ODO : 18,000 KM; Drive to Kashmir / Ladakh
I recently returned to Jamshedpur after a wonderful drive to Kashmir / Ladakh. I intend posting a picture-travelogue on TBHP but this involves selecting a handful of pictures out of the 1500 or so which I clicked and will take some time. Meanwhile, here’s the tech report :
Overall : Prior to this trip I had undertaken three major long drives from Jamshedpur – (1) to Delhi, Amritsar, Kasauli and Nainital; (2) to Gangtok, Nathu La, Lachung and Yumthang; (3) to Chilka, Vizag, Araku Valley and Gopalpur. But this trip to Kashmir / Ladakh was the big daddy of all my trips during the last 7 months of XUV ownership. Not only were the duration (25 days) and total distance (6,576 km) the highest, the degree of difficulty was much greater, even when compared to the Sikkim trip. Being the only hard core driving enthusiast in the team, I drove the entire 6,576 km myself (same was the situation during my Sikkim and Vizag trips; only during the Amritsar / Kasauli trip I could periodically relax and confidently hand over the steering wheel to my son-in-law Sandeep who is a very capable driver).
My XUV-W6 once again proved to be a reliable, capable and efficient machine. This trip involved crossing several high altitude mountain passes and some of the roads were quite bad and treacherous. Furthermore, I found a lot of water / slush / mud on high-altitude roads due to copious amounts of melting snow. One would probably feel more comfortable (less stress for the driver) with AWD / 4WD on slush, mud and ice (yes, there were a few places where I had no choice but to drive on ice, but such stretches were very few and also very short) but my FWD did not let me down anywhere.
High-altitude performance : During this trip I could distinctly perceive the reduction of engine power at high altitudes as long distances needed to be covered between the altitudes of 13,000 to 18,000 feet and many mountain passes had to be climbed. There were 5 adults plus a fair amount of luggage in the XUV and so it could be considered almost fully loaded. But the XUV engine has adequate power on tap and by choosing a lower gear and maintaining a slightly higher RPM all obstacles could be easily crossed.
View of the luggage space.
Incidentally, out of the 5 of us, my own baggage was the minimum, both in weight and volume. Note the apt tag on my daughter's bag!
Sub-zero temperature issues : Though I drove through mountain passes early in the mornings when the ambient temp was minus 4 deg C, the car was never parked overnight at sub-zero temperatures (unlike during the Sikkim trip) and so there were no issues like starting problem, diesel freezing or ice on the windshield. Incidentally, low temperatures slightly compensate for high-altitude as far as engine power is concerned. At high altitudes, the number of molecules of oxygen per litre of air greatly reduces, reducing the quantity of fuel that can be combusted in each cylinder and, in turn, the power output. However, colder air is a bit denser and is easier to compress in the turbocharger (greater boost pressure) and this partially compensates for the rarefied air at high altitudes. Please note that this compensation is only partial, otherwise the reduction of engine power at altitudes greater than 13,000 feet would not have been so obvious to me.
Suspension : Performed wonderfully throughout. With the XUV almost fully loaded, the suspension was subjected to some bad jolts but took them in its stride. Suspension of the XUV certainly inspires confidence. There were no squeaks or any abnormal noise heard from the suspension.
Ground clearance : On the whole, I found the GC adequate. But there were a few bottom scrapes, usually while crossing large puddles with invisible submerged boulders or raised areas. While going from Srinagar to Kargil, I had to cross one such large water-filled crater near Zozi La and I could hear the sound of the bottom getting scraped. After coming out of the puddle, there was a loud noise of something rubbing against the ground. When I stopped the car and peeped under it, I saw that a part of the engine bottom guard (black plastic) was hanging loose and touching the ground.
Due to melting snow, there are many large puddles, even flowing streams, on high-altitide mountain roads.
Luckily, there was a flat paved road surface just 20 metres ahead of where this problem took place. The road was also quite wide there. So I drove the car 20 metres (with the scraping noise coming) and parked it on the flat paved road. A Xylo which was ahead of me heard the scraping noise and stopped to help. I decided to get under the car to find and fix the problem. The driver of the Xylo helped me in jacking up the front RHS of the car. Thereafter, I spread a sheet and crept under the car. After inspection it was clear that I needed to cut off the part of the bottom guard which was bent and touching the ground.
Jacking up the XUV takes a lot of effort. Maybe I should invest in a small hydraulic jack.
The broken part of the engine guard which was touching the ground can be seen in this picture.
First, I tried to cut off the bottom guard with a pair of scissors. It didn’t work as the plastic is thick and hard. Luckily, I was also carrying a mini hacksaw in my tool kit and with it I could saw off the bent part within a minute. The problem was solved.
Tyres : The Bridgestone Duelers worked very well and offered adequate traction and cushioning under adverse conditions. I would like to place on record here that unlike some other XUV owners I have never yet faced the problem of misalignment or the car pulling to one side. While driving on straight and smooth roads I sometimes leave the steering wheel to ascertain whether the car is pulling to one side. Also, I periodically examine (visually) the front tyre treads for signs of uneven wear. So far everything seems to be fine.
Interestingly, a few months back when I happened to be enquiring about the wheel alignment setup at my ASC at Jamshedpur, my R.M. advised me against getting the alignment adjusted there as there were reports of alignment getting worse after the adjustment!
Steering : Fully satisfied.
Engine : No complaints. Keeps on delivering effortlessly. As mentioned earlier, there was perceptible drop in power output at altitudes above 13,000 feet and I needed to push it harder. During this trip the turbo whine somehow seemed more audible than before, though I couldn’t exactly understand why. I need to concentrate on this sound during my future long drives.
Transmission : Fully satisfied.
