Old 6th October 2023, 17:01   #301
Thanked: 53 Times
Old Innova (pre Crysta)
How many still own a pre Crysta model and what is the current ODO reading?
I picked up a 2007 model for cargo and i see some problems with rust. How are yours?
sidbarabari is offline
Old 21st November 2023, 15:31   #302
ex-innova-guy's Avatar
Thanked: 2,380 Times
Re: Old Innova (pre Crysta)
Hey, sorry for such a delayed reply. We had a 2015 Innova which did 260k km. There was only one patch above the Rear Left Door which had the rusting issue. Other then that no rusting issues on the car.
ex-innova-guy is offline   (1) Thanks
Old 21st November 2023, 15:53   #303
Thanked: 53 Times
Its alright @ex-innova-guy. I have restored most mechanical parts of my old innova and I want to keep maintaining it up to the original spec. I have problems with battery discharging every couple of days and theres a rusted battery tray which is currently supported only by the front wheelwell.
any ideas on how to work things in this situation?
Old 21st November 2023, 16:33   #304
Unfortunately I have no idea about both of them. Although, you can post about battery discharge problem here (Battery getting drained out | Battery discharge problem) and hope you find an answer. You said you have kept it original but did you happen to install any other electrical accessories? It might be causing that. We had changed the headlight bulbs outside ASS once and it kept going kaput(not sure what went wrong). We always got it serviced at the ASS and they were quite supportive in diagnosing and rectifying any issues we had. Get it checked in the ASS or a competent FNG.
Old 21st November 2023, 19:34   #305
Thanked: 53 Times
Re: Review: 2013 Toyota Innova Facelift
Everything about the wiring is stock. Maybe its the old true elctronics. I will get the battery checked once to see if its the right one.
I dont want to spend much on it as its our employee car but i want to restore it in budget.
Old 26th November 2023, 17:25   #306
Thanked: 164 Times
Sorry for the delayed response. I have a 2013 Innova VX from April 2013. The ODO reads appx 92K. Primarily used for long distance travel. Changed a set of tyres around 56K and 2 sets of batteries. The vehicle gets serviced regularly (not sure what the guys do except pressure wash and check the brakes and replace engine oil of course. I've also changed the oil and filters a couple of times myself. All good with the car. I'm glad I got it before the prices went up insanely.
Rgds, Balaji
Bsimhan is offline   (1) Thanks
