Old 3rd June 2013, 15:55   #1096
speedsatya's Avatar
Thanked: 738 Times
re: Review: 1st-gen Honda Amaze (2013)
Refueled for the first time today after buying the car . While the display showed 19.3kpl as the average FE , the actual figure that I got was 17.xx kpl .
No complaints on this city driving figure for sure . Any thoughts on how is there a difference between this actual FE and the average FE shown on the display ?
Could it be that petrol pump reading wasnt accurate ? Which means it could be overreading? Which also means they are cheating customers
speedsatya is offline
Old 3rd June 2013, 16:15   #1097
@speedsatya- The readings in the display are mostly on the higher side. I've been driving my Brio for over a year now and my actual fuel efficiency (full tank-full tank) is always ~1 lower than the displayed mileage.
Probably a marketing strategy to keep customers thinking that they are getting something more (like our speedometers!)
rony180 is offline
Old 3rd June 2013, 16:24   #1098
Thanked: 75 Times
There needs to be a surety that the petrol filled from the pump also is correct. So you never know. Although manufacturers try to tune their meters to ideal situations; such situations may not exist. My two cents..
MuzzledMoose is offline
Old 3rd June 2013, 16:32   #1099
speedsatya's Avatar
Thanked: 738 Times
I drove 510 kms and the pump showed 29.55 litres ,which equates to a FE of 17.25kpl .
The 19.3 kpl figure should have allowed only 26.4 litres of fuel .
Now thats a difference of close to 12 % !
Let me try at a different pump next time .
Old 3rd June 2013, 22:53   #1100
Thanked: 75 Times
out of the 29.55 litres showed in the meter, we are unsure how much really went inside. this was my thought
Old 4th June 2013, 02:13   #1101
Thanked: 101 Times
my amaze is showing 17.4km/l as average on the display and i am getting slightly above 17. i filled 32 liters of diesel and the car drove for about 550 kms on it
coolmob is offline
Old 4th June 2013, 14:33   #1102
INNOVATOR's Avatar
Thanked: 151 Times
After reading multiple posts on the AMAZE in this very forum, the claimed mileage of 25.8 KMPL looks to be a gross over-estimate. 17.X seems to be the norm in the city. My experience has been that the city FE trails the highway FE by max of 4-5 KMPL that would result in 21-22 KMPL at the most for the AMAZE on highways
Owners - pl. confirm since this may be the only way to get consistent and accurate information to the masses that aspire to buy the AMAZE for its "AMAZING" FE.
INNOVATOR is offline
Old 4th June 2013, 15:05   #1103
Thanked: 101 Times
generally the FE should increase a bit after a couple of services. My friends BRIO gave an avg of 10.8 when he bought it. now after 3 services it is consistently giving 13.5kmpl to 14kmpl. and this has been calculated from the tank full to empty method although the display shows 14.8kmpl. and this is from city driving!
considering that i expect the FE to go up to around 19kmpl to 20kmpl with ease after a couple of services.
coolmob is offline
Old 4th June 2013, 15:21   #1104
speedsatya's Avatar
Thanked: 738 Times
Then it could be the petrol pump. Lemme try another pump.
BTW I notice that I am getting improved fuel consumption numbers as compared to the more expensive Shell Diesel. Has anyone else faced similar issues ?
Old 4th June 2013, 17:13   #1105
Thanked: 101 Times
you should not use premium diesel. all manufacturers advice against using premium fuels in cars. when i took the delivery of AMAZE the sales rep clearly told me not to use any premium diesel and if i did use it and it caused any problems with the fuel pump or injectors, honda would not replace it under warranty.
coolmob is offline
Old 4th June 2013, 19:18   #1106
speedsatya's Avatar
Thanked: 738 Times
This is interesting ! The Dakshin Honda sales rep actually asked me to try and fill Shell diesel as much as possible.
Old 4th June 2013, 23:06   #1107
humyum's Avatar
Thanked: 5,573 Times
Read the manual satya. It would categorically state about only using normal diesel. Diesel with additives will be detrimental in the long run
humyum is offline
Old 5th June 2013, 00:18   #1108
speedsatya's Avatar
Thanked: 738 Times
Yeah. I read the manual later on. The sales guy kept on telling me to fill at Shell.
Old 5th June 2013, 00:28   #1109
Vid6639's Avatar
Thanked: 43,785 Times
Same with my Figo. Shell gives lower FE vs Indian Oil or HP.
Also, the difference in FE could be because you did not do auto cut off.
Vid6639 is offline
Old 5th June 2013, 10:34   #1110
rajshenoy's Avatar
Thanked: 2,255 Times
This is news for me. With Diesel prices going up, i was feeling that Shell diesel is now being offered at competitive price and everyone will switch for that. But if it gives lower FE, it may still not work out.
I was under the impression that Shell diesel is finally just the normal diesel sold by shell. Only thing that we can be assured is the quantity and no further adulteration in that.
Also its high time that PSU pumps improve on the quality of the diesel being sold to us. Since we are paying more from our pockets now
rajshenoy is offline