Brakes : No major issues. On two occasions a shrill metallic grinding noise was heard from one of the front wheels (without the application of brakes) with the car moving at slow speed. As I had faced this issue earlier, I simply kept driving and on both occasions the noise vanished after a few minutes as suddenly as it had appeared. I think this noise comes when some hard particle gets lodged between the brake pad and disc. On one of the occasions the noise started after crossing a deep muddy puddle.
Air-conditioning : For the first time since purchasing the car 7 months ago, AC was put to the acid test with ambient temp. in the region of 43-44 deg C. And it passed the test with flying colours.
Cruise control : Both while driving to Delhi and returning from there, I took the Yamuna Expressway and used cruise control continuously on the Y.E. Thus my cruise control was tested over a distance of approx 350 km during this trip and it worked flawlessly.
Breakdown : I got a real scare when I started from Kargil (for Leh) on the morning of 17 May and after 500m or so the car stopped and refused to restart (though the starter was cranking the engine properly, it was not starting). 'Check Engine' lamp came on and there were also some strange symptoms (brake lights remaining on without applying brakes, remote locking / unlocking non-functional, infotainment system remaining ON even without inserting ignition key).
First I tried to reboot the system by disconnecting and reconnecting the battery. But it didn’t help. To make matters worse, the engine could not be cranked now. I called M&M Roadside Assistance and they made me talk to a technician who advised (even after being briefed in detail about the symptoms) me to purge the fuel system. Though I was not convinced, I purged the system as advised but the engine could not be started.
When I reported the situation to M&M, they decided to send a flat bed truck from Srinagar and carry the XUV to a Service Center at Srinagar. This was going to be a major exercise as Zozi La pass (very bad and treacherous roads) needed to be crossed between Srinagar and Kargil. Also, at least 2-3 days would have been lost. I was convinced that the problem was with electronics only and could be rectified in-situ. After many phone calls I finally convinced the Service Manager in charge of J&K to render in-situ assistance and not take the XUV to Srinagar. I also requested Heavy Horse (I had his phone number) to escalate the matter as there were 5 (including 2 young ladies) of us in the XUV and the entire Ladakh trip was at stake. Finally, a M&M dealership-cum-ASC (dealing in Boleros, Scorpios) was identified in Kargil and they were directed by M&M to render assistance in-situ.
My XUV was towed to the Kargil ASC just 2 KM from where I was stranded. During investigations some moisture was found inside the fuse-box inside the engine compartment. After drying it with compressed air everything became normal and the engine started.
Purging the fuel system -- an exercise in futility.
A Bolero pick-up truck getting ready to tow my XUV.
The tow rope brought by the pick-up truck parted even before my XUV could get moving. Then my own nylon rope (bought in Delhi) came in handy.
Little moisture was found in the fuse box inside the engine compartment.
My XUV being attended to at M/s Vehicleage, Kargil.
Apparently, the problem occurred because I got the XUV washed at Kargil the previous evening. Some water was splashed inside the engine compartment during the washing.
Overall, the support and response received from M&M during this ordeal was quite positive. They even offered to give us a car free of cost to proceed with our planned trip to Leh while my XUV was taken to Srinagar and repaired. Because the Kargil workshop was not equipped to service XUVs, M&M decided to follow their standard operating procedure of towing the car to the nearest XUV workshop (Srinagar). It took a lot of effort on my part to persuade them to deviate from their SOP and render in-situ assistance. This turned out to be the best decision (both for M&M and me) as the root cause of the electronic fault was a relatively minor one.
Niggles :
- One peculiar niggle with the music system started about halfway through the trip. With the car running and the music playing (any source) there would be a sudden loud low frequency sound from the speakers and the music would stop. The indications of music playing and volume level would be seen on the display but no sound comes from the speakers. Initially we all thought that the sound was coming due to some loose object rolling about inside the car and dashing against something; only later I realized that there was no loose object and the sound was apparently coming from the speakers. After turning the ignition off and on, the music system returns to normal.
- Some minor body squeaks raise their ugly heads sometimes on rough roads.
- One of the horns (left side) stopped working towards the end of this trip. The reason was that one of the two electrical wires to that horn snapped. It may be recalled that one of the wires of the same horn had snapped earlier during my Sikkim trip. If the wires to the horns repeatedly break off, it can definitely be interpreted as either a design flaw or sub-standard quality of wiring.
Mileage : I don’t have much faith on the DIS reported mileage any longer. It is indicative, at best. In my case, whenever I reset it and go for a long drive, it usually increases to 18.0 kmpl quite soon and gets stuck there. So I have to rely on tankful-to-tankful method only.
The overall mileage over this entire trip works out to a phenomenal 15.63 kmpl. This mileage has been calculated over 6648 km by TF to TF method and is reasonably accurate. AC was used non-stop in the plains (where ambient temp. was as high as 43-44 deg C) and as required in the hills. It is worth noting that even while driving in Srinagar, Gulmarg and Pahalgam AC was required. During most of the driving in the mountains there were 5 adults and lots of luggage in the car. During the legs Jamshedpur-Delhi and Srinagar-Delhi-Jamshedpur there were 3 adults plus their luggage in the car.
Battle scars : On a narrow mountain road my XUV was lightly grazed by an Army truck. It was entirely the Army driver’s fault as a big convoy of trucks was coming from the opposite direction and I had pulled over and completely stopped my car to allow the convoy to pass. A few trucks passed my car without any problem but this one bad driver came too close to my car and grazed it. Fortunately, the damage was not much – a few deep scratches.
Battle scars! ![Debuda’s Silver Mahindra XUV500 W6 @ Jamshedpur-xuv-11.jpg](https://www.team-bhp.com/forum/attachments/test-drives-initial-ownership-reports/1094054d1691557343t-debuda-s-silver-mahindra-xuv500-w6-jamshedpur-xuv-11.jpg)
