E46) build thread | EDIT: New video & upgrades on page 15-imageuploadedbyteambhp1513950222.115229.jpg
My 2001 BMW 328i (E46) build thread | EDIT: New video & upgrades on page 15-imageuploadedbyteambhp1513950259.935744.jpg
My 2001 BMW 328i (E46) build thread | EDIT: New video & upgrades on page 15-imageuploadedbyteambhp1513950289.638012.jpg
This is sourced from Black Diamond Performance. This Paddle Clutch has been engineered to be a Race Clutch. These five paddle clutches are designed for use with highly modified engines (up to 40% above standard) have cerametallic friction surfaces which can cope with more power and deal with heat more efficiently, they wear at a slower rate, and have stainless steel backing plates.
This clutch is designed as direct replacement to standard unit using the original manufacturer’s bolt holes, no modification of the flywheel is necessary and the standard clutch release mechanism can be retained
karan561 is offline   (9) Thanks
Old 28th December 2017, 22:15   #81
karan561's Avatar
Test Running the New clutch;
My 2001 BMW 328i (E46) build thread | EDIT: New video & upgrades on page 15-imageuploadedbyteambhp1514479521.496943.jpg
Initial impressions are though being a Stage 3 clutch it still retains almost OE like clutch pedal release. As its a fresh install its too early to comment now but shall keep you posted
karan561 is offline   (11) Thanks
Old 29th December 2017, 13:11   #82
v12
v12's Avatar
Thanked: 7,548 Times
Sorry for hijacking your thread Karan! But couldn't find a better place to post this. Love the M3 CSL type boot spoiler.
http://classifieds.team-bhp.com/buy-...3-Series.html/
My 2001 BMW 328i (E46) build thread | EDIT: New video & upgrades on page 15-picture_226242.jpg
v12 is offline   (3) Thanks
Old 31st December 2017, 16:49   #83
karan561's Avatar
Attachment 1710766
Yes i am aware about this car & the owner. Dont know why is it for sale though.
karan561 is offline
Old 1st January 2018, 20:46   #84
karan561's Avatar
New Year New Car Parts
My 2001 BMW 328i (E46) build thread | EDIT: New video & upgrades on page 15-imageuploadedbyteambhp1514819751.124873.jpg
1) Level 3 Cooling System Upgrade Kit - GEBA water Pump with metal impeller, ECS Aluminum Water pump pulley, Fan Switch, Thermostat with Housing, Sealing Gaskets, Expansion Tank with level sensor and clamp,Pressure Cap, 1 Gallon Coolant, Upper & Lower Radiator Hoses,Accessory Drive Belts, Radiator Drain Plug, Nissens Radiator,Idler Pulley,Hydraulic Tensioner and Pulley, A/C Belt Tensioner Assembly)
2) New A/C parts (condenser, evaporator etc...)
3) AFE Stage 2 Magnum Intake
4) Gearbox Rebuild Kit (Bushings, Shifter Rod joints, Washers, Bearings etc)
5) Short Throw Shifter
6) Transmission Fluid change
7) Stage 3 clutch already installed
Old 1st January 2018, 20:56   #85
F150's Avatar
Thanked: 918 Times
Hi Karan,
I thought this was a mod with specific targets in mind. But your list of mods is starting to get a little long. I have seen threads of the forum where everything will be modded or upgraded and the car is not reliable anymore. Eventually the car is sold.
I hope and wish your car doesn't end up as one such case.
F150 is offline
Old 1st January 2018, 21:14   #86
karan561's Avatar
Originally Posted by F150 View Post
Hi Karan,
Hi F150.
Well the list of mods is maintenance, let me explain;
1) ECS Tuning Level 3 Kit is all Genuine BMW / OE Parts
2) AC Parts are again OE
3) AFE Intake is BOLT ON fitment for E46
4) This is to get back the original shift quality and again all parts are genuine BMW
5) Short Throw shifter is again Genuine BMW upgrade for the E46.
6) Transmission fluid change is again Maintenance
7) Stage 3 clutch is an non OE part installed to tackle the 328i power.
Thank you for the good wishes
karan561 is offline   (5) Thanks
Old 26th January 2018, 18:55   #87
karan561's Avatar
Been really busy with work, travel & other commitments hence could not update the thread but all the parts are installed & now this is how the engine bay looks (New Air Intake, New Cooling Parts & Radiator, New AC parts, Short Shifter etc);
My 2001 BMW 328i (E46) build thread | EDIT: New video & upgrades on page 15-imageuploadedbyteambhp1516973055.756210.jpg
Will be soon Filming a video (Project E46 - Part 3) to explain everything
Old 27th January 2018, 12:39   #88
karan561's Avatar
Yes
My 2001 BMW 328i (E46) build thread | EDIT: New video & upgrades on page 15-imageuploadedbyteambhp1517036969.995781.jpg
karan561 is offline   (12) Thanks
Old 4th February 2018, 21:37   #89
karan561's Avatar
Had called for the OE Cabin/AC Filter for the car;
My 2001 BMW 328i (E46) build thread | EDIT: New video & upgrades on page 15-imageuploadedbyteambhp1517760380.204204.jpg
My 2001 BMW 328i (E46) build thread | EDIT: New video & upgrades on page 15-imageuploadedbyteambhp1517760409.783727.jpg
My 2001 BMW 328i (E46) build thread | EDIT: New video & upgrades on page 15-imageuploadedbyteambhp1517760429.775066.jpg
^ was a simple DIY
karan561 is offline   (6) Thanks
Old 17th February 2018, 14:14   #90
karan561's Avatar
Called in for some meaty exhaust tips for my E46 to match the DTM Race sounds my custom exhaust setup produces;
My 2001 BMW 328i (E46) build thread | EDIT: New video & upgrades on page 15-imageuploadedbyteambhp1518856999.544550.jpg
^ PS - Dont miss that gear knob, More details of that & short throw will be shared in my next video
My 2001 BMW 328i (E46) build thread | EDIT: New video & upgrades on page 15-imageuploadedbyteambhp1518857018.617083.jpg
My 2001 BMW 328i (E46) build thread | EDIT: New video & upgrades on page 15-imageuploadedbyteambhp1518857048.717837.jpg
karan561 is offline   (7) Thanks
